TLCA.org
Go Back   IH8MUD.com > TLCAForum.com > Toyota Land Cruiser Association Forum > North American Clubhouses - East Region > PA- Appalachian Land Cruiser Association
LinkBack (16) Thread Tools Display Modes
Old 07-31-08, 06:34 PM   1 links from elsewhere to this Post. Click to view. #61 (permalink)
kb3gun's Avatar
TLCA# 17295
I got black (tan) lung trying to remove the bondo. LOL
I'll save them for you if you'd like. You can keep them for your next project. The only piece I'm keeping is the fuel filler opening. I'll graph that into the new skin.
Bill
Somerset, PA USA
2007 FJ Cruiser
1966 FJ40 :Buildup thread: Progress (or lack of) info here
Proud member of ALCA!
kb3gun is offline   Reply With Quote
Old 08-03-08, 04:53 PM   #62 (permalink)
kb3gun's Avatar
TLCA# 17295
Unfortunately, I could only work on the 40 on Saturday. Family reunion today...
It was a little more involved than I expected (nothing new). Worked for about 9 hours and I'm almost done prepping the passenger side quarter panel.
At this point, I had most of the sheetmetal (I mean sheet material, huh Sean ) I was able to save the inside fender top for a template for the outside support as seen in the next photo.
All I did was cut slots into the angle iron, bend to form the radius, and weld it up.
Here it is with the welds ground flat. I still need to make one for under the top rail.
These won't be welded in place until I have the new quarter panel tacked in place to ensure a good fit. The reason I'm making these is to have some thicker material to weld the quarter panel to. The angle iron will be tied together top and bottom and run down to the angle supports I have surrounding the underside of the tub.
I also added some 2" tubing to the vertical support at the bed opening.
I rough cut the fuel filler out of the old quarter and sandblasted it. I'll be graphing it into the new quarter once everything is mounted.
That's it. That was 9 hours. I didn't get far.
Now all I have to do is open up the radius on the new quarter a little and get it mounted. Will hopefully be done with it by Friday evening if I get off work early enough during the week.
I should be able to do the whole drivers side in one day with the lessons I've learned on this side. We'll see.
Till next installment.... See 'ya!
Bill
Somerset, PA USA
2007 FJ Cruiser
Old 08-03-08, 07:12 PM   #63 (permalink)
CJBury's Avatar
TLCA# 15636
Man, you're nuts. I like what you are doing. I'm gonna read every post but, you're nuts.
Chris
96 FZJ
ALCA
Wheel it till it's a buggy
CJBury is offline   Reply With Quote
Old 08-04-08, 07:52 AM   #64 (permalink)
kb3gun's Avatar
TLCA# 17295
Hey, if it was easy, everyone would do it. I like a challenge.
As far as being nuts, you'd have to ask my shrink about that...
Bill
Somerset, PA USA
2007 FJ Cruiser
Old 08-06-08, 05:49 PM   #65 (permalink)
kb3gun's Avatar
TLCA# 17295
Well, I got the panel in place. All I have left is to finish the bracing and get it welded in. Then on to the drivers side. Here are a couple of pics:
Fits pretty good.
Besides the bracing on the back side, I'm going to try and weld along the top to make it look like the original seam. This should be fun. Welding 16ga to 3/16" plate. Hope to get the welding done by COB on Friday.
I'll start on the other side after work on Saturday...
Bill
Somerset, PA USA
2007 FJ Cruiser
Old 08-07-08, 05:45 AM   #66 (permalink)
Wayneraintree's Avatar
TLCA# 9720
Looks good Bill!
Wayneraintree is offline   Reply With Quote
Old 08-07-08, 09:59 AM   #67 (permalink)
Lugboot's Avatar
TLCA# 17677
Bill, you get major props for this work. Amazing. Or, as I've seen elsewhere around this board, "Strong work." Keep it up.
Lugboot is online now   Reply With Quote
Old 08-08-08, 06:16 AM   #68 (permalink)
kb3gun's Avatar
TLCA# 17295
Thanks all. Got the supports in last night. It's welded in except for the very top along the rail. I'll get started on the other side tonight. Have a little tweaking to do before finalizing all the welds and that will be it with the tub.
Bill
Somerset, PA USA
2007 FJ Cruiser
Old 08-17-08, 06:07 PM   #69 (permalink)
kb3gun's Avatar
TLCA# 17295
Well, got a little more done today. I wish I had more time to spend on this thing...
