Frame Galvanizing & Painting question
Plan on Galvanizing my frame on my 83 BJ42 and wondering what to do with the threaded holes prior to galvanizing and painting? Do I need to leave the bolts in the threaded holes so they dont get filled up?
Roberto |
I took all of my bolts out and then chased all of the holes with a tap after it was galvanized. That was easy.
I missed a few of the bolts. The ones I missed were essesntially welded in with the galvanizing. I ended up trying to back them out and the heads broke off so I had to drill and retap the holes. I would make sure EVERY bolt is out. __________________ '75 FJ-40-In pieces on my garage floor. -Buildup thread here '07 Titanium FJC- wife's ride My statement to my wife: "All of the accumulated crap in my shop will be really useful if I find a use for it." "You may all go to Hell and I will go to Texas"- Davy Crockett |
where in Tx did you have your frame galvanized?
I could not find anyone in Texas willing to galvanize. They all cited liability issues.
I had mine done in South Carolina. I had a buddy from Texas that was working construction there so he hauled it on a trailer for me. __________________ '75 FJ-40-In pieces on my garage floor. -Buildup thread here '07 Titanium FJC- wife's ride My statement to my wife: "All of the accumulated crap in my shop will be really useful if I find a use for it." "You may all go to Hell and I will go to Texas"- Davy Crockett |
Same company I am going to use here in NC. They said around .50 cents a pound, so I cant see the frame costing more than $300?
Robert |
I think I paid $250 which was the minimum charge for the acid dip and galvanize. This was a couple of years ago though.
i don't know about galvanizing but i do know the powdercoaters use silicone plugs and plug the threaded holes. i have no idea where you get them though
__________________ All ive got is my dreams and my land cruiser!
The guys that galvanized my frame did not want anything on the frame that was not metal.
Not sure if the silicone would work with galvanizing, but the temps are hotter than powdercoat I think. It really was not a big deal to tap the holes. The bigger deal was the 2 or 3 bolts that I missed. They were essentially welded in and when I tried to remove them, they snapped at the head of the bolt which required drilling and tapping which was much more of a pain in the butt. If galvanizing, make sure you check twice for any bolts that have not been removed from the frame. __________________ '75 FJ-40-In pieces on my garage floor. -Buildup thread here '07 Titanium FJC- wife's ride My statement to my wife: "All of the accumulated crap in my shop will be really useful if I find a use for it." "You may all go to Hell and I will go to Texas"- Davy Crockett |
#9 | |
#10 |
Galvanizing and powdercoating are two different animals.
Molten zinc bath is something like 900F so silicone or anything else will be vaporized. The place that did my frame actually dipped in zinc bath first to burn off crud before starting the acid/etc dipping before going to final galvanizing. Pics in my build thread (which I haven't been able to update in quite a while). __________________ 1980 FJ40 (slowly going back together) http://forum.ih8mud.com/40-55-series-tech/108807-1980-frame-off-resto.html |
#11 |
i've been thinking about metalizing/galvanizing a frame and i am wondering about how worthwhile it is to grind off all the rivets and split the c-channels before blasting and plating...
i know it makes the job way bigger but maybe the way to go, any thoughts? eric __________________ '81 bj 42 daily driver '81 bj42 project '77 fj40 everything that could be wrong is... |
#12 | |
#13 |
i have got to do some frame repairs that i am not looking forward to. want to preserve between the c-channels, where they lap together. bla bla... sorry about the wine.
#14 |
here in SC i was quoted the same $250 minimum charge for the galvanizing. Unfortunately, in order to have it galvanized, it needs to be completely stripped, and a chem-strip (at a different place) costs $450.
__________________ Project Overland Build - Updated 8/1/08 UpstateCruisers.net "Goes where the golden trout are." |
#15 |
BS - find a different galvanizer that would rather have jobs to meet payroll. Otherwise - contact South Atlantic Galvanizers - I'm pretty sure the have a shop in SC. Otherwise head down to Claxton, Ga where I know they can do it as that's where i had mine done.
__________________ 1980 FJ40 (slowly going back together) http://forum.ih8mud.com/showthread.php?t=108807 |
#16 |
South Atlantic was the one I contacted. Are you saying it doesn't need to be completely stripped?
#17 |
They told me they don't want any rubber or chemical type product on the frame. I think they meant spray on type undercoatings. I took a pressure washer to mine and then wire brushed some areas that the p.o. had sprayed some substance. They had no problem taking mine and it still had some stuff on it.
#18 | |
The only thing my frame has on it the factory paint. Maybe I'll drive up there and talk to a technician instead of the lady behind the desk... Did you have yours done at the Greenville SC location?
#19 |
Mine was done at Traveler's Rest, SC. I think the lady I talked to there was named April, but that was about 2 years ago.
#20 |
Yeah that's the same place. I'll have to try again, I'd love to save the $450 for a chem-strip....
#21 |
I would make a half assed attempt with a wire brush to get some of the paint off. Take it down to metal in a few places and then take it to them. Harder to turn you away when you are there. I know for a fact there were a few places on my frame that had overspray on it and they did not turn mine away.
#22 |
I was only mildly interested in galvanizing until I called South Atlantic in Claxton just to get a little more info. When I was told minimum charge was $250 (a couple of years ago) I got more interested. Then started asking about prep. Told them it had paint, grease, rust and response was no problem - they'd just pre-dip in zinc bath to burn anything off. I asked about contaminating their zinc and they said quantity was so small on a vehicle frame that it wouldn't matter.
They had apparently also done several frames for a guy restoring land rovers over the years. Maybe I just lucked out and its not so easy anymore! __________________ 1980 FJ40 (slowly going back together) http://forum.ih8mud.com/showthread.php?t=108807 |
#24 |
Talk to your powder-coater first - some say powder won't stick to the fresh galvanized surface. My plan with sliders and bumpers is to plate with zinc dichromate and then powder-coat because the galvanized finish can show trough the powder (the giant metal flake look). My cad plating shop has a 20' tank and I was thinking of maybe doing the frame as well and then powder coating cuz I want a black frame. Come to think of it - I need to make sure the powder will stick to the dichromate.
__________________ 78 FJ45 LWB - stock starting restomod ![]() 81 4x4 PU - 35's and lifted etc- sold ![]() 05 Sienna - the wifes sold07 Corolla - the commuter ![]() 08 RAV4 - new toy(ota)![]() Comfort the disturbed - disturb the comfortable |
#25 |
#26 |
Excellent link VT - thank you
#28 |
