Slomo
It's Complicated
So I searched and read the FAQ on the steering gear box and general steering issues and found lots that is almost this but not quite. 2 core problems 1) excessive steering wheel play and 2) Rough steering feel. Sounds like whats been asked a million times I know but keep reading.
1. My steering has excessive play, at its worst it was 2.5" of steering wheel play but currently at 1.5". It was also darting all over the road very inconsistently which I traced to 2 separated radius arm bushings so I replaced all 6 and that is gone but the play remains. I know it will inherently have some and I do not expect rack and pinion type response but I feel I should be able to keep it in my own lane!
I have gone through everything. Trunion bearings are set to proper preload, wheel bearings set to proper preload, tire inflation even and good, all rod ends are EMF custom units adjusted and lubed, panhard good, power steering pump is rebuilt verbatim per FSM with parts from Cdan, new belts at good tension with no squealing, Redline ATF in system flushed per FSM no bubbles, high and low pressure hoses replaced with no leaks, and power steering box adjusted verbatim per FSM being careful not to over tighten. I even replaced the radius arm bushings with Cdan parts. Whew, did I miss anything?
I have a 6" Slee lift, knuckles cut and turned to set castor at +5* confirmed with alignment, I have Hellfire knuckles, 1" wheel spacers which I know affect the scrub radius but were on long before the issues came about, running 315s for a long time and it has done a lot of rock crawling and off roading in general since I got it at 124k miles with 176k miles on it now with a great service history.
2. I told you all that to tell you this. After the second gear box adjustment in almost year, again following FSM perfectly in small increments, my power steering is not smooth, it varies between normal ish and hard to turn and sometimes it almost wont turn at all, both returning to center and not returning to center, hot or cold. It is never too easy or does not work at all like a loose belt or air in the system. There is no regularity to it. It is behaving like the gear box is too tight but I only have it set to the MAX acceptable steering wheel play per the FSM, if I loosen it anymore it won't be driveable. Is it that the gear box is simply worn out and the adjustment used up? That doesn't seem to happen often but I don't know what else to do besides rebuild/replace the gear box. Ideas?