Final welding of drivers side rear quarter:
Same, after grinding down the welds:
Another view welded:
Another view after grinding:
Rear welded:
After grinding:
Still need to fill in a few small places where I missed some tacks, but it's getting there. It's not easy welding the original metal (14-16GA) to 3/16" plate. It's getting easier as I go.
Here are a few of the sandblasted frame. I took the front shock towers/mounts off today (after taking this photo). Will start setting up the suspension next weekend if all goes well..
Till next time...
Bill
Somerset, PA USA
2007 FJ Cruiser
Old 08-17-08, 08:52 PM   #70 (permalink)
caz
caz's Avatar
Wish you had more time? Looks like you are flying along to me! I had mine for 3-1/2 years before I ever got to drive it!
Keep up the good work,
CAZ
caz is offline   Reply With Quote
Old 08-17-08, 09:03 PM   #71 (permalink)
kb3gun's Avatar
TLCA# 17295
Thanks Andy! 8 months seems like a long time. Now I need to figure out my shackle reversal, cut and turn and spring over. This will be uncharted territory to me. Worst I can do is do it wrong and have to do it over I guess.
Bill
Somerset, PA USA
2007 FJ Cruiser
Old 09-23-08, 06:25 PM   #72 (permalink)
kb3gun's Avatar
TLCA# 17295
Well, a little over a month has passed and I'm making a little headway. Parts are starting to trickle in.
Here are some current photos:
Got the springs outboarded, shackles reversed and springs flipped. Going to drill a new center hole in the springs to bring the axle back closer to the original location.
A little closer look at the rear hanger. Looks to be strong enough but I'll probably add a few gussets to it to be on the safe side.
View from the front. I just got the saginaw mounting plate for the drivers side and I'll be boxing the frame on this side.
I'll be adding a Traction Bar and I've been told that the cross-member isn't strong enough. So here is a photo of my plan. Tubing is 1-1/2"D x 1/4" wall (was a real bi#@h to bend with a Harbor Freight bender). Center supports are made out of the same. Outer plates are 1/4". Think it'll be strong enough?
Another angle...
Slight problem here. Having a hard time getting the springs to seat. May have to heat them a little.
I'm still waiting on some things from suppliers. Once I get the above spring perch ground down and get the axle slid under, I'll be dropping the engine in (temporarily) so I can get the pinion angles set. Then I will start the cut&turn.
I got a complete saginaw hardware kit from Kurt @ CruiserSolutions so I'm ready to go on that.
With everything in and measured, I'll be able to get my measurements in to 4x4Labs and get the highsteer kit on order.
Getting closer but still have a ways to go.
Bill
Somerset, PA USA
2007 FJ Cruiser
Old 09-23-08, 06:40 PM   #73 (permalink)
i wouldn't suggest trying to drill new holes in the springs, it'll be a major pita, destroy drill bits, and weaken the springs...just redrill your spring perches and ubolt plates, or leave it the way it is, it helps your approach angle and just looks better to have the springs flipped...otherwise, looks good
2002 vw jetta tdi
sidekick comp buggy
85 sr5 mini
95 zuk
zucruisers is online now   Reply With Quote
Old 12-12-08, 05:20 AM   #74 (permalink)
Lugboot's Avatar
TLCA# 17677
bumpity-bump-bump, bumpity-bump-bump...
Look at kb3gun go....
Update?
Old 12-12-08, 08:26 AM   #75 (permalink)
kb3gun's Avatar
TLCA# 17295
Been done for a couple of months now. Decided to do it again.
Work took over the project for awhile. Planning to get back to it over X-mas.
Bill
Somerset, PA USA
2007 FJ Cruiser
Old 01-30-09, 11:23 PM   #76 (permalink)
EWheeler's Avatar
Great work, have you made any progress on this thing? I am going to be tackling the same project here in a couple months (saginaw, outboarding for FJ60 axles, and replacing quarters) and will definitely be referring to your pictures for help. Thanks for posting them up
EWheeler is offline   Reply With Quote
Old 01-31-09, 06:18 AM   #77 (permalink)
kb3gun's Avatar
TLCA# 17295
Thanks EWheeler!
No real new progress yet. Very busy at work. Just some small things here and there. Just picked up a new plasma cutter last week (better late than never). Been a bit cold in the garage even with the heater the last few weeks. Once it gets back into the 20's, I'll get back at it. I'll be POR15'ing the frame and getting the tub back on next. Then dropping the engine back in (for the weight) so I can get the pinion angle set for the cut and turn. I'll wait till the engine is in before mounting the saginaw and cutting the hole thru the crossmember for the shaft.
