11-03-11, 04:46 PM
#1 | | Addict
| Phosphoric acid rust removal I finally sourced some Phosphoric acid (85%) and I am curious if anyone else has used it on their land cruisers. I have a few spots on the truck that I've rattle canned to try and keep the rust off but it keeps coming back... This time I'm also going to use a good epoxy primer and top coat....
Will just brushing this on waiting and wire wheeling then repeat until the rust is gone be effective?
Thoughts, comments and stories?
__________________ 1986 BJ70, 24v with a 3B |
11-04-11, 08:32 AM
#2 | | omnea mea mecum porto
| I have used Muratic acid (almost or same as what you use) and after letting it sit on the rusty areas until its tacky just about to dry off.. I spray or use POR15... it helps the pain adhere a lot better |
11-04-11, 10:45 AM
#3 | | Addict
| Not that I'm an expert but many forums and articles I've read say muratic acid is way more agressive an acid, not only that it also eats clean metal and will continue eating metal unit it is neutrlized. How long has the POR been on there? How's it holding up? Phosphoric acid will only eat rust until it burns itself out and become inert leaving a thin rust inhibiting coating... This is all just what I've read no first hand experience yet...
12-13-11, 04:46 AM
#4 | | Addict
Join Date: Sep 2008 Location: behind enemy lines FEMA sector IV
| I get my phosphoric acid at home depot in the paint dept. $14/ half gallon. Works great, but slow to remove mill scale, and actually protects the metal via a chemical process.
Once I am done, wash with TSP and dry with a 50% blend of water and alcohol rubdown. Minimizes flash rust and speeds drying
__________________ Pillguy Illegitimi non carborundum
1997 4runner Mods:33 muddies, elocker, lift, armor, etc.  |
12-20-11, 06:43 AM
#5 | | 250+ Club
| Hi there, I've been to Home Depot, Rona and Canadian Tire...at all three places, I could not find Phosphoric Acid. I'm heading into Christmas vacation time now and would really like to get started on the rusty frame that my Cruiser has. What better way to spend my vacation time eh...under the Cruiser
So, anyone with ideas on where to buy Phosphoric Acid in Canada, please let me know!
BTW, the HD guys tried to sell me an "environmentally friendly" alternative to Phosphoric Acid, but when I described why I need it for, he told me it won't work.
__________________ ---
'87 HJ60 Landcruiser 6-cylinder diesel, 5-speed manual. 213k km
'84 W123 Mercedes 300D, 5-cylinder diesel, auto. 581k km
12-20-11, 08:46 AM
#6 | | Geezer
| Look for Jasco Prime & Paint. Home Depot and Lowe's have it in Washington.
__________________ 1978 FJ40 mostly stock
1976 FJ40, 5.7l Vortec, NV4500, Orion
1976 FJ40 being brought back to life |
12-20-11, 10:01 AM
#7 | | 250+ Club
| Quote: |
Originally Posted by spotcruiser Look for Jasco Prime & Paint. Home Depot and Lowe's have it in Washington. | Thanks! I'll have to get it next trip down then. Wonder why nothing's available over here. I'll pop by IPP today though to see if they have anything.
12-21-11, 08:29 PM
#8 | | 250+ Club
| http://forum.ih8mud.com/fj25-owners-...ml#post7191519
In my rebuild thread I have used the Phosphoric acid. I think it woorks very well. the pictures in the link above don't tell the whole story. The blaster I used to try and clean the metal works very well on paint and light rust. The stuff in the photo wasn't even responding to the wire brush in a 4" grinder. All the grinder was doing was shine the rust. Given enough time I'm sure it would have worked but the Prep & Etch at HD works MUCH faster. It's still not quick but it's the only thing that works for me.
__________________ Rod
65 Fj40 in rebuild mode. |
12-22-11, 06:39 AM
#9 | | Lifer
| Quote:
Originally Posted by markthemenace Hi there, I've been to Home Depot, Rona and Canadian Tire...at all three places, I could not find Phosphoric Acid. I'm heading into Christmas vacation time now and would really like to get started on the rusty frame that my Cruiser has. What better way to spend my vacation time eh...under the Cruiser
BTW, the HD guys tried to sell me an "environmentally friendly" alternative to Phosphoric Acid, but when I described why I need it for, he told me it won't work. |
As above...straight white vinegar works too on parts that can be submerged. Because its only 6% acid solution it just takes longer than phosphoric acid or muriatic acid (muriatic acid only takes seconds to minutes). When you pull them out of the soak, could be 2-3 days depending upon how much rust on the parts, rinse the part under hot water...a little easy scrub with a bristle brush helps too...then immediately dry the parts.
Works great for me...
__________________ 1999 100-Series...kinda modded.
2009 Kimberley Kamper Sports RV; sadly gone but to a great new home that will surely sponsor as many wonderful memories for them as it did for me. Truly one of the best possessions I've ever owned!
ROTM: spressoWAGON ROTM Blue Ribbon Coalition Life Member |
12-22-11, 10:42 AM
#10 | | 250+ Club
| Quote: |
Originally Posted by Icantdive55 http://forum.ih8mud.com/fj25-owners-...ml#post7191519
In my rebuild thread I have used the Phosphoric acid. I think it woorks very well. the pictures in the link above don't tell the whole story. The blaster I used to try and clean the metal works very well on paint and light rust. The stuff in the photo wasn't even responding to the wire brush in a 4" grinder. All the grinder was doing was shine the rust. Given enough time I'm sure it would have worked but the Prep & Etch at HD works MUCH faster. It's still not quick but it's the only thing that works for me. | Thanks for sharing your experience Rod. Yeah what you're doing parallels my intention somewhat. In my case I'm trying to fix a rusty frame. That 1 Gal Klean Strip is EXACTLY what I need, but is nowhere to be found here in metro Vancouver. For some reason, phosphoric acid is a bad word here!
