A friend recently bought a commercial soda blasting unit for stripping paint off military vehicles. I just had him blast my front clip and it turned out pretty well - at least now I can easily see what I need what needs work. In my opinion, the soda doesn't really do a very good job on rust. However a big restoration shop that does a lot of soda blasting told me that's what rust is left after soda blasting is solid, cleaner than it looks, and they epoxy prime right over it. I didn't have much rust on this so it won't take much additional effort to clean it up.
If anyone's interested in soda blasting let me know and I can put you in touch. He's mobile too. We're in east central Alabama.
Looks great. I need to do that with mine. Are you going to finish taking any left over rust off or prime over it? If he ever comes to south Ga. (Valdosta) let me know.
__________________ Finally found one thing I would trade my FJ40 for and she only weighs 7lbs15oz. Gotta find a FJ40 car seat!
Yes, I am going to take care of the rust issues. Some are just a matter of a quick hit with a roloc abrasive pad and others I'm thinking about hitting with a cheapy blasting pot I've got using worn out glass beads and other cabinet media that I've accumulated. Either way there's not that much to deal with and that will put it all down to white metal.
As far as glass is concerned - soda has no impact at all on the glass or the rubber gaskets. It would take off any paint overspray, crud, etc but will not etch the glass or chew up the rubber like other abrasives.
Soda blast will not warp metal; will not damage glass, chrome or rubber parts. You will not experience flash rust problems either. You do need to wash off the residue before you start any body work or paint work. Use Holdtight 102 (www.holdtight.com) after blasting with ANY MEDIA. Do not use water only, soap and water or vinegar and water as an after wash!
Soda blast does not damage metal and therefore does not dig in and eat rust. This is a good thing as you can blast an entire vehicle without the risk of damage - actually seeing where the good metal/bad metal is.
Looking for a local contractor or more information on soda blast? Visit www.ChesapeakeSodaClean.com or call 410-271-2652.
I have rear wheel fenders that have undercoating and rust problems. Can soda take off the existing undercoating ? Or should traditional sand blast take care of it?
Removing undercoating with soda blast - Sometimes it will and sometimes it won't. There are all kinds of undercoat out there and some is tough as nails. You just have to try it, but the nice thing is that soda blast is a cold process and no heat is generated and the coating will not get hot and just get pushed around. You can spend time on the metal without worry of warpage. I generally ask my customers to work on thick undercoat with a heat gun and putty knife to remove the thickness and then soda blast it. Hope that helps!
I am in the Seattle area, after reading this thread. I searched for soda blasting, there is a local moblie guy. But at 175.00 a hr and 3 hr min. I am still looking. I have a bantam trailer I want blasted.
posted about this also in the tool tech forum
have been thinking about soda blasting old paint + light rust since I read this a while back;
looking at the eastwood soda blaster.....http://www.eastwoodco.com/jump.jsp?itemType=CATEGORY&itemID=1310 anyone have any experience with it to remove paint?.......the info from eastwood also states can be used with other "Media" and there is an "abrasive kit" that comes with the soda blaster......... might be nice to soda blast paint then hit the rust with the "abrasive" kit.....it is pricey specially when factoring in the freight costs to Alabama; about 100$..............but the ability to soda and sand blast with the same system makes it very attractive to my inexpereinced eyes............TIA
Lou
