Old 01-18-08, 12:44 PM   #1
Bed liner Removal
I am building a bumper for my Ford (tow rig) that was built by a buddy of mine for his Dodge. I am modifying it with a tow plate and some other goodies.
The problem I am having is that he covered the WHOLE thing with this spray on (maybe Herculiner) junk. I would like to strip it because the top is stainless diamond plate and then have the rest Vortex bedlined, when my bed gets done.
Any ideas how I can get this junk OFF? I have tried burning it with propane torch, carb cleaner, Acetone, and it seams to get crispy when I cut near it with a plasma cutter.
My life is like trying to swallow a pine cone its tough when you live fast just to die slow.
~Shinoda
Build thread: updated 2/23
http://forum.ih8mud.com/showthread.php?t=169539
Wildman is offline   Reply With Quote
Old 01-18-08, 12:50 PM   #2
JJS
Let's Go!
JJS's Avatar
Is it the stuff that dries up really hard? If so, wire wheel or flap wheel on a 7" grinder.
I'm not even sure they make flap wheels for 7" grinders. A 4.5" also works...just takes longer..lol.
Toyota still builds real Cruisers. They sell them overseas.
JJS is offline   Reply With Quote
Old 01-18-08, 09:22 PM   #3
THat would work fine, but its on diamond plate and not on the flat. Those areas are easy.
~Shinoda
Old 01-19-08, 11:06 AM   #4
Old Fart
76FJ40's Avatar
TLCA# 8019
I've heard that brake fluid will take it off.
'76 FJ-40 with a Hula Girl on the dash for me and a '65 FJ-45 LPB for the wife. Life is good.
76FJ40 is offline   Reply With Quote
Old 01-25-08, 07:29 PM   #5
Kief's Avatar
Try some different paint strippers... Problem- they only work well in warm temperatures and DO NOT USE it without respirator or supplied air and if you do it indoors don't do it in a garage attached to a house- NASTY! I don't know if it will work, just an idea.
Kief is online now   Reply With Quote
Old 01-25-08, 07:48 PM   #6
randyr's Avatar
The PO of my '78 covered the entire floor with Herculiner. Get yourself a , grab an old wood chisel with a sharp edge, and start scraping. The stuff on mine peels right off with the chisel.
'78 FJ40
nice lookin 2F surrounded by lots o' rust
randyr is offline   Reply With Quote
Old 01-27-08, 01:34 PM   #7
Wile E Coyote's Avatar
Anothe vote for wire wheel.
="Are you gonna sit there on that friggin computer all day or what?"
The desert dwellin, roadrunner chasin, soooper-genius!
'90 FJ 62, '08 Scion head unit, chopped quarters and rockers, bedlined exterior, and mostly stock. My soft wheeler and DD.
'85 Dodge Ramcharger a little built, and a little beat. My hard wheeler.
Wile E Coyote is offline   Reply With Quote
Old 01-27-08, 02:28 PM   #8
I have tried brake clean, brake fluid, acetone, laquer thinner, all seamed to only scrach the surface. Now I am onto 5F5, commonly known as airplane stripper... This stuff is nasty, but it seams to be working. Still need to apply multiple coats, but its a jelly substance that sits where you put it and dosnt run off.
After I get 99% of it off, then il hit it again with the wire wheel to shine it up.
~Shinoda
Old 02-02-08, 03:55 PM   #9
removal
If the coating is not a roll on but a high pressure spray on such as line-x, armacoating or gatorhide it can be removed with an airchisel and a box cutter, just cut parallel lines with the box cutter and then use the airchisel between the lines is not fast or easy but it works, I have removed a few of them in the past, you can also use a grinder and a cup wirewheel.
I have never remoded a roll on like herculiner or a low pressure coating like rhino liner, vortex or reflex.
chupacabra is offline   Reply With Quote
Old 02-02-08, 06:07 PM   #10
Pat, the airplane stripper is probably your best bet (sounds like its working). I don't think I've ever seen anything eat away at paint, etc like that stuff.
- Matt Isgro
'86 4Runner SR5
Isgro is offline   Reply With Quote
Old 02-02-08, 06:32 PM   #11
First post and its in my thread, I am touched Matt! :sniffsniffteartear:
Yea I plan on buying another jug of it and going to town next week. This weekend I am building the 40's drivetrain.
~Shinoda
Old 02-04-08, 03:32 PM   #12
Who_Dat's Avatar
I just took most of the herculiner out of mine this weekend and recoated with the same stuff. It peels up better than trying to grind through it. So, what worked for me was aircraft remover and a pressure washer set on destroy. The pressure washer got underneath it and it came up in sheets. Worked great. Wood chisel for the rest. Left some of it on in hard to reach and low traffic areas, since I was reapplying.
Alcoholism is the only disease you can get yelled at for having. 'Damn it, Otto, you're an alcoholic.' 'Damn it, Otto, you have lupus.' One of those two doesn't sound right.
Who_Dat is offline   Reply With Quote
Old 02-06-08, 01:48 PM   #13
bandy rooster's Avatar
theres a product that eastwood sells when i was browsing through there catalog thats an aerosol that is specifically for removing undercoat.
71fj40-350,SM465,3SPD L/C T-Case,4 WDB's,SAGINAW
Dude!, those are my work moccasins!
bandy rooster is offline   Reply With Quote
Old 02-07-08, 04:47 PM   #14
Mod in Hibernation
brownbear's Avatar
TLCA# 15584
wire wheel on an angle grinder.
-91 FJ80, wife's ride
Old 02-09-08, 08:38 AM   #15
Got a nice one for ya....
jsaltlick's Avatar
TLCA# 17094
club soda
John
1983 VJ47 Crew Cab
1992 M-101
M-101 Trailer Tarps For Sale
Finally I can get what I've always wanted....a used Toyota.
jsaltlick is offline   Reply With Quote
Old 02-27-08, 01:10 PM   #16
bed liner remover should do the trick
products of the dominon sure seal
Di Trut is offline   Reply With Quote
Old 02-28-08, 08:44 PM   #17
Waorani's Avatar
Permatex Gasket Remover works for a lot of different stuff. I found out about it while looking for something to remove powdercoating.
1980 FJ40 (slowly going back together) http://forum.ih8mud.com/40-55-series-tech/108807-1980-frame-off-resto.html
Waorani is offline   Reply With Quote
Old 03-06-08, 08:21 PM   #18
toomanytoyzz's Avatar
I had it on the lower panel on the outside of my 85 toy pickup bed when I bought it. It was rhinolining, and it came off in almost one comlpete sheet with a heat gun and a putty knife. Took me about an hour to get it off both sides with ease. I'm not sure if it will come off in the same manner using heat if it's a cheaper brand, but it's worth a try.
toomanytoyzz is offline   Reply With Quote
Old 03-08-08, 07:26 PM   #19
8" sander and some 40 or 80 grit
bthelton is offline   Reply With Quote
Homeowner Loans | Web Advertising | Learn real Kung Fu | Free SMS | Mobile Phones