That vinegar idea would be good for small parts, but for the frame, no.
12-22-11, 11:52 AM
#11 | | Addict
| We used to put corroded metal that we found while diving into Coke to get the rust off.
That's the classic coke; not sure how the diet or zero would work.
__________________ 1978 FJ45 - 2nd owner and I wheel it
1994 4Rnr - sold |
12-22-11, 12:45 PM
#12 | | You want to do what...?
| phos acid works great.
I just got some at Home Deport for $15 a gallon (around 50% strength). It's sold among other ways as a cleaner / etcher.
I just did a rusty cast iron grill grate a couple of days ago. It looks brand new now. And so easy. Just spray with a bottle and let sit for a while very wet, repeat as necessary, then rinse (don't let it dry on as there will be unsightly deposits).
Some Naval Jelly also contains phos acid but did not work well at all for my needs. Not as strong and has to be brushed on, which is a pain for intricate big stuff. And much more expensive. But that might be better for body or frame work as it won't drip.
A good thing about the phos acid is that it'll leave a phosphate coating which is supposedly somewhat rough/porous and would therefore in principle soak up oil (as in Parkerizing maybe) or make a good substrate for paint.
__________________  : '97: 90K, 3xlock, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar Tradesman full rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!).  : '03: 125K
DDs: ex-Accord (seller's remorse), Prius  : souped-up DR650 |
12-23-11, 12:32 PM
#13 | | 250+ Club
| In my research, I've also come across the use of tannic acid as leaving a superior coating. Any ideas where to get that?
12-30-11, 03:46 PM
#14 | | Forum Regular
12-30-11, 04:53 PM
#15 | | 250+ Club
| Well, I drove down to Lynden the other day, and the guy at the hardware store told me that Phosphoric Acid is no longer allowed in Whatcom County. So I guess BC must be the same, which explains why I can't find it anywhere.
I've got a whole bottle of Evaporust that I used in the restoration of an old Lee Enfield that worked wonders for parts soaked in it. However, I can't possibly soak the frame...so, I'm going to try brushing it on and seeing if it works. I've run out of options it seems...
02-08-12, 08:33 AM
#16 | | Addict
| I've been using Ospho. Ospho Rust Treatment - Since 1947. I find it at ACE in the states for ~$30. The rust converters are mostly phosphoric acid. My body shop friend uses Rust Mort with success. Rust Removal and Metal Treatment. For a frame, I'd look at Chassis Saver. Monstaliner do-it-yourself roll-on truck bed liner
__________________ 96 LEXUS LX450 factory locked, 36X13.5X17 Bias Iroks, 17 FJ steelies, 1.5 in spidertrax spacers, OME Js & Ls, CDL switch, 7 pin, LEDs, Metal Tech Sliders, 2" Front Spacers, & Front Tube Bumper, Warn 9.5XP, Nitro 5.29s, audio stuff
87 FJ60
70 M35A2
87 4Runner 127k |
02-27-12, 09:09 PM
#17 | | Forum Regular
| Best way to remove rust - Get a 20 gallon plastic bucket at Home Depot or Lowes. Get a metal air flow duct that fits into the bucket leaving room around the edges of the bucket. Have a battery charger with about 8 or so amps. Go to grocery store and get a big box of baking soda. Supplies will cost you less than a gallon of the acid (minus the batter charger).
Fill the 20 gallon bucket with water mixing one tablespoon of baking soda to each gallon of water. Lower the metal tube duct into the bucket having about an inch or two of the rim above the water.
Attach the positive charge from the battery charger to the metal duct being careful not to touch the water with positive clip (it needs to stay dry).
Attach the negative clip firmly to the part you are trying to de-rust. Lower the part into the center of the duct being careful not to touch it to the positively charged metal ring. If you touch the water while lowering the part in the bucket, you will feel a stinging sensation. It wont shock you but it is unpleasant after a while (experience talking).
If you do it correctly, bubbles will begin to form on the part and after a while the rust will begin to collect on the positive charged metal. Leaving it over night, you will find a bucket full of nasty foam stuff, the sacrificed metal covered with rust and your part clean as new.
This is the cheapest and best way I have found to remove rust on parts that can fit in a 20 gallon bucket. For bigger parts, I suppose a bigger tub would work just as well.
__________________ 2008 FJ Cruiser TT "Cinder Block"
1995 4Runner "Munford"
1974 FJ55 "Napoleon"
1973 FJ40 "Elsie"
1998 Ford Expedition "Henrietta"
TLCA #18510 |
02-27-12, 09:52 PM
#18 | | Forum Regular
| rust mort hey in B.C. you can buy a product called RustMort.
it is sold at KMStools.
cheap enough, and its phos. acid.
hope that helps you out.
__________________ 82 bj60 87 hj60 62 ford falcon |
05-27-12, 07:53 AM
#19 | | 250+ Club
| Yep home depot has it ( phosphoric acid) after reading the thread I went to HD and bought a galon jug $15 bucks good deal. Find someone who crosses the border regularly to bring some. |
05-27-12, 09:56 AM
#20 | | 250+ Club
| My HD quit stocking it. After looking all over for it I finally found it at the Paint Mart. They sell all types of paint and they sell the prep and etch for doing the prep on metal. It was 18$ for a gallon. I built a small wooden box lined it with heavy plastic. It's the right size to fit my seat feames. I diluted it 3 to 1 and let the items soak for a day or two. Been working great! The directions say full strength on rust as heavy as I have but I couldn't afford to drop over 100$ at the time so I cut it 3 to 1 and let it soak a little longer.
