Home Forum Gallery CruiserFAQ Tech Links Merchandise
IH8MUD Forum
Go Back   IH8MUD Forum > General Tech Forums > Paint and Body
Join IH8MUD on Google+   Follow IH8MUD on Twitter   Visit IH8MUD on Facebook
Paint and Body Whether you brush on the rustoleum or need the code for Cygnus White, check what others recommend for tips and tools
Thread Tools Display Modes
Old 11-25-07, 11:14 AM   #1
gray
Addict
How to use/paint Chip Guard?
Anyone know how to properly apply and paint (over) Chip Guard
like the SEM product?
I replaced my OEM bumper a few months ago with a new factory painted bumper. In just this short time I am already getting little dings from stones, tried to touch it up, but a losing battle as I noticed that there literally dozens of very small pits from small stones, gravel, etc.
So, figured I would sand it down a tad, then spray it with the SEM Chip Guard, then paint over that.
Not sure if I need to prime it, as mentioned, it came painted from the factory, but the paint coat is extremely thin
Problem is, I have never used this product or anything similar, and their website does not provide an technical advice.(side chat: Dupli-Color's website is great, a ton of little video clips for the do-it-yourselfer, but nothing on the SEM website. Their products are professional grade however, so mostly body shops using their stuff).
So, anyone ever use this product of know how it should be used??
I should mention; I am not looking for a rough finish like what you see with Rhino lining; the only purpose of using the Chip Guard is to help prevent dings in the paint.
My plan is to probably use it on the front face of the metal bemper section, then paint over it, and also leaving the top of the bumper smooth and painted. In the end, the entire bumper will
be the same OEM color. At least, that is the plan.
Alternatively, I was thinking, if the Chip Guard cannot be painted over, was just to repaint the bumper, but use more layers and paint
and a clear coat to provide more strength to resist dings.
Advice from those who have used this product, or similar??
g
1985 FJ60 (Fairey OD)
1988 FJ62
1996 FZJ80 (lockers)
gray is offline   Reply With Quote
Old 11-27-07, 11:01 PM   #2
gray
Addict
Answering my own question in case anyone wants the info; called SEM, they make professional auto paints for body shops, etc.
Their Chip Guard is an Acrylic Lacquer, and as such cannot go over fresh enamel paints, which most rattle cans are; like most (but not all) Dupli-Color paints. The Chip Guard will lift or crinkle the enamel.
SEM's tech recommended either using the Chip guard on the OEM paint either of two ways;
1). Spray the clear over the OEM paint (assuming it is in good shape) and leave it as is; ie: the Chip Guard on top to protect the paint below.
2)If you are going to paint over the Chip Guard with enamel, you first prepare the OEM paint surface by sanding and using primer (etching primer if you sanded down to metal), then spray the Chip Guard, then when dry, you can use the enamel rattle can paints over it.
Of course, if you use an Acrylic Lacquer as the base color coat, you can spray the clear Chip Guard over it or vice versa.
Clear, as mud??
1988 FJ62
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
vBulletin® ©2000 - 2013, Jelsoft Enterprises Ltd.
Garage Plus, Vendor Tools vBulletin Plugins by Drive Thru Online, Inc.
©2000-2013 - Tie Rod Media, LLC - ALL RIGHTS RESERVED
