TLCA HOME : BOARD & BYLAWS : EVENTS: MERCHANDISE : BUSINESSES : PHOTO GALLERY : CLASSIFIEDS
HISTORY : TOYOTA TRAILS : MEMBERSHIP : CLUBS : MISSING VEHICLES : LAND USE : CHAT : LINKS
Go Back   IH8MUD™ Forums > TLCAForum.com > Toyota Land Cruiser Association Forum > Clubhouse Corner > PA- Steel City Land Cruiser Club
Old 04-15-08, 08:28 AM   #1
pghfj40's Avatar
TLCA# 13361
She's Legal!!
A momentous occasion...
First PA inspection... ever, since I bought in in June '01.
'70 FJ40
pghfj40 is offline   Reply With Quote
Old 04-15-08, 08:50 AM   #2
pghfj40's Avatar
TLCA# 13361
I suppose I've done a few things in the meantime...
ENGINE:
- straight six 4.2L "2F" from 49k mi. 1978 Toyota Land Cruiser
- 6-1 headers
- custom 2.5" exhaust w/ 3-disc insert
- "Jim C." performance rebuilt carb
- electric fuel pump
- custom 20+ gallon under-bed stainless steel gas tank
TRANSMISSION:
- Muncie SM420 (early GM truck 4-speed w/ 7.1:1 granny gear)
- 3/4" xfer adapter to 3-speed transfer case w/ case saver
BRAKES:
- Toyota LC front disc brake conversion
- GM Monte Carlo rear disc brake conversion
- adjustable proportioning valve
POWER STEERING CONVERSION
- GM tilt column
- Borgeson slip shaft and joints
- GM saginaw box, pump
SUSPENSION
- custom SOA Spring-Over-Axle conversion
- Aqualu high-steer
- custom heavy-duty drag link
- custom CV long-slip driveshafts, .188 wall: front & rear
- UHMW slinky strips between leaf springs to reduce friction
- custom traction bar with tow hook
- polyurethane bushings all around
- greasable frame pins and shackle bolts
- shackle reversal
- lengthen wheelbase, front & rear
SHOCKS
- Bilstein 5125's: front 14" travel, rear 12" travel
- custom upper and lower mounts, front & rear
AXLES
- '78's w/ cryo-treated "Longfield" birfield joints
TIRES
- Super Swamper TSL Q78's (27/32depth, 35.5x10.8) on 15x8" AE589 aluminum rims
PROTECTION:
- custom front bumper 2x4x.25 steel w/ 1" thick D-ring recovery points
- gas tank skid plate
ON-BOARD AIR
- york 210 compressor
ELECTRICAL
- 120 Amp alternator: GM 17-SI
- all-new Centech custom wiring harness
- Weatherpak waterproof connectors
- custom 00 gauge welding wire in high current paths
- switch for vehicle lights to run as tow lights when flat-towed
- tachometer
- in-cab winch control
- in-cab compressor (OBA) control
- keyed front & rear fuel pickup selector switch
- starter button, can run in ACC mode too, to move w/out starting
SEATS
- Corbeau Baja SS
- 4 point harnesses (with standard seat belt latches)
ROLLCAGE
- custom 6-point, TBD: tied into frame
WINCH
- Ramsey REP8000
- mounting plate setup for flat-tow bar
ACCESSORIES
- Hi-Lift Jack: cast: 60"
- 8000 lbs. hand-winch
'70 FJ40
Old 04-15-08, 09:13 AM   #3
pghfj40's Avatar
TLCA# 13361
An old pic already...
Will be so good to get 'er painted one color, then it'll be more photogenic: will do, soon as it warms up a little more.
And the other "major" remaining items...
- get my CB installed.
- get my rear bumper/carrier built
- get my OBA tank(s?) installed & plumbed
- ARB's F&R, maybe 4.88s (want to drive more before deciding)
...but the list has finally become manageable and optional: a "hobby."
'70 FJ40
Old 04-15-08, 10:59 AM   #4
78Crusher's Avatar
TLCA# 15533
where is the other sticker?
I thought that penn hills was still in allegheny county therefore needs emissions sticker.
If its exept it still needs one right?
Anyway now you dont have to trailer it
"The world is full of kings and queens who will blind your eyes and steal your dreams." (RJD)
78Crusher is online now   Reply With Quote
Old 04-15-08, 11:08 AM   #5
pghfj40's Avatar
TLCA# 13361
I thought that penn hills was still in allegheny county therefore needs emissions sticker. If its exept it still needs one right?
Penn Hills hasn't moved: still in in Allegheny County. (though i wish it could move!)
It is exempt, but I don't know if it needs an "exempt" sticker?? My inspection guy said "it's a 70 so you don't need emissions," but now that you mention it... I'd rather be sure so I don't get ball-busted.
Guess I'll check into it further.
'70 FJ40
Old 04-15-08, 01:25 PM   #6
78Crusher's Avatar
TLCA# 15533
The "IM" above the month number will usually tip a cop off if the vehicle needs an emission sticker.
If the sticker has nothing above the month nuber you would not need a sticker but that would meen that you moved to a different county.
I am exempt due to not putting enofe miles on a year but I still have to have a sticker.
Year of the vehicle does not matter only if its got a classic or antique plate on it.
Old 04-16-08, 08:51 AM   #7
pghfj40's Avatar
TLCA# 13361
It has the "IM." I talked to the guy and he said it was the wrong insert, but that it happens all the time so NBD. He said that pre-76 it's all good.
My only remaining concern is it being PC to pull me over & pick at other things on the vehicle... oh well... happy to have what i got.
Gratuitous shot from the meeting last night (but hey it shows the sticker, so it's relevant to the thread, right?!)...
'70 FJ40
Old 04-26-08, 03:32 AM   #8
BURGH, Nice job on your FJ, looks great. Did you fab up your own gas tank or have someone build it? Moose
Bigmoose is offline   Reply With Quote
Old 04-28-08, 07:24 AM   #9
pghfj40's Avatar
TLCA# 13361
Thanks!
Had someone build it.
'70 FJ40
Old 04-29-08, 07:27 AM   #10
Zimm's Avatar
Location: i cant wait to get home and play with my *blank*
TLCA# 13760
Originally Posted by pghfj40 View Post
Thanks!
would you recommend the guy?
"a true Land Cruiser owner wouldnt delete a thread he is getting bashed in. He would take it and love it....."
NoaH
"my wife sleeps with NoaH". whodat
Zimm is online now   Reply With Quote
Old 04-29-08, 08:29 AM   #11
pghfj40's Avatar
TLCA# 13361
'70 FJ40
YOU MAY CONTACT US AT MEMBERSHIP@TLCA.ORG | (800) 655-3810 | PO BOX 230, VERONA, KY 41092
