Well, that's a good question. So far, @ $1600 for unit, condenser and the good vents. Vents alone were $100 a piece, x4. I still need a dryer and some fancy hoses.
I have to sort out the relocation OR elimination of the oil cooler which is currently in front of the radiator...where the condenser needs to live.
Question: On a 6.0L LQ4, is the oil cooler necessary? Not quite sure where to put it.
U might run into interference on ur vent routing with the control panel there. I put mine in the ash tray slot
probably depends on your climate if you need the cooler or not you can buy blank plates to bypass the cooler hoses down by the oil filter, I've never bothered running a cooler on my engine (non race application and cooler climate)
Awesome troopy mate
On my 5.3, I used the auto trans. cooler built into the aftermarket radiator. I believe a lot of guys use the plate above and run their oil pressure line to it, not using the cooler. You could also run a small cooler in front or below your condenser.
