Hey folks,
I'm about to dive into a few bigger projects that will kick off my real 80 build thread. Here are the while you're in theres I've thought of for each job. What's missing?
Gas tank replace/refresh:
- New tank straps
- New seals
- New valve
- New clamps for hoses
- New fuel sock
Rear axle housing swap (rebuilt the rear axle a few months ago; this will be swapping the guts into a new housing):
- New crush washers for diff
- New paper gaskets
- Already have new bearings back there
- Rebuilt the e-brake already
Radiator core support replacement (this:Radiator Core Support FJ80 , FZJ80 & LX450 - $250.00 : CruiserParts.net, Toyota Landcruiser Parts) The whole front face of the truck needs to come off, seems like.
- New belts (mine aren't OEM)
- New radiator foam
- Clean radiator
- Would fuel filter be easy with this piece removed? Already did oil pump cover seal and crank shaft seal.
Thanks for your input. I'm going to put in an order to @beno but I'd rather just have it be one order! haha
Thanks in advance for any replies.
-- Beej
- New tank straps
- New seals
- New valve
- New fuel sock
- New paper gaskets
- New radiator foam
- Clean radiator
-- Beej
