Old 03-28-08, 06:02 AM   #1
VTCruiser's Avatar
TLCA# 15472
Paintable chip guard?
Can anyone recommend a paintable rubberized chip guard? I would like to apply it to the bottom 2-3" all around my body before I paint it. My HJ has this done is it's great but I don't know what was used. It needs to be something with minimal texture that will take paint. I have seen products out there, but I am looking for experience. Thanks!
Project Overland Build - Updated 8/1/08
UpstateCruisers.net
"Goes where the golden trout are."
VTCruiser is offline   Reply With Quote
Old 03-28-08, 10:15 AM   #2
Texx's Avatar
3M has the product you need, cleverly called "paintable chip guard" as I remember. Goes on clear (ish). Your local autobody paint store should have it.
world's cleanest 89 FJ-62, and a few parts... 85 xcab hilux 4x4 resto'ed, 67 XKE, 1500 Vulcan, 80 Fj40 under resto..mine now! ! 03 Tacoma TRD SR5, Suzuki DR350
Born to raise Hell! Right after my nap.
Texx is offline   Reply With Quote
Old 03-28-08, 12:24 PM   #3
VTCruiser's Avatar
TLCA# 15472
funny you mention it...I found some today when I picked up my paint. Does it work pretty well?
UpstateCruisers.net
Old 03-30-08, 07:51 PM   #4
Texx's Avatar
I never kept any of the trucks I put it on long enough to judge, I had the V8 60 the longest, never had a problem with it in maybe 6 months or so.
Old 03-30-08, 07:55 PM   #5
lowenbrau's Avatar
TLCA# 5513
Somewhere in the middle of Buckroseau's 45lv buildup he tints some rocker guard and uses it on the underside of his wagon.
Seems like the right thing to do.
Rocky Mountain Land Cruiser Association TLCA # 5513
'87BJ74, '86BJ70, '78FJ45, '53M100, '90M101cdn
I support our Troopies
lowenbrau is offline   Reply With Quote
Old 03-30-08, 08:58 PM   #6
baxter650's Avatar
I have used a product from "Proform" i think it's called panel guard, it's tintable and tough.
I have used it as undercoat and has held up great.
1980 PU 9" lift 383 38" Swampers
1993 FZJ80 6" slee lift 37s
2000 XR671L
83 BJ60 under construction
2008 XR650L
baxter650 is online now   Reply With Quote
Old 03-31-08, 08:03 PM   #7
VTCruiser's Avatar
TLCA# 15472
here's what I got...
UpstateCruisers.net
Old 03-31-08, 08:22 PM   #8
What this guy suggested is the direction you need to go. The reason for this is because Chip guard painted over will only cause white spots when the rocks hit the outer layer of paint. If you notice on alot of vehicles, when their chip guard has alot of chips in it from rocks, the under lying layer is usually white. Therefore I would suggest a chip guard that is either Tintable....or the bottom 2-3 inches going with a "two tone" like paint job. For example, the upper portion your color, the lower layer almost as if you have a rhino lining or something that is a solid color when it is sprayed. Or even the same color as you are painting the entire truck. So that when it does get chipped, it is still the same color as the exterior chip guard.
Simply put, get your paint job......take some tape and tape off the lower sections all the way around your truck, sand the portion down and throw a cover over the rest of the vehicle so nothing is exposed. Don't forget to cover the wheels as well. Then, get yourself a black truck coating, or a 2 part bed liner kit....something that is durable and spray it yourself.
Here is an example of an entire truck sprayed.....my 85 awhile back.
Now look at the lower portion after I painted the top half with rattle can.
Just keep in mind that the 2 part bedliner type product will fade and not have a glossy color. This will be the only downside to a bedliner type lower portion. But again, I think the guy I am quoting is going in the right direction.
Do your part and keep America clean, keep Jeeps on pavement!
What?
Boogie is offline   Reply With Quote
Old 03-31-08, 08:36 PM   #9
VTCruiser's Avatar
TLCA# 15472
thanks for the info. This stuff is clear, but your right in that the under layer will show through when I the paint gets chipped off of it. However, my main concern is the chips exposing bare metal which this stuff will prevent. I don't mind going back with touch up from time to time. This truck will not be a rock crawler, more a camping/expedition style truck so minor pebble chips are all I trying to protect against.
UpstateCruisers.net
New York Hotels | Credit Reports | Puma Sneakers | Stay at Home | Biker shirts shop
