Old 12-10-07, 03:44 PM   #1
what to do with pinholes around weld?
I got a patch welded above my fj60's tailgate. I need to touch it up, prime, skim coat with filler, etc--but the weld has small holes. I have pics, but not with me. It was done pretty well in that there was little to no warping, but there's some small holes, probably no more than 1mm in diameter. Maybe 5 or so of them.
How do I make sure there's no rust in the holes, and how do I seal these, preferably without further welding? I don't really want to take it into the welder and wait again.
And no, I'm not going to buy a welder at the moment. Fun, but I don't have the time or space.
Carpe Discus is offline   Reply With Quote
Old 12-10-07, 06:46 PM   #2
Wile E Coyote's Avatar
IF the pin holes are 1mm or so, any skim of filler or even a quality glaze (Evercoat) would fill just fine. To abate any rust, use one of the many steel prep solutions containing phosphate, Eastwood, Zerorust's stuff, and even generic phos from a hardware store will all fit your needs.
My 0.02
="Are you gonna sit there on that friggin computer all day or what?"
The desert dwellin, roadrunner chasin, soooper-genius!
'90 FJ 62, '08 Scion head unit, chopped quarters and rockers, bedlined exterior, and mostly stock. My soft wheeler and DD.
'85 Dodge Ramcharger a little built, and a little beat. My hard wheeler.
Wile E Coyote is offline   Reply With Quote
Old 12-10-07, 09:49 PM   #3
brew8's Avatar
TLCA# 7165
I would not leave them unless you have a way to treat them and seal them on both sides, I would weld them anyway, they will be back in a year or two bubbling the paint. I know it's a PITA but do it anyway, Larry
Larry Brewster, TLCA 7165, Billings, MT
brew8 is offline   Reply With Quote
Old 12-12-07, 07:12 PM   #4
kb3gun's Avatar
TLCA# 17295
You could always try lead.
Bill
Somerset, PA USA
2007 FJ Cruiser
1966 FJ40 (Website Link:New Project) (on Mud: updated more often)
Proud member of ALCA!
kb3gun is offline   Reply With Quote
Old 12-16-07, 11:17 AM   #5
They call me crazy88
cruiser88's Avatar
TLCA# 17319
X2
"how 'bout we sing 'kyles mom is a bitch' in E minor?"by OregonCruzer
http://s237.photobucket.com/albums/f...13957_15_0.jpg
http://s237.photobucket.com/albums/f...113957_1_2.jpg
Old 12-16-07, 01:26 PM   #6
Mod in Hibernation
brownbear's Avatar
TLCA# 15584
light sand blasting on both sides of the weld. Then clean with POR-15 metal ready, then use POr-15 over the area. Then after it dries lightly scuff it. Then use the POR-15 compatible filler. After topcoat with a primer and colour.
That is how I did all my welds on my 60.
-91 FJ80, wife's ride
Old 12-30-07, 01:05 AM   #7
Dave-T's Avatar
TLCA# 16951
My solution has always been to fill em with paint!
1984 FJ60---Hi-perf 2F with other goodies
1978 Hilux---Dirty old man truck
1994 Honda XR600R
2003 Polaris RMK 800
(@)==Toyota==(@) <----- 60's rule!
Dave-T is offline   Reply With Quote
Old 01-05-08, 03:27 PM   #8
FineWynsFJ55
FineWynsFJ40's Avatar
Cut off the fender, then the fender won't rust.
Permatex makes an anti-rust converter and protector, brush on, then lightly sand on topside, fill with body filler then paint. Underside coat with whatever you want to.
Brian
~ Two paths diverged in the woods, and I, I engaged my front axle and took the path less travelled ~
1974 FJ40: Pandora's Box
1970 FJ55: Iron Pig
FineWynsFJ40 is offline   Reply With Quote
Old 01-21-08, 12:31 AM   #9
bsmith123's Avatar
JB weld
One site on welding body panels recommended using JB Weld having seen it used to seal holes in blocks I think it would stick for ever and it can be sanded drilled just like metal which is an advantage
B Smith123
Chaos, panic, & disorder - my work here is done.
The easy way ain't cheap and the cheap way ain't easy!!!
71 FJ frame off build "UGLY BETTY"
33 in BFGs, 4 inch HFS lift, Durabak lined tub, and a soft top on the way!
bsmith123 is offline   Reply With Quote
Old 01-22-08, 11:27 AM   #10
chappysfj40's Avatar
TLCA# 9188
i agree with wild e coyote run with it,
- Iam home now from the SUCK !!!!!!!
VJ60 700R4 33's 203 doubler, ARB's 4.56, OME and just a awesome truck!!!!!!!!!!
- RUBITHON 2008 TESTED
GOD ASKED FOR 10 DAYS TO CREATE EARTH, CHUCK NORRIS GAVE HIM 7..
chappysfj40 is offline   Reply With Quote
Mortgage Calculator | Free Online Games | Credit Cards | Internet Advertising | Adverse Credit Remortgage
