Old 04-23-08, 06:33 AM   #1
Lulu is on a distinguished road
fenders in ok shape?
Remembering I am not a welder yet. The rust in the outer radius should just be cut out and replaced correct? What about the rust where the fender and the skirt are joined... I plan to just media blast the heck out of it to get the flakes out and spray rust converter and paint. I realize that is not an important are to worry about rust but this is my first time doing all this and want to get other opinions. I am also thinking of the MT tube fender kit. Would that sheet metal be ok to make my own finish kit for the tube kit? thanks again.
Brad
ps also I think that the po had some type of liner sprayed under the fender. I have just been torching and scraping. Are there anyother ways to get that stuff off... am I wasting time? will the media blaster do it faster?
1974 FJ40 down to the frame
Lulu is offline   Reply With Quote
Old 04-24-08, 10:55 AM   #2
mooker82's Avatar
mooker82 is on a distinguished road
Those fenders look like a lot of work to me. I would honestly think you would be better off replacing them now, especially if you are already considering the ones from metaltech.
74 ford bronco , 97 40th anniversary, OME lift, ARB bumper, Dolby 5.1 surround sound Rusty 72 FJ40
mooker82 is offline   Reply With Quote
Old 04-24-08, 02:56 PM   #3
They call me crazy88
cruiser88's Avatar
TLCA# 17319
cruiser88 is on a distinguished road
blast it!!!...you can fix anything
Girls you need to join this club
http://www.playhardgetdirty.com/index.html
"how 'bout we sing 'kyles mom is a bitch' in E minor?"by OregonCruzer
http://s237.photobucket.com/albums/f...13957_15_0.jpg
http://s237.photobucket.com/albums/f...113957_1_2.jpg
Old 04-25-08, 10:16 PM   #4
Kief's Avatar
Kief is an unknown quantity at this point
You have to get any tar/undercoating or grease off before any blasting--- it will waste a lot of time and media.. heat might help, maybe solvent. Most likely elbow grease is the best bet. That can be cut out and welded up but that requires fab skills and if you are to pay someone else you're better off buying new or good used..
Kief is offline   Reply With Quote
Old 04-28-08, 06:47 AM   #5
Coolerman's Avatar
TLCA# 13645
Coolerman is an unknown quantity at this point
Cool
The fastest, and safest method (though a bit messy) to remove that tar/undercoating is a 4 inch angle grinder equipped with an aggressive coarse wire wheel. It will cut right through that stuff. Go over it with a solvent to remove the last traces of tar.
This is how I did mine (though not done yet) Drill out all the spot welds holding the inner fender to the top fender then drill out the spot welds holding the fender brace to the inner fender and top fender. Sand blast all the pieces, repair the rust by welding in new metal, prime with a weld through primer where they spot weld back together. Weld back together, prime then paint. Simple! Or just order new Toyota fenders... Pic shows one that's been partially stripped and the top fender removed...
Good Luck!
!Oy my 1971 FJ40
Not Road Legal
http://tinyurl.com/47zpb (My Web Site)
http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet)
Coolerman is offline   Reply With Quote
Old 04-28-08, 10:35 AM   #6
Pin_Head's Avatar
Pin_Head is an unknown quantity at this point
That is pretty typical fender rust. It is easy to fix by welding in a piece of sheet metal. Just bend it to fit over the fender curve, cut out the rusted part and weld in the new piece. A little Bondo and paint and you are done. It is about a 2 hr job, not counting the time it takes for the Bondo to harden.
New aftermarket fenders are $150 - 200, but there have been a lot of complaints about fit.
Pin_Head is offline   Reply With Quote
Loans | Mortgage | Buy Anything On eBay | Secured Loans | Ringtones
