Me and my Big Wheel
no inline water filter cause this?
if i spray using a compressoer/air gun combo, will the water in the tank cause "fish eyeing"? for the longest time i have been thinking it was poor prep, but now im thinking its water?
anyone know __________________ cc------------- 76' fj40 camcrusier13 build threads the following are links, just click, go on try it Traction Bar Sliders Ram Assist Bumper Poison Spider Style Shackle Reversal Half Doors if your doing it im sure ive done it, need help just ask....... |
What's next?
Condensation is not you're friend. It was screwing with my primer job till I got a water seperator/filter.
__________________ '69 fj40 CSC#103 A dry heat still cooks a turkey |
Ramblin Wreck
At least put one of those little $2 disposable filters at the gun. Your line probably has condensation etc in it.
__________________ Bailey Quintrell '74 FJ40--37 Irocks-32 Bolt 'Locks-SM420-ARB-XD9000i-FJ60 PS-MetalTech Cage '93 FZJ80-DD-Part Time 4wd-locked-5" lifted-snorkel-bullbar-315 AT's '97 FZJ80 '98 UZJ100-OEM RR locker ΣΧ
Thanks Guys! I had that exact problem when I painted my bumpers. I'm going to paint them again and now I'll add a water filter before I do.
__________________ 2001 UZJ100 Land Cruiser ARB bar, OME lift (863's, N74L's), Slee diff drop, 295 BFG AT's, Slee step-sliders, Slee rear bumper, Husky liners, Hella 4000's My Featured 100 Thread |
Me and my Big Wheel
all i needed to know
Former Wheeler
A lot of fish eye is improper prep, specifically not getting the surface clean enough.
Your fingerprints can cause it. wax and grease remover, then do it again. |
They call me crazy88
go to napa and get a tac rag/and solution also
__________________ "how 'bout we sing 'kyles mom is a bitch' in E minor?"by OregonCruzer http://s237.photobucket.com/albums/f...13957_15_0.jpg http://s237.photobucket.com/albums/f...113957_1_2.jpg |
Prior to painting...clean with Prep Solv (PPG) or Pre Kleeno (RM) or similar, tack it off, run an in line filter and go. Make sure you don't have one of those inline air tool oilers (more than just a fish eye with one of those puppies). Fish eye additive may help if it persists (available at your auto paint supplier). More often, I've seen fisheyes from waxes, grease, oils, (generally the bad prep mentioned above) and occaisionally air born dust/schmootz coming from a heater kicking on during the painting...I hated that one.
__________________ 1)Wanda: I hate people. Do you hate people ? Henry: I don't. I just like it better when they're not around. |
A little write up from the BASF site....
On a freshly painted finish, craters (a.k.a. fisheyes, pinholes) appear when a contaminant that creates high surface tension prevents the paint film from flowing over it. As a result, the paint forms a ring around the contaminant, creating what looks like a circular indentation with raised edges. Sources of contamination that cause craters include: oils, fats, waxes, polishing and sealing compounds, airborne oils and waters, and many types of personal care items such as hairspray, deodorant and lotion. Only a very thorough chemical cleaning of the areas to be coated can prevent craters from forming. If craters have formed, sand away the contaminated topcoat layer, clean thoroughly, and apply a fresh layer of material. Alternately, a fisheye eliminator may be used to lower the surface tension and allow the paint film to flow over the contaminants. R-M makes two products designed to reduce the effects of silicone contamination. 809 Fisheye Eliminator Eliminates fisheyes without causing orange peel. Use in R-M Clearcoats only. Do not use in Diamont Basecoat or R-M Undercoats. Add 2 oz. per gallon of RFU clearcoat. 812 Stop Silicone Use in UNO-HD only. Do not use in Diamont Basecoat or R-M Undercoats. Add ¼ to ½ cap to one quart of RFU UNO-HD. Apply 1-2 very fine coats in the areas where fisheyes have formed. Allow solvents to evaporate between coats. Please be advised that these products should be used as a last resort, and only when a thorough cleaning of the substrate and spray equipment has not rectified the problem. If used, all equipment should be cleaned thoroughly with clean (virgin) solvent-based cleaner in order to reduce subsequent contamination. __________________ 1)Wanda: I hate people. Do you hate people ? Henry: I don't. I just like it better when they're not around. |
#10 |
Been there, done that, only to be told after the fact that you shouldn't use fisheye elminiator in catalyzed paint.
__________________ world's cleanest 89 FJ-62, and a few parts... 85 xcab hilux 4x4 resto'ed, 67 XKE, 1500 Vulcan, 80 Fj40 under resto..mine now! ! 03 Tacoma TRD SR5, Suzuki DR350 Born to raise Hell! Right after my nap. |
Credit Card Consolidation | Homeowner Loans | Loans | Credit Counseling | Pay Day Loans |
