TLCA.org
Go Back   IH8MUD.com > TLCAForum.com > Toyota Land Cruiser Association Forum > North American Clubhouses - East Region > PA- Appalachian Land Cruiser Association
Old 11-19-07, 08:31 AM   #1 (permalink)
jtaco1's Avatar
Cool JT's '88 4 Runner Build
Ok, I figured I would start a new thread for this. I picked up an 88 4 Runner with a blown 22re, it came with a 22r with 80k on it, so I am going to swap all of the accessories and EFI over to the 22r and put that in. I have, presumably, all the parts we need, but need some extra hands and know-how. I am currently cleaning up some of the parts since they have a good bit of oil and grime on them from the PO.
So if you would like to give me a hand at my place outside of Marysville on December 8, 2007, that would be awesome. I will provide pizza and beverages. Even if you just want to stop by and check it out.
JT
DD - 05 Toyota 4 Runner
Trail Rig - 88 4 Runner with dual cases w/ 4.7's, 35's and no lift
Was
99' Toyota Tacoma Crushed by Toyota
jtaco1 is offline   Reply With Quote
Old 11-19-07, 04:39 PM   #2 (permalink)
JT, care full what you ask for you may end up with a house full of free loaders looking for pizza and beer like me.
Good luck, sounds like a good time.
From experience put the food and bevs "under the engine" that will ensure it will get installed early.
bob
I cut this wire 3 times and it's still to short.
norville is offline   Reply With Quote
Old 11-19-07, 05:36 PM   #3 (permalink)
do you have a garage to work in?...it might be kinda cold to work outside
2002 vw jetta tdi
sidekick comp buggy
85 sr5 mini
95 zuk
zucruisers is offline   Reply With Quote
Old 11-19-07, 05:40 PM   #4 (permalink)
Wayneraintree's Avatar
TLCA# 9720
I need to clear it with Em but it sounds good.... I do think JT has it indoors as he kicked out his dad's 40 project ; )
JT, babysitter?
Wayneraintree is offline   Reply With Quote
Old 11-20-07, 06:49 AM   #5 (permalink)
jtaco1's Avatar
Yep got a 20x20 insulated garage, I can even fire up the kerosene heater if you like
JT
Was
Old 11-20-07, 06:58 AM   #6 (permalink)
jtaco1's Avatar
JT, babysitter?
I think Dana will be watching Addy, if your wife wants to come down, she is more than welcome and can hang out with Dana
Also does anyone have a clutch alignment tool for the 22re and a topshift t-case oil slinger??
JT
Was
Old 11-20-07, 06:59 AM   #7 (permalink)
jtaco1's Avatar
bob
You just gotta time the delivery of the food so that work still gets done Even if someone just wants to see how things work, that is cool with me, it can be a tech weekend for the club.
JT
Was
Old 11-20-07, 11:58 AM   #8 (permalink)
ive got a clutch alignment tool for the 22re
2002 vw jetta tdi
sidekick comp buggy
85 sr5 mini
95 zuk
Old 11-20-07, 12:07 PM   #9 (permalink)
jtaco1's Avatar
Excellent
JT
Was
Old 11-28-07, 09:15 AM   #10 (permalink)
jtaco1's Avatar
Ok, so far it look as though Jeff and John are planning on coming down, I also have another buddy from the Burwick area who is a Toyota Tech coming. Jeff and John, closer to the day, I will pm you directions to my place and anyone else that would like to come by. I have most of the parts swapped over to the 22r motor, have a few line that I have no real clue what they connect to yet, but hopfully will get that figured out or we can on the 8th.
One worrysome thing that happened when I was working on the 22r is when i pull the oil plug, some anti-freeze was in with the oil, I am really hoping that the original timing chain rubbed through and caused that, which has been replaced or when the PO was doing the timing chain and water pump it happened. I guess we'll see on the 8th or I'll be looking for another 22re for cheap.
