Part 3 of our series on fixing old issues is my antenna. It has been stuck about 3 inches out of its hole for some time now. Turning the radio on does nothing for it and the reception sucks. Today I had the wife sit in it and press the up down button while I listened and gently pulled on the mast. The first time the mast actually came up about halfway and I could hear the little teeth moving on the gear. After that it neither went up or down. When the button is pressed I can hear a click down where the motor is at, but no movement of the mast. Do I simply need to order an antenna removal tool and a new mast with plastic gear thing attached ?
