Old 12-19-07, 01:16 PM   #31
Tools R Us's Avatar
Tools R Us is on a distinguished road
Originally Posted by 5280Hawk View Post
Man, it takes a lot of buffing.
I have a rotatry orbital buffer, and it's taking forever to get the paint to shine. I started with the Turtle wax buffing compound (red label), then went to the polishing compound (green label) It's shining up but it's taking forever.
At this rate it MIGHT be done by spring.
To make the job quicker use a more aggressive compound. For the first step after color sanding I like Meguiar's Diamond Cut Compound 2.0, it makes quick work of it. Use it to knock out most of the dullness, then move to a finer compound.
The good thing about the "normal parts store" compounds is that they aren't very aggressive, so it's harder to mess up and take too much paint off. The bad part is that they aren't very aggressive, so it takes a lot more work! When you move to more aggressive "professional" compounds, you have to be much more careful around edges, ridges, etc. It's much easer to remove too much or all of the paint in those areas, but they are much faster in large flat areas.
meguiars.com: E-Store /Professional (Mirror Glaze Brand)>Auto Paint Care>Paint Cleaners/Compounds
They also have a good forum;
Car Care Forums: Meguiar's Online - Powered by vBulletin
Copper State Cruisers #007
Tools R Us is online now   Reply With Quote
Old 12-19-07, 01:49 PM   #32
5280Hawk's Avatar
5280Hawk is on a distinguished road
Thanks Alot for the tip!,
I think for the fenders, now that i know what to expect, I will get through them a lot faster, I'm not as afraid to used the more aggressinve compound, anfter the final wet sand.
- 1983 FJ60 - 229K
2.5" Man-a-fre HD leaf springs, HFS shocks
4runner Calipers, 4.11 thirds 33x10.50MT's Wilderness Roof Rack
CORN TACO - DD - 2005 Tacoma Double cab with Ethanol full flex converter
ARB Front bumper w. warn winch and PIAA lights
3" Toy Tec Lift Rock-tec rear bumper
5280Hawk is offline   Reply With Quote
Old 12-19-07, 02:32 PM   #33
Tools R Us's Avatar
Another thing to be aware of is that new paint is soft, takes a while to fully harden. When you sand it, scratches and burrs that stick up are formed. When the paint is soft, the burrs are like little plastic flags, the buffer hits them, the fold over and pop right back up. If you wait until the paint is harder the tiny edges, burrs break off much easier, making the job easier.
Also new paint off gases solvents until cured, so don't seal, wax it for at least a couple of weeks. Warmth and putting it in the sun will speed the curing process.
Old 12-19-07, 02:54 PM   #34
Got a nice one for ya....
jsaltlick's Avatar
TLCA# 17094
jsaltlick is on a distinguished road
Hawk- do you have any orange peel on that hood what so ever? I'm using 600 grit and I'm either burning through the paint or it's still faintly orange peeled. How did your hood look when done? It it slick and smooth or is there some small texture to it? Thinking I might throw on the next 3-4 coats then sand after those are done to have a thicker base. Either way I'm still gonna have to wet-sand a bunch.
2000 328i
1983 VJ47 Crew Cab
1982 Toyota Blizzard (For sale)
1981 BJ40
Finally I can get what I've always wanted....a used Toyota.
jsaltlick is offline   Reply With Quote
Old 12-20-07, 08:21 AM   #35
5280Hawk's Avatar
I had oarnge peel on the first couple coats, but not after a few more coats and wet sanding.
It seemed like I would get it where a lot of bubbles formed. I started going back over the areas that had bubbles, with the roller really dry, to smooth them out.
If you're getting alot of Oarnge peel, the paint is probably to thick and won't spread.
Also, when I wet sanded that hood I would use very little or no pressure on the block. I let the "suction" of the water and sandpaper apply the pressure to actually do the sanding, take your time and you wont burn through the layers.
I had a few really small spots that no matter what i did i could still see though the paint to the primer. I ended up just dabbing a small amount of paint right on the spot with the end of the roller, or a foam brush, then wet sanded it with a small peice of 1000 or 1500.
The photos of the hood look better than it does in real life, It's probably a good 3-4 foot paint job, and that is just fine by me.
- 1983 FJ60 - 229K
Old 12-20-07, 05:27 PM   #36
jsaltlick's Avatar
TLCA# 17094
Cool. Mine's at about a 10 footer right now.
2000 328i
1983 VJ47 Crew Cab
1981 BJ40
Old 12-29-07, 01:58 PM   #37
5280Hawk's Avatar
Hope everyone had a great Christmas!
Back to work in the garage today.
I got the JBweld all sanded down, you can see the filled holes for the snake blinders. JB weld really worked well, Thanks MUD!
I went with your advice and primered the fenders and Valence before rolling on paint. heres a few shots of the First coat of Rustoleum after the primer.
- 1983 FJ60 - 229K
Old 01-06-08, 10:11 AM   #38
5280Hawk's Avatar
I can't remember if this is the fourth or fifth coat of paint on the fenders. Either way i feel like i'm getting pretty good at getting it to go on flat.
- 1983 FJ60 - 229K
Old 01-06-08, 03:49 PM   #39
Project60's Avatar
Project60 is on a distinguished road
Looks good... I still need to drop by and see the color in person.
83 FJ60, major project in progress
Check out status of the build: http://forum.ih8mud.com/60-series-wagons/128847-83-fj60-build-up-thread.html
Project60 is offline   Reply With Quote
Old 01-07-08, 08:20 AM   #40
5280Hawk's Avatar
Project60, I PM'd you
- 1983 FJ60 - 229K
Old 01-07-08, 03:16 PM   #41
5280Hawk's Avatar
What do you think the record for length of time to paint a car is?
