"rust never sleeps"
soda blast
I was considering soda blasting for cleaning the 40 body but I hear about paint not sticking to the metal after. Is there some type of metal prep that has to be used after blasting?
__________________ pat 79fj40 rebuild and 3B diesel conversion 85 fj60 gasser 00 Chevy 6.5 td 14' van 03 Camry 79 triumph T140 70 triumph T120Rt "It's a dogs life" aren't we all just dogs anyway? falfiles#19313 FAL STG58 Aint no poodle shooter
Never heard that one. Perhaps I'm about to learn something?
You know that soda will not remove rust, right? You'd have to switch to coal slag, alum oxide, etc for rust. __________________ ="Are you gonna sit there on that friggin computer all day or what?"The desert dwellin, roadrunner chasin, soooper-genius! '90 FJ 62, '08 Scion head unit, chopped quarters and rockers, bedlined exterior, and mostly stock. My soft wheeler and DD. '85 Dodge Ramcharger a little built, and a little beat. My hard wheeler. |
Brewers in '08!
local powdercoater here uses plastic media as to not warp the body.
__________________ 04/75 fj40 slowly under resto...... build thread http://forum.ih8mud.com/40-55-series-tech/99015-04-75-frame-off.html '94 FZJ80 (DJ81) with 14k gold emblems(wifes) '06 Tundra/Work Truck Model Iforce V-8 ( paint/estimating rig) |
They call me crazy88
I knew about that but never seen it done. What kind of a profile does it leave?
__________________ "how 'bout we sing 'kyles mom is a bitch' in E minor?"by OregonCruzer http://s237.photobucket.com/albums/f...13957_15_0.jpg http://s237.photobucket.com/albums/f...113957_1_2.jpg |
"rust never sleeps"
Really only looking for info on paint adhesion to soda blasted metal. I have new heritage rear quarters rockers and floors, so rust is gone just looking to clean all the paint off the body without sandblasting it.
Brewers in '08!
From what I could tell, a very smooth profile. No pitting anywhere. Definately no chance of body panel warping. The media is about the size of a match head. Tho not sure about removing pitted rust, etc.
__________________ 04/75 fj40 slowly under resto...... build thread http://forum.ih8mud.com/showthread.php?t=99015 '94 FZJ80 (DJ81) with 14k gold emblems(wifes) '06 Tundra/Work Truck Model Iforce V-8 ( paint/estimating rig) |
#8 | |
Try www.eastwood.com or www.autobodystore.com and poke around their forums for a possible answer. If ya find anything, perhaps post it up here? __________________ ="Are you gonna sit there on that friggin computer all day or what?"The desert dwellin, roadrunner chasin, soooper-genius! '90 FJ 62, '08 Scion head unit, chopped quarters and rockers, bedlined exterior, and mostly stock. My soft wheeler and DD. '85 Dodge Ramcharger a little built, and a little beat. My hard wheeler. |
"rust never sleeps"
Yea rust never sleeps! We just slow it down some. Thanks for the links asked the soda blasting question there also so we'll see. My paint supplier told me about this problem but if you prep the surface after blasting I can't see why there would be a problem.
#10 |
If this is a valid concern, I wonder if it's a pH thing, or a lack of surface 'bite' thing? If it's either, they both are easy fixes.
#11 |
"rust never sleeps"
I have posted this question on [www.autobodystore.com] and had 2 replys, one reply was to make sure to sand the entire metal surface after blasting, and one that had paint problems? no other details although madia blasting was recomended. I may go that route.
#12 |
Here's what google turned up this morning:
This is a cut and paste from a Nova forum. "Well I contacted Sherwin Williams Automotive paint and this is what Rose Gasper, Customer Service Rep, had to say. "Application of a primer with minimal acid congertration such as etching fillers, vinyl wash, or metal preps, will react with sobium bicarbonare. This will emit carbon dioxide potentially causing blistering of the paint and then total delamination of the paint and undercoats". Then Rose Gasper wrote the following steps must be adhered to. Observe recommendations specified by the company that produces the soda and the maufacturer of the equipment used. Then before applying any refinish materials, thoroughly clean the surface with soap and water, preferably with a pressure washer, then dry. The third step is to inspect the surface for any white residue. If a residue is found repeat the second step. The last thing is after the surface is thoroughly clean, and no residue is found, follow manufactures specific recommendations for bare substrates. I hope this answers any questions you may have." The preceeding post in the same thread stated: "Warm water and vinegar will remove the residue. I add in a red scotchbrite and have had great results with small parts. I havn't done a full car yet. I also don't know any paint company that is going to warranty a paint job. When I was painting full time we had a problem with a color and called the jobber, they did replace the paint but wouldn't cover our time wasted." __________________ ="Are you gonna sit there on that friggin computer all day or what?"The desert dwellin, roadrunner chasin, soooper-genius! '90 FJ 62, '08 Scion head unit, chopped quarters and rockers, bedlined exterior, and mostly stock. My soft wheeler and DD. '85 Dodge Ramcharger a little built, and a little beat. My hard wheeler. |
#13 |
"rust never sleeps"
Sounds iffy, I dont really want to spend a lot of time and cash and have my paint peel or blister, sounds like you could be real careful and still have problems.
