Masking off windows, chrome etc, Techniques?
Just wanted to get some ideas on methods and products used to mask off glass, chrome, latch's, etc. I have some basic masking tape, should I find something else? Using newspaper for the glass and if easy enough I am going to remove the latch's, if not then I will just put a whole bunch of tape around them and the chrome and exacto knife the borders.
Thoughts, ideas? __________________ "The Dude Abides" 1973 FJ55 |
Don't use newspaper, it degrades under solvent and will put a fine lint all over your paint job. Biggest secret to masking is to buy the best quality tape you can find, and practice until you get it right. 3M makes a "fine line" tape that's very high quality you can use for close masking. It's pretty expensive. Take plenty of time masking, remove everything possible, and use real masking paper, it's available at home depot and other places.
__________________ world's cleanest 89 FJ-62, and a few parts... 85 xcab hilux 4x4 resto'ed, 67 XKE, 1500 Vulcan, 80 Fj40 under resto..mine now! ! 03 Tacoma TRD SR5, Suzuki DR350 Born to raise Hell! Right after my nap. |
Agreed on not using newspaper. Lowes and Home Depot have big rolls of paper for like $10.
__________________ 83 FJ60, major project in progress Check out status of the build: http://forum.ih8mud.com/60-series-wagons/128847-83-fj60-build-up-thread.html |
2X on fine line tape. It's almost like pin stripe tape but made for masking. You can bend it around curves and corners without it folding up and causing a seem that will allow paint to enter. Once you masked around with the fine line tape then you can use blue painters masking tape. Then attach your making paper to the blue tape. Sounds like a lot of work but it will be worth the effort. I painted with only blue tape and got away with it most of the time but there are some spots where I didn't and it shows up like a sore thumb. Now I go the extra mile and use fine line tape.
I use the blue or green masking tape. It works great.
You can also use plastic bags, or other types of light plastic to cover stuff up. __________________ 1966 GREEN FJ-40 SOA, Stock F Motor. - Runs, stops and leaks. ![]() 1996 Toyota 4Runner - 35's, locked, armored 2003 Toyota Tundra - Stock 1996 Toyota Camry - Stock |
Noaccount Webwheeler
A tip on masking the rubber weatherstrip..... Lift it and place a piece of heavy cotton cord under it then mask the rubber with tape. This allows the paint to get slightly under the rubber resulting in a very nice finished product. Buy yourself a 3M masking machine and a roll of 12" and a roll of 4". Makes masking a snap and does not cost very much...it is all plastic. I wanna say 10-15 bucks.
GL Ed __________________ There is nothing so depraved as a man in the depths of an ether binge '66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers
#7 | |
Just try and git it.
I'm watching this thread closely for my paint job too! (FJ60) Thanks! ![]()
Spike, here is the one I have. Quite honestly, I've had it so long that I don't remember exactly what it cost. I just remember being kinda shocked at how expensive it wasn't. The papers come in several widths but I routinely use 12".
The model number is conveniently un-readable But I think it is "M1300"GL Ed __________________ There is nothing so depraved as a man in the depths of an ether binge '66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers
Thanks Degnol,
At least now I know what to look for. Searching and trying to buy right now! Found it! $22 Ace Hardware. 3M M1000 Hand Masker S. Last edited by Spike Strip; 06-01-08 at 01:46 PM. |
#10 |
The green masking tape is much thicker than the blue, it also has better adhesive. It worked great on the weatherstripping around the windows. X2 in the X-acto knife. You can get a really clean line by cutting the tape around the curves of the glass.
You might as well take off the door handles though. they're not really too hard to put back on. __________________ - 1983 FJ60 - 229K 2.5" Man-a-fre HD leaf springs, HFS shocks 4runner Calipers, 4.11 thirds 33x10.50MT's Wilderness Roof Rack CORN TACO - DD - 2005 Tacoma Double cab with Ethanol full flex converter ARB Front bumper w. warn winch and PIAA lights 3" Toy Tec Lift Rock-tec rear bumper |
#11 | ||||
Brewers in '08!
__________________ 04/75 fj40 slowly under resto...... build thread http://forum.ih8mud.com/40-55-series-tech/99015-04-75-frame-off.html '94 FZJ80 (DJ81) with 14k gold emblems(wifes) '06 Tundra/Work Truck Model Iforce V-8 ( paint/estimating rig) |
Vegas Hotel | Ringtone | Cheap Car Insurance | Build your own Dory Boat | Horoscopes |
