Old 02-04-08, 10:05 AM   #1
You want to do what...?
e9999's Avatar
how long before a spray gun clogs up dry?
sadly, I don't know anything much about spray guns. I have a couple that I tried once or twice to see how spraying goes, but no experience. But I'm gearing up to do some painting soon.
I was wondering how long one can typically leave the paint in the gun without cleaning it and still be able to shoot stuff out afterwards. As in doing a coat, waiting for a while, spraying again, etc. I'd hate to wait 10 mins and find the gun clogged cuz the paint dried up in the nozzle.
Haven't done any experiments on this for obvious reasons.
Clearly, I'd rather not clean it up after every coat.
This would be for enamel, rustoleum type paint.
I'm sure it depends on the gun, size of hole etc, but any general thoughts on what would be safe to do?
I'm also going to try and improvise with generic plastic bags in the tank (suction guns) to minimize cleaning up. (Recycling these newspaper bags I get all the time? ) Seems to work with water...
'97: 88K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!)
'03: 99K, the better half's...
DD
souped up DR650
Old 02-04-08, 10:42 AM   #2
IH8MUD Junior Whopper
thecrazygreek's Avatar
Check the POT life info on your paint. Thats a good indicator. I always clean my gear after every use. Or if you use the ten dollar guns from Harbor Frieght, then I guess it doesnt really amtter...
Yahsoo!
1969 Breathe FJ40 Currently in the middle of a ground up...
1976 Olive FJ40 finished as of May 2008 Faster Track Resto
thecrazygreek is offline   Reply With Quote
Old 02-04-08, 11:41 AM   #3
e9999's Avatar
does Rustoleum etc provide a pot life spec on their cans? Don't recall that, but I'll check. Or could call I guess.
Any guesses?
DD
souped up DR650
Old 02-04-08, 12:26 PM   #4
Project60's Avatar
I have sprayed some white gloss Rustoleum with my $10 HF spray gun on some wood shutters. Turned out good.
I would say it took well over 25 minutes to spray all the details in the shutters and the paint had no intention of drying in the gun.
It does depend on temperature as well.
83 FJ60, major project in progress
Check out status of the build: http://forum.ih8mud.com/60-series-wagons/128847-83-fj60-build-up-thread.html
Project60 is offline   Reply With Quote
Old 02-04-08, 12:28 PM   #5
e9999's Avatar
OK, thanks, but I'm talking about something else. Say you spray for 1 minute, stop and wait. So the paint just sits there in the nozzle and dries some.
DD
souped up DR650
Old 02-04-08, 12:44 PM   #6
You can go days with Rustomleum with no ill effects. Ask me how I know...
Since theres no hardner, only air will get it hard...
I would not recomend anything over 48 hours tho... And the more its thinned the less "issues" you will have..
Yahsoo!
Old 02-04-08, 02:20 PM   #7
e9999's Avatar
snip
yes, how do you know? since you clean after each use...?
but excellent, so I can just do several coats over a day without cleaning, yea!
(well, that is assuming the paint in the pot doesn't start to congeal...)
DD
souped up DR650
Old 02-04-08, 06:28 PM   #8
duck slayer
webelk6's Avatar
typically it all boils down to pot life. You should be able to shoot all day with a one part paint, 2 component , definately boils down to pot life.
04/75 fj40 slowly under resto......
build thread http://forum.ih8mud.com/40-55-series-tech/99015-04-75-frame-off.html
'94 FZJ80 (DJ81) with 14k gold emblems(wifes)
'06 Tundra/Work Truck Model Iforce V-8 ( paint/estimating rig)
webelk6 is offline   Reply With Quote
Old 02-04-08, 10:05 PM   #9
TLCA# 16723
here's what I do when in similar circumstances.
when done spraying poor the paint out of the gun into a clean container, solo cup, etc and cover with saran wrap.
then pour in lacquer thinner into gun and spray in trash for several ounces, changing flow and pattern while I do this. I leave a little bit of this thinner in pot.
when ready to spray again I shoot out the thinner to empty the pot then put a funnel filter in the pot. restir the paint and pour thru the filter. then ready to go.
if you let paint sit in the tip it can easily dry and mess up the pattern.
at the end of the day clean very well.
a vertical test panel or piece of cardboard is a good idea to test before spraying the cruiser to check for spitting, plugging etc.
good luck
78 FJ40
77 FJ45
72 FJ55
77 FJ55
and a few junkers
jm599 is offline   Reply With Quote
Old 02-05-08, 11:00 AM   #10
nuclearlemon's Avatar
TLCA# 1431
i'm guessing e9999 is talking about painting, stopping for 1/2 hr, 1hr, whatever, maybe while getting another panel ready to paint, or between coats, whatever. good question. is that the kind of info pot life relays? sorry, i'm a gun idiot also, but this summer i'll give it a go.
seven cruisers and 3 of em run and four are for sale
nuclearlemon is offline   Reply With Quote
Old 02-06-08, 07:55 AM   #11
duck slayer
webelk6's Avatar
That is exactly what pot life is. If it has a 4 hour pot life, and you are taking 6 hrs. to do it, you will have problems!
build thread http://forum.ih8mud.com/showthread.php?t=99015
Old 02-07-08, 12:11 AM   #12
Mod in Hibernation
brownbear's Avatar
TLCA# 15584
pot life is the cure rate for how long you can keep the paint before you spray it.
You NEED to clean the gun after each use no matter what. Or next time a small air orifice will be blocked and you can throw out the gun. As it will not spray nice again.
You spray one coat and have to wait an hour or so for re-coat. Yes you need to fully disassemble the gun and transfer the paint out. Clean all the pieces. Re-assemble and fill the pot with lacquer thinner and spray it clear. Failure to do so each coat and your gun will die.
The paint can hang around for days in a sealed container. Only paint with a second part truly have a "pot life" Pot life and gun usage are two different subjects.
-91 FJ80, wife's ride
Earth for Energy | Remortgages | ID badge | Debt Consolidation | Anime Episodes