- 1983 FJ60 - 229K
Old 01-10-08, 11:32 AM   #42
5280Hawk's Avatar
Whew,
I just threw down some cash!. Got a decent bonus from work, so the said i could spend HALF of it on the Cruiser....
I got new Tail lenses and markers all the way around.
I got new Emblems, all that stuff from CCOT.
Plus a 1" Body lift and new bushings from 4Crawler,
and New Aussie Knock-off mirrors from Man-a-fre.
I figure if im putting this much effort into the paint job, the rest of the exterior better match up!
- 1983 FJ60 - 229K
Old 01-22-08, 05:28 PM   #43
5280Hawk's Avatar
Figured I better post an update,
fenders have the final coat of paint and sanding, I just finished w. the 2000 grit. I am starting buffing tonight.
Front doors will be next.
Also I got my new emblem and tail lenses. Photo -
- 1983 FJ60 - 229K
Old 01-28-08, 10:06 AM   #44
5280Hawk's Avatar
Progress!
Yesterday was beautiful here, 60 degrees out!
I got the fenders done yesterday and took the tarp off and pulled the 60 out to remove the front Doors,
Im getting rid of those Mirrors. They're the Man-a-fre Knock-offs, if anybody wants them.
- 1983 FJ60 - 229K
Old 01-28-08, 11:23 AM   #45
Project60's Avatar
T'was nice this weekend, nice progress! Sorry I haven't been by to see the truck... been busy working on the wife's projects.
If you haven't given them away, I'll take the mirrors... I need everything I can to keep my project cost down at this point .
Check out status of the build: http://forum.ih8mud.com/showthread.php?t=128847
Old 01-28-08, 12:25 PM   #46
5280Hawk's Avatar
Sure man,
When you come by you can pick them up.
- 1983 FJ60 - 229K
Old 01-31-08, 03:43 PM   #47
ColoradoLC's Avatar
ColoradoLC is on a distinguished road
Looks great hawk. I'm down in Centennial. Let me know if you need any more help with this any time. I'd be willing to trade help just to learn how to get the clearcoat on right. I have my own paint gun and compressor too.
Same color 60 for me as well. Where did you say you got your paint?
PM me if you are interested.
Winston
1986 FJ60 - Rear discs, JK Custom front bumper, 33x12.5 BFG ATs, Land Cruiser bottle opener and a whole bunch of other things. - For Sale!
1997 FZJ80 - Stock
ColoradoLC is offline   Reply With Quote
Old 02-02-08, 09:37 PM   #48
5280Hawk's Avatar
I had to order the "Sand" Rustoleum Color special from Home Depot. They had the "Smoke Grey" color in stock.
thanks for the offer by the way and the compliment. I have no clue about clear coat, unfortunately, as the Rustoleum doesn't require it.
More progress on the Doors tomorrow.
I almost had to get stitches last week when i cut my arm pulling off the clip that holds the lock cylinder in place. left a 1" gash on my Wrist.
- 1983 FJ60 - 229K
Old 02-03-08, 03:39 PM   #49
5280Hawk's Avatar
Started masking and Sanding the Front doors today before the big Game, I pulled the Door handles and locks and Masked all the trim. I also pulled the rest of the chrome trim.
Sanding mostly complete in this shot. I've been using a Black & Decker orbital sander, and 150 grit pads.
There were a couple tiny dings on the ridge of the door, now filled with bondo.
- 1983 FJ60 - 229K
Old 02-04-08, 07:30 AM   #50
Project60's Avatar
Sorry to hear about your wrist...
How long did it take to sand down the door that far with the sander?
Old 02-04-08, 08:02 AM   #51
5280Hawk's Avatar
About an hour for that much sanding. The dust gets everywhere!! When i am done with this I will have to pull everything out of my garage and wipe it all down.
- 1983 FJ60 - 229K
Old 02-04-08, 09:53 AM   #52
Project60's Avatar
That's what I was afraid of...
Old 02-14-08, 08:33 AM   #53
5280Hawk's Avatar
I got 5 coats of paint on the front doors now. Time for the second round of sanding - 800 grit this time.
The doors are so much easier than the Fenders were, just because there are co curves and only two really straight ridges to deal with.
I am dreading the rest of the Body once i get to that point. The Roof is soo Big!
One thing I'm wondering, I have a Dent in the roof that I want to try to Pop out from the inside. My roof liner is pretty shot so I was going to just pull it when i go to fix that dent. I won't be able to put a new liner back in for a while, Any reason that will be a problem???
- 1983 FJ60 - 229K
Old 02-14-08, 11:07 PM   #54
DocuDude is on a distinguished road
Looks nice. An inspiration to us all. I need to learn more about the JBweld
"The trouble with America is when the dollar only earns 6% over here, it gets restless and goes overseas to get 100%. Then the flag follows the dollar, and the soldiers follow the flag."
- Maj. Gen. Smedley Butler, USMC
87 60- Me- A MUD liberal. Impeach BUSH!
95 80- Wife
DocuDude is offline   Reply With Quote
Old 02-18-08, 06:23 PM   #55
Waiting on a Troopy!
TJDIV's Avatar
TJDIV has a little shameless behaviour in the past
good work. looking forward to seeing the finished product (as I'm sure you are).
Reminds me of a time this guy did a 45lv in durabak.
Genetics Load the Gun, Lifestyle Pulls the Trigger.
Classic Toyota
My Crazy Dog
Ride Squaw Valley
What are you "sinking" about?
