fixing paint runs
I just wanted to make sure this was the right way to do it.
I have about 5 runs after painting last night, its a single stage ppg, beige #464. Im going to break down the run with around 220, then go to 400, 1200, 2000 grit. Do I need to scuff the rest of the body with 1200, 2000, and then paint it all again?? __________________ Firefighter/EMT My Build "Blue Ridge Cruiser" - http://forum.ih8mud.com/showthread.p...ighlight=build 71 FJ40 Mini Truck P/S Conversion Front disk brakes (mini truck) Rear disk brakes (monte carlo calipers) HFS Shackles Pertronix Electronic Ignition Frame up Resto in progress |
Brewers in '08!
You could wet sand with those aforementioned grits and then do a top coat.
__________________ 04/75 fj40 slowly under resto...... build thread http://forum.ih8mud.com/40-55-series-tech/99015-04-75-frame-off.html '94 FZJ80 (DJ81) with 14k gold emblems(wifes) '06 Tundra/Work Truck Model Iforce V-8 ( paint/estimating rig) |
yep wet sand......do a nice feather edge
If it is your final coat you do not need to spray again. You could do taht forever until you get a perfect spray.
If the runs are substantial you can use a razor blade to shave it off. Then wet sand. __________________ 1956 F-100 1968 Power Wagon 1972 FJ40 1992 4-Runner 1997 F-250 PSD 2006 VW Jetta TDI |
...put you in an FJ today
No need to repaint the whole truck. You'll get an idea of what needs to be done once you start fixin the spot. I used my thumbnail and 150 grit and ground it back to level but I only had 2 coats on it. You should be able to touch up that one spot.
__________________ John 1983 VJ47 Crew Cab "The Great Pumpkin" 1992 M-101 Tons of 40 parts for sale <---Link Finally I can get what I've always wanted....a used Toyota. |
End result
Well, things worked out great, I used 250 on the runs then followed with 400, 1200, 2000. I ended up scuffing most of the truck with 2000 and adding 3 more coats, very carefully this time. I must say she looks perty. For my 1st time doing this I am really happy with the results... I will post some pics later..
Thanks for the advice.. __________________ Firefighter/EMT My Build "Blue Ridge Cruiser" - http://forum.ih8mud.com/showthread.p...ighlight=build 71 FJ40 Mini Truck P/S Conversion Front disk brakes (mini truck) Rear disk brakes (monte carlo calipers) HFS Shackles Pertronix Electronic Ignition Frame up Resto in progress |
Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,Pics, pics, pics, pics,
Nice.......pics.
#10 |
Nice color choice.
__________________ ="Are you gonna sit there on that friggin computer all day or what?"The desert dwellin, roadrunner chasin, soooper-genius! '90 FJ 62, '08 Scion head unit, chopped quarters and rockers, bedlined exterior, and mostly stock. My soft wheeler and DD. '85 Dodge Ramcharger a little built, and a little beat. My hard wheeler. |
#11 |
Looks good! x2 on the color choice.
__________________ 83 FJ60, major project in progress Check out status of the build: http://forum.ih8mud.com/60-series-wagons/128847-83-fj60-build-up-thread.html |
Wills | Earth for Energy | Loans | Free Credit Report | Debt Consolidation |