On an other note: My FJCruiser lost some teeth on the rear ring so I'll be working on that for the next week or two (waiting on parts). 2.5 years old with under 18,000 miles. Dealer (Laurel Toyota of Johnstown, PA) denied warranty. Stated it was abuse from all my mudding?!? Last time I wheeled was at CMCC... in July. (if you don't count the snow and ice covering the paved roads in town) Did I mention the dealers name? Laurel Toyota (Also Laurel Scion and BMW) of Johnstown, PA.
Good luck on your project! It's been a blast so far. Just remember to take your budget for the rebuild, and double it. Well worth it in my book though. Make sure you start a thread on your build.
-Smitty
Bill
Somerset, PA USA
2007 FJ Cruiser
Old 01-31-09, 08:35 AM   #78 (permalink)
Old Fart
76FJ40's Avatar
TLCA# 8019
What was that dealer's name again?
'76 FJ-40 with a Hula Girl on the dash for me and a '65 FJ-45 LPB for the wife.
76FJ40 is online now   Reply With Quote
Old 01-31-09, 09:39 AM   #79 (permalink)
kb3gun's Avatar
TLCA# 17295
HaHa!
Laurel Toyota of Johnstown, PA. Part of the Laurel Auto Group.
Google bots, do your stuff!!
Old 04-29-09, 02:42 PM   #80 (permalink)
kb3gun's Avatar
TLCA# 17295
OK. What am I doing wrong?
The engine mounts aren't lining up. It's off by about 1/2". I can elongate the hole in the frame mount, but if I have something off, I'd rather not make it worse. If it looks right, let me know and I'll break out the drill.
View from center:
Right (drivers) side:
Left (passengers) side:
For those new to this thread, it's a 1982 2F going into a '66 frame.
Now, on another note, which way is UP on the motor mounts? One side has a stud (currently facing up but I only have a few threads showing. May be upside down) and the other side uses a bolt. The bolt side also has a small flange that wont allow the mount to fit flush with the frame mount.
These came with the '66. Looking at SOR, the style might have changed a little after 1980. Do I need different mounts?
Thanks all. Great way to spend a vacation day off from work!
Bill
Somerset, PA USA
2007 FJ Cruiser
Old 04-29-09, 02:55 PM   #81 (permalink)
kb3gun's Avatar
TLCA# 17295
Well, looking in the SOR catalog again, it seems that I have the '75-'80 style motor mount and I do have it upside down. Stud down, bolt up. The '80-'87 has studs top and bottom. I'm assuming that fitment will be an issue either way, so I think I'll just elongate the holes on both the left and right sides of the frame mounts and flip the motor mounts over while I'm at it. Project for tomorrow night I guess.
Bill
Somerset, PA USA
2007 FJ Cruiser
Old 04-29-09, 05:30 PM   #82 (permalink)
shmukster's Avatar
TLCA# 12019
motor mounts
Bill- stud down. bolt top all the time from my experience. bet you can't wait to wheel again, eh buddy??? Gonne be ready for Coal Mine? If not maybe the pig run? Gary S
78 FJ55
85 BJ70
95 FJ80
shmukster is offline   Reply With Quote
Old 04-29-09, 06:57 PM   #83 (permalink)
racefanmartin's Avatar
TLCA# 17538
Nice to see things are coming together on the 40...hope we see it at CMCC.
Matt
Fjcruiser: All-Pro lift,Dented Skids,All-Pro Bumper, Rubbed Rock Rails, Cobra 75 w/bandi ,315/75/16 kook's,Fourtreks, All-Pro lower links and shock skids. TRD cold air intake, Safari Snorkel, Warn M8000
ALCA, FJBruiser
"Why Drive A 4-Letter Vehicle When You Can Drive A 2-Letter One" mjm
racefanmartin is offline   Reply With Quote
Old 04-29-09, 08:59 PM   #84 (permalink)
kb3gun's Avatar
TLCA# 17295
Thanks guys. Yeah, got the mount figured out and did end up extending the mount holes. Fits good now. Have to lay out the transmission mount and get the holes drilled for that. It's coming along. Hope to have it ready for CMCC or at least on the road by that time. I'll be at CMCC even if it's just as a passenger. People ask how long till it's done. I tell them it will be done in about $3000. Low estimate I'm sure.