Although I talked to a guy at Aqua Blast today and he said that he blasts with Arm and Hammer blasting soda he says it has a a chemical in it that leaves the soda neutral? after he is done blasting he power washes the metal drys it sprays it with metal etch then washes it with soap and water. Lot of steps to get the powder off. __________________ pat 79fj40 rebuild and 3B diesel conversion 85 fj60 gasser 00 Chevy 6.5 td 14' van 03 Camry 79 triumph T140 70 triumph T120Rt "It's a dogs life" aren't we all just dogs anyway? falfiles#19313 FAL STG58 Aint no poodle shooter
#14 |
RT Customs Vortec Junky
I have used soda blasting in some of my builds. The only thing you have to tell the person or shop doing the paint work is that it has to be completly free of dust etc. Then it has to be wiped down thouroghly with vinegar. If you try to wipe it with a cleaning solvent all it will do is smear. Vinegar first then prep solvent. It will stick and it leaves a baby butt smooth surface. It will not remove rust though. You will need to take care of that before or after soda blast.
Here is a link www.sodablasting.com Call them talk to Bill or Brian these are great guys to deal with and they will give you the straight from the horses mouth answer. __________________ Cool place to get all the cruiser crap you could want! http://cruisercrap.com1989 FJ 62 4" Hell Creek Suspension, Bridgestone Duellers 33X12.50, Hummer sliders modified of course, HI-Lift Jack, Pioneer Equipment Rack, HFS 2.5 Shackles, Defender Light rack, 4 KC Rally 800 series lights, All new steering components,First responder kit, and a whole lotta stickers! Member: LSLC, DFW and Austin, BSLCA |
#15 | ||
Brewers in '08!
#16 |
I do sodablasting I do a lot of blasting for the local body shops in my area. I have done vettes merceds old mercs etc. I am not a total expert but I got a pretty good resume. In answer to paint not sticking after sodablasting. I know all the jobs I have done you wash the car down warm water and dishwashing liquid or vinegar and water. It is no big deal. I highly recommend sodablasting over the other types of blasting. 1 you can rinse away soda it will displace 2 It is totally harmless to enviro 3 The finish is excellent. Don't get me wrong sand dose have it's place as dose other types of media's. The jobs I have done where I have encountered rust those areas where gonna get cut out. The areas that had just surface rust the body shops I worked with would use a DA on it and prep the area accordingly. Hope this helps you.
#17 |
Noaccount Webwheeler
Get it blasted, then wipe or spray it with 3M MetalPrep, wait, hose off and you have a perfect surface for paint.
Ed __________________ There is nothing so depraved as a man in the depths of an ether binge '66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers
#18 |
Brewers in '08!
Did some checking with the local sodablaster, and after further review, I concur. Belay my former posts. Good, plain and simple Degnol.
#19 |
Gee, 'Elk, thanks! As I recall, i have received some great paint advice from you in the past. You're a professional painter, aren't you?
![]() Ed __________________ There is nothing so depraved as a man in the depths of an ether binge '66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers
#20 | |
Brewers in '08!
). I know a lot about paint, but mostly on the industrial side , which can be applicable in the cruiser nation.+ I just can't see shooting a cruiser after all that work, to see it fail. That would really suck. I am going with the cleaning aspect, post soda blasting. Nuff Said. __________________ 04/75 fj40 slowly under resto...... build thread http://forum.ih8mud.com/showthread.php?t=99015 '94 FZJ80 (DJ81) with 14k gold emblems(wifes) '06 Tundra/Work Truck Model Iforce V-8 ( paint/estimating rig) |
#21 |
After Soda Blasting...
As a soda blast industry professional, I have researched this subject to great legths. What I found was a product called Hold Tight 102 (www.holdtight.com). It is used worldwide as a surface after wash and used after blasting with ANY MEDIA. I am a dealer of this product and I'll be happy to sell you or any others in need this product. Visit www.ChesapeakeSodaClean.com or call Stacey at 410-271-2652.
#22 |
ok.....
