Old 03-03-08, 05:07 PM   #1
2K epoxy primer
Have heard a few different opinions and wanted to run by you all.
My 40 has some spots reapaired and then primered over with the typical auto parts rattle primer. Question is, do I have to remove all of the primer down to bare metal to use the 2K epoxy primer? It is real smooth now, can I just sand with 320 or so grit and spray the 2K over the existing primer. By the way the existing primer is not over bondo or rust. Thanks in advance for any advice.
Matt
bucfan is offline   Reply With Quote
Old 03-05-08, 10:47 AM   #2
Texx's Avatar
There's a possiblity it could lift the old primer, you need to ask this question where you bought your 2k stuff. My first opinion is that it would be fine.
world's cleanest 89 FJ-62, and a few parts... 85 xcab hilux 4x4 resto'ed, 67 XKE, 1500 Vulcan, 80 Fj40 restored 03 Tacoma TRD SR5, Suzuki DR350
ANYBODY BUT OBAMA!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Texx is offline   Reply With Quote
Old 03-06-08, 08:12 PM   #3
toomanytoyzz's Avatar
I would say sand off the old primer. If it's cheap, autopart store primer I wouldn't put a higher quality 2 part epoxy over top of it. Epoxy is supposed to be sprayed directly to bare metal. I've been doing autobody for 13 years, and if there is one rule of thumb you should follow is spend the time and do it right. Autobody is a very tedious and time consuming trade, and there is nothing worse than trying to save yourself a little bit by cutting corners only to have to do it all over again .
toomanytoyzz is offline   Reply With Quote
Old 04-10-08, 09:46 PM   #4
pportmd's Avatar
...it will also go well over a coat of etching primer applied first.
pportmd is offline   Reply With Quote
Equity Release | Credit Cards | MPAA | Compare | Duwayne Burnside