Still have some final body work on the tub once it's back on the frame, lockers (ARB front, aussie or lockright rear), need to get the Saginaw installed, 4x4 labs hi-steer setup, brakes, cut-n-turn, fab the front and rear bumpers, winch, full cage with frame tie-ins, skid plates, anti-wrap bar, paint and wiring. I have some 33" rubber for it, but am now thinking 35 or 37. Then to get it registered. Other than that, I'm about done.
Bill
Somerset, PA USA
2007 FJ Cruiser
Old 04-30-09, 05:27 AM   #85 (permalink)
Lugboot's Avatar
TLCA# 17677
Wow, so close to being finished!
Old 04-30-09, 06:19 AM   #86 (permalink)
jtaco1's Avatar
Looking good. When is CMCC this year?
JT
DD - 05 Toyota 4 Runner
Trail Rig - 88 4 Runner with dual cases w/ 4.7's, 35's and no lift
Was
99' Toyota Tacoma Crushed by Toyota
jtaco1 is online now   Reply With Quote
Old 04-30-09, 10:21 AM   #87 (permalink)
kb3gun's Avatar
TLCA# 17295
I didn't realize I had that much more to do until I started writing it down. I'm sure I missed a few things too...
July 9-11, 2009
Bill
Somerset, PA USA
2007 FJ Cruiser
Old 04-30-09, 12:27 PM   #88 (permalink)
caz
caz's Avatar
We need pictures!
Old 04-30-09, 01:14 PM   #89 (permalink)
kb3gun's Avatar
TLCA# 17295
I just posted 3 yesterday! What more do you want!?!
Bill
Somerset, PA USA
2007 FJ Cruiser
Old 04-30-09, 01:47 PM   #90 (permalink)
caz
caz's Avatar
I want "overall" pictures. Let's see that shiny engine and frame!
LinkBack to this Thread: http://forum.ih8mud.com/pa-appalachian-land-cruiser-association/193980-new-me-66-fj40.html
Posted By For Type Date
LONGEVITY PLASMA CUTTER REVIEW LP-40D --- A new tool for the project - FreeWeldingForum.com Welding Forum Community presented by LONGEVITY This thread Refback 11-06-09 07:47 PM
Cobra 75 WXST and Bandi Mount Install - Page 3 - Toyota FJ Cruiser Forum This thread Refback 11-05-09 06:53 AM
More calculators than you know what to do with... - FreeWeldingForum.com Welding Forum Community presented by LONGEVITY This thread Refback 10-29-09 10:17 AM
Welding Aluminum...How to with pics inside!!! - Page 2 - FreeWeldingForum.com Welding Forum Community presented by LONGEVITY This thread Refback 10-25-09 02:46 PM
40D Plasma and 16GA - FreeWeldingForum.com Welding Community presented by LONGEVITY This thread Refback 08-20-09 05:14 PM
FJ40 full quarter panel skins - Rising Sun Member Forums This thread Refback 08-17-09 08:46 AM
LP-40D --- A new tool for the project - FreeWeldingForum.com Welding Community presented by LONGEVITY This thread Refback 06-15-09 07:54 AM
cut through paint ok - FreeWeldingForum.com Welding Community presented by LONGEVITY This thread Refback 05-26-09 08:54 PM
More calculators than you know what to do with... - FreeWeldingForum.com Welding Community presented by LONGEVITY This thread Refback 05-26-09 07:12 PM
Hot weather welding/cutting protection - FreeWeldingForum.com Welding Community presented by LONGEVITY This thread Refback 05-07-09 06:57 PM
Ext. cord for mig. welder - FreeWeldingForum.com Welding Community presented by LONGEVITY This thread Refback 05-06-09 10:15 AM
Jeep Scrambler Project - Page 4 - FreeWeldingForum.com Welding Community presented by LONGEVITY This thread Refback 04-27-09 07:36 PM
Rule of thumb? - FreeWeldingForum.com Welding Community presented by LONGEVITY This thread Refback 04-26-09 04:10 PM
LP-40D --- A new tool for the project - Longevity-Inc.com Community This thread Refback 03-24-09 06:25 AM
longevity-inc.com Welding and Generator Forums • View topic - LP-40D --- A new tool for the project This thread Refback 02-20-09 08:51 AM
longevity-inc.com Welding and Generator Forums • View topic - Ext. cord for mig. welder This thread Refback 02-17-09 05:56 PM
CONTACT US AT MEMBERSHIP@TLCA.ORG
