Love this build and your color choice. That spring green just fits... And I'm a sucker for an 8274 on the front. Lovely 40.
|Apple logo is cool looking, you sure got good with the plasma cutter.
I love the Apple graphic, your wife did a great job! What compressor is that please?
Nice air setup. Here is a good site for air accessories for someone following this thread and is building there own air system Train Horns & Train Horn Kits: Loudest Horns Available
You may have problems with the air coming off of the compressor. It gets super hot and melts hoses. I ended up running a steel power steering pump cooling tube to allow the air to cool a bit before entering the manifold. Also, you may already have this covered, a pressure cutoff switch can be screwed into the manifold and wired in series with the compressor clutch. It will then shut off at a predetermined pressure, that is less than the pop off pressure valve, for convenience and safety. They are inexpensive. I chose one rated at 120psi for my system.
What are those fittings at the top of the York?
