Old 05-16-08, 01:25 PM   #1
Lulu is on a distinguished road
? media valve on sand blaster
I have a 60# pot blaster. The manual doesn't say which way the handle on the media release valve is on and off. I started with it in the horizontal position and slowly rotated in toward the down position and I keep clogging the ceramic tip. Help? I am using about 80 psi and my comp is capable of 8 scfm. It starts to abrade the paint and then thud I can hear it clog. The rubber hose was completely full of media. Am I starting it wide open and filling the hose before the air can take it out?
Thanks for any help.
Brad
1974 FJ40 down to the frame
Lulu is offline   Reply With Quote
Old 05-16-08, 01:40 PM   #2
Cuerno Largo's Avatar
TLCA# 16073
Cuerno Largo is an unknown quantity at this point
what media are you using?
I have a HF pot and my media valve is horizontal in the off position. Seems that the right amount comes out at about a 1/4 to 1/2 toward vertical.
The only time I have had clogging was when I used playground sand. Occasionally a larger rock would clog the tip. Also, make sure the incoming compressed air is dry or else you will build water in the pot and the resulting mud could clog.
'75 FJ-40-In pieces on my garage floor. -Buildup thread here
'07 Titanium FJC- wife's ride
My statement to my wife: "All of the accumulated crap in my shop will be really useful if I find a use for it."
"You may all go to Hell and I will go to Texas"- Davy Crockett
Cuerno Largo is offline   Reply With Quote
Old 05-16-08, 01:43 PM   #3
It's called Amber Blast. I bought it at Northern Tool with the pot blaster. It is slightly larger than salt crystals.
Old 05-16-08, 01:46 PM   #4
TLCA# 16073
Never used that media. Any chance something could have gotten in the pot to clog up the valve?
Old 05-16-08, 01:51 PM   #5
Doubtful. The first time I took the cap off was to pour in the media. Now I did just pour it out of the bag with the pour hole similar to concrete bags in one of the corners.. with the rain and humidity recently do you think the media might be damp.. didn't pour like it was but this is my first time so I have no reference.
I guess the way it fills the media hose my thought is that the valve is flowing I just don't have the air to push it.
Have you use the small blast pots? The air hose that goes from the pressure valve at the top to the media valve at the bottom leaks (at the bottom) where the hose fits into the valve. Could that be killing my air pressure? It is only held in there by little metal teeth. I blew it out the last time it clogged.
thanks for help
Old 05-17-08, 09:31 PM   #6
They call me crazy88
cruiser88's Avatar
TLCA# 17319
cruiser88 is on a distinguished road
thanks for help
If your media is damp.......you are screwed.
Girls you need to join this club
http://www.playhardgetdirty.com/index.html
"how 'bout we sing 'kyles mom is a bitch' in E minor?"by OregonCruzer
http://s237.photobucket.com/albums/f...13957_15_0.jpg
http://s237.photobucket.com/albums/f...113957_1_2.jpg
Old 05-18-08, 08:22 PM   #7
Brewers in '08!
webelk6's Avatar
webelk6 is on a distinguished road
Check my build thread on amber crap. I tried it and fawked up alot of parts, as it doesn't leave a nice finished "smooth/pitted" look.
It heats up too quick when it hits. As far as the lever, test it all the way one way. One way is off, the other extreme is wide open.
Find the off spot and slowly open it until media is just coming out with the power of the air. Also a moisture separator might be another choice for your clogging. It will keep any media dry, while collecting the moisture in a "trap" which can be bled easily.
I agree 100%
04/75 fj40 slowly under resto......
build thread http://forum.ih8mud.com/showthread.php?t=99015
'94 FZJ80 (DJ81) with 14k gold emblems(wifes)
'06 Tundra/Work Truck Model Iforce V-8 ( paint/estimating rig)
webelk6 is offline   Reply With Quote
Old 05-18-08, 08:47 PM   #8
cruiser88's Avatar
TLCA# 17319
The MAIN media valve you may try to open and close it with someone holding the blast line. They call this choking....it may help...but i am not 100% sure what setup you got
Old 05-21-08, 08:01 AM   #9
cruiser88- I finally got it figured out, I just don't have enough air flow for it to work properly... I finally got the flow going good and my poor little compressor just ran the whole friggin time... when I close the deadman valve to let it catch up the nozzle would clog so bad that I didn't have the pressure and flow to clear it...
webelk6- I am glad you wrote that. I was starting to think that I don't like this DIY blasting much.... take that back I loved it while it worked, for about 20 seconds... The amber blast pitted the bonnet that I did finally get done badly... At least I think it was bad. First experience with blasting. It has a diamond type look to it and felt rough... Now that said it was allowing the rustoleum white primer that I sprayed (for the first time ever, that was fun too!) But I can see the really pitted area's around the bolt holes were I had the worst amount of rust and stayed on it longer with blaster... So I am assuming that I can build places like that up some with primer... but this is not a trailer queen so I am not looking for perfection....Mostly have a great time working on it just get frstrated/worried that I may not have capability to do this all on my own...
thanks everyone for chiming in! Just when I get down on the project someone lets me know they had that problem too and what they did to evercome it... great place to be this MUDD!
Old 05-27-08, 10:19 AM   #10
cruiser88's Avatar
TLCA# 17319
Originally Posted by qrst664 View Post
You write very well, support you 油罐车 油罐车 油罐车 油罐车 油罐车
spam or what?
btw must of us speak at least English.
Debt Consolidation | Mortgages | Credit Card Consolidation | Credit Cards | Internet Advertising
