Old 03-30-07, 10:08 AM   #1
FloridaFJ80's Avatar
Mixing Paint for spray gun
I have a paint gun that came with my Air Compressor.. I want to paint the undercarriage of my 80 with some black paint: i wanted to know what I needed to do this, also how I would mix the paint, and any techniques on doing it correctly. This would be my first time painting with this gun. I am used to using the rattle can approach, but for this project i would like to use the spray gun...... Thanks
Frank
1992 FJ80 Semi-Stock
2008 Prado VX - Semi-Stock
305/70/17 Maxxis Bighorn M/T w/ 1.5 trim spacers
Safari Rack with Fogs
HIDs
Factory Digital Inclinometer/Compass
Rear storage system
Dual Battery Setup
On Board Air
FloridaFJ80 is offline   Reply With Quote
Old 03-30-07, 01:34 PM   #2
Texx's Avatar
Each brand/type of paint has it's own mixture. Your paint supplier can answer all thoes mixing questions. As long as you have a gun with two adjusments, one for width of pattern, and one for flow rate, just adjust it where you're happy. Try a throw away piece of cardboard or the like first.
world's cleanest 89 FJ-62, and a few parts... 85 xcab hilux 4x4 resto'ed, 67 XKE, 1500 Vulcan, 80 Fj40 restored 03 Tacoma TRD SR5, Suzuki DR350
ANYBODY BUT OBAMA!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Texx is offline   Reply With Quote
Old 03-30-07, 03:57 PM   #3
Isotel's Avatar
TLCA# 16898
This stuff comes premixed i dont see the need for a spray gun on the bottom of your truck
1976 FJ40 TBI350 700R4 D300 SOA Locked 37" PBR's Protected by REDLINE
Colorado Land Cruisers - Club
Redline Land Cruisers - Safety First
CrAwLoRadO.com - Just Check it out
Old 03-30-07, 07:45 PM   #4
Pytbool's Avatar
I use Rustoleum in a gun. Way faster!!!!!
'78 FJ55 - Rust, 2f, SM465, NP203, 3spd, FJ60 axles, SOA, 37s Runnin' soon....
Pytbool is offline   Reply With Quote
Old 03-31-07, 08:21 PM   #5
do they sell rustoleum paint... ????? that i can use with the gun????
Frank
HIDs
Rear storage system
Dual Battery Setup
On Board Air
Old 04-02-07, 11:38 AM   #6
FL cruiser's Avatar
You can buy Rustoleum at Home Depot for $8 a quart or just over $20 a gallon. Mixed with enamel reducer it can be sprayed though your paint gun.
For cheap paint, I like Krylon too. Drys faster. Costs about the same as Rustoleum. Needs to be thinned with laquer thinner. I found it at a hardware store.
If your budget allows and you want to use automotive grade paint, look for a single stage urethane with hardener. A generic will cost you around $50 a quart with hardner though.
81 HJ60 Costa Rica Cruiser
82 FJ60 Trail Rig. Convertible, 2F, H55, Toybox, SUA, 37" MTR's
83 JJ60. Daily driver, OME, 33's, 6.2 diesel, NV4500, WVO
http://mysite.verizon.net/sbutman1/LC.html
FL cruiser is offline   Reply With Quote
Old 04-02-07, 01:20 PM   #7
I will be checking out the rustoleum paint at home depot, is there a special mix for this with the enamel reducer???? I would like to use the spray gun... I think a quart would be enough for just the undercarriage.. or would i need more???
Frank
HIDs
Rear storage system
Dual Battery Setup
On Board Air
Old 04-03-07, 06:28 AM   #8
FL cruiser's Avatar
I'm not sure what the mixing ratio is. Not sure the label says either. You might have to experiment. Just keep adding reducer until it the spray quits spattering, but not too much to where it runs easy.
I only tried spraying Rustoleum twice. It stayed sticky forever and took days to dry. It could have been that cheap thinner was to blame. So if your at Home Depot and have a choice between mineral spirits and a good grade enamel reducer, get the better grade. A quart should be enough.
Maybe someone that sprays alot with Rustoleum can give better advice.
Steve
Old 04-03-07, 09:09 PM   #9
Thanks steve for the advice... I appreciate it... Will be checking it out when i get to home depot.
Frank
HIDs
Rear storage system
Dual Battery Setup
On Board Air
Personal Loan | Equity Release | 0 Credit Cards | Loans | Apply for Credit Card
