Looking good, Someone just told me there was another lifted Lexus in town. I'm glad I'm not the only one here. I was thinking about doing the ditch lights in Aug but was unsure on how they would fit. Did you have to modify the brackets at all?
purchased in Portland for $12k, 144k miles, lexus dealer maintained, non-kdss, does have factory navigation, was owned by a 73 year old lady who's husband is a dentist. It has brand new brakes all around, new tires, new battery all within the last year. interior is dark grey.
Mods so far 10/15
tinted front 2 windows
glasspack cat back with 2.5in pipe, sounds amazing. Not to loud, exits behind passenger rear tire.
White LED light kit for interior
HID kit for low and high beam.
Yellow fog light bulbs
Die hard platinum battery.
ordered...
Ironman complete suspension kit, comfort soft ride springs in back, Ironman 4x4 FJ Cruiser Front Springs 0-110lbs extra weight, nitro gas front and rear shocks. AIR LIFT 60809 1000 Series Rear Air Spring Kit
Light racing UCA's.
BFG KO2's 275/70/17's
level 8 MK6 gunmetal 17 X9 6-139.70 -12 offset
near future...
Cbi ditch light mounts(gen4 4Runner)
Sliders
smittybuilt xrc 9.5 winch w/synthetic line
bud built hidden winch mount.
Your order is correct. I did NOT use FJ coils. I used the kit in your pic. Get the rear coil kit the make as well.Wingy,
I am on metaltech's website and I've attached a photo of the setup that I think you ordered, can you confirm this? I'm kinda confused because you said complete ironman lift kit, but it looks like you used FJ springs in the description above. Also what is the air lift 60809 1000 series rear air spring kit?
Sincerely a lift kit newb trying to get his bearings on lift kits.
I highly doubt you could fit my tire/wheel combo with out lift. In retrospect I would keep the stock UCA's and get sliders instead. Several guys have kept stock UCAs with no problem.
Wingy,
My bad, I thought I posted this question a few pages back on your ditch light install but it looks like it posted here...sorry. Was originally referring to the linked harness and switch for your led ditch lights.There is no switch or harness at all. The wires come directly off the LED strips, a positive and a negative wire and I just wired those LEDs to the rear cargo light. So when I open up the back hatch All the lights come on. Hope that makes better sense
