last year I started having a fuel delivery problem with my 94 HDJ-80 VX with factory dual fuel tanks. Driving on the big 90l tank the car would at any given level of fuel in the tank suddenly start to run out of fuel and eventually stall. All within a very short time, at first maybe within 30 seconds to a minute then much faster. My first thought was that the respirator/tank ventilation hose was clogged and a vacuum was created which eventually starved the engine of fuel. Driving the truck with the fuel cap off and eventually changing the respirator hose proved that this was not the case. Trying to start the engine a few minutes after it had stalled would take a few turns but eventually it would start idling roughly and then a few seconds later the engine would run perfectly fine, even at high speeds, for up to 100km until the same thing happened again. I decided I would at some point take out the fuel tank and see if I can find the problem there. Until then I would make sure the second 45l tank was always as full as possible and switch to the auxiliary tank whenever the engine started failing. This worked perfectly fine. The auxiliary tank never ever failed. I always filled both tanks at the same, brand new gas station.
Finally, about six weeks ago, I took off the tank and rinsed it thoroughly. There wasn't too much muck in it to begin with and after rinsing the tank was clean. Some slightly rusty spots could be seen inside but nothing that would look anywhere like flakes of rust might chip off at any time. I put a new filter on the pick-up tube, checked the hose that goes to the switch-valve, which was OK and installed everything again. For about 5 weeks or maybe 3 entire tank fillings, I had no problem whatsoever driving on the "big tank" until about a week ago the same thing started happening again, only this time the intervals between failing became shorter (sometimes after 5km) and also the time from starting to fail to eventually stall became shorter, too (no more than 10 seconds). Again, the truck runs perfectly fine until this happens. No power loss or even slightly rough running engine at all... And then it stalls within seconds. I still switch to the auxiliary tank when I realize it's happening again, drive on the auxiliary tank for a few minutes, switch to the big tank again and again it runs as if nothing had ever happened until it stalls again.
This is really weird. Does anybody have an idea what this might be..? I welcome any suggestion
