1911, if I may ask, what was the ballpark cost of that combo? I have the F.5 and it likes about 60 mph, not that I want to go too much faster, but I also don't want to sacrifice low range speed...
Good to know. I mostly keep my 40 on the road so the wheeling aspect isn't really a concern for me>3.70s will reduce RPMs by 10%. Off road this means an increase in minimum speed by 10%.
So, depending on how you wheel, you may end up going faster than you want. For where I drive I decided to make that compromise and don't regret that choice.
It also becomes uncomfortable real quick when you are going 70 and someone cuts you off or something comes into your path. Short wheel base, high center of gravity, speed and having to take evasive actions never ends well.
One of the signs of middle age is when you become more interested in how long something will last, rather than how fast it will go.
I want to put a sign on the rear window of my cruiser that says, "going as fast as I can go" so people will stop giving me dirty looks for going 60mph.
Just driving around the city I stay at 2750 rpm which is around 64 65 mph. Since I was driving through pretty much flat terrain for long distances I was around 3000 to 3250. The 40 wasn't appearing to be straining or under any stress. Redline is 4K.
my speed is off because of the larger tires but i use my an app called speed box to get my speed.I wish. Are you sure your speedo is correct? At 2750 I'm probably just about 55mph. 4.10s and 33s. Pretty sure mine is right because everyone is riding my a$$ on the highway.
Mine too. Im sure my 2 2f 40s will go way past 75 but its been years since i cranked them so hard. The drivetrains dont appreciate it.
i haven't been able to find a pair of thirds in that price range.3.70 gears are often considered less desirable, as a result, you can often pick up a pair of thirds for $100 from a 60 series. In my case, they were in great shape and much lower mileage than the 40 year old set of 4.11s I was running.