JT
Was
Old 11-28-07, 01:18 PM   #11 (permalink)
Straydog's Avatar
TLCA# 16782
I'm planning on being there with the FSM in hand. When I did my timing chain I lost about a pint or so into the pan.
SEAN
Go outside and do that!
Straydog is offline   Reply With Quote
Old 11-28-07, 01:33 PM   #12 (permalink)
jtaco1's Avatar
Awesome, glad you can make it as well. Good to know about loosing some doing the timing chain, makes me feel a lot better. Plus the coolant was bright green and not mixed in with the oil and the oil was a little dark, but no water mixed in.
Would you recommend regular green coolant or Toyota red, I use the red in my Tacoma??
JT
Was
Old 11-28-07, 07:23 PM   #13 (permalink)
regular green ethylene glycol will be fine
2002 vw jetta tdi
sidekick comp buggy
85 sr5 mini
95 zuk
Old 11-29-07, 01:54 AM   #14 (permalink)
Straydog's Avatar
TLCA# 16782
The red is extended life? Otherwise just go green. using distilled water to keep corrosion to a min. is more important, in my opinion.
SEAN
Old 11-29-07, 06:49 AM   #15 (permalink)
jtaco1's Avatar
Sounds good, still have to pick some up along with some other stuff.
JT
Was
Old 11-29-07, 06:56 AM   #16 (permalink)
most supermarkets should have distilled water.
bob
Old 11-29-07, 05:15 PM   #17 (permalink)
kb3gun's Avatar
TLCA# 17295
Looks like I may have the 8th off. I'd like to stop by and lend a hand if you need it. It may give me some ideas for a new project. Can you PM an address? Need any tools?
-Bill
Bill
Somerset, PA USA
2007 FJ Cruiser
1966 FJ40 :Buildup thread: Progress (or lack of) info here
Proud member of ALCA!
kb3gun is offline   Reply With Quote
Old 11-29-07, 07:15 PM   #18 (permalink)
TLCA# 9720
Bill's got the pimp avatar: pimpin ALCA : )
Old 11-29-07, 09:02 PM   #19 (permalink)
kb3gun's Avatar
TLCA# 17295
Yeah... It was either ALCA-holic or ALCA-Haulin' A**. Now I need to find an ALCA-ho.
http://www.youtube.com/watch?v=68Z-7...eature=related
Bill
Somerset, PA USA
2007 FJ Cruiser
Old 11-30-07, 07:06 AM   #20 (permalink)
jtaco1's Avatar
-Bill
Great that you can make it, I'll shoot everone my address and some directions. As for tools, I have most of the hand tools that I think we would need, maybe bring your CO2 tank to run some air tools, not sure how much CO2 I have left in my 20# tank, if we need it.
Too bad I don't have my dual case adapter yet, with the number of people that know what they are doing, we could have the engine swapped and duals installed by lunch
Thanks guys.
JT
Was
Old 11-30-07, 09:02 PM   #21 (permalink)
kb3gun's Avatar
TLCA# 17295
I have atleast 10# left in mine. Need any air tools?
Bill
Somerset, PA USA
2007 FJ Cruiser
Old 12-01-07, 03:10 PM   #22 (permalink)
jtaco1's Avatar
I have the basics, but more can never hurt, plus we will need a timing light to set the timing I would assume and any other toools usually used to swap and engine along with clutch and flywheel. Thanks.
JT
Was
Old 12-01-07, 09:24 PM   #23 (permalink)
Straydog's Avatar
TLCA# 16782
I'll throw my air compressor(40gal) in the back with the big impact, clutch alignment tool, FSM, and anything else I can think of. Do we need a hoist? Engine stand? Beer ? Dancing girls?
SEAN
Old 12-02-07, 09:18 AM   #24 (permalink)
yep...those are a must have
2002 vw jetta tdi
sidekick comp buggy
85 sr5 mini
95 zuk
Old 12-03-07, 06:30 AM   #25 (permalink)
jtaco1's Avatar
Got an engine hoist and stand.
Should I just go ahead and get the dual case adapter so we can put that in as well
If anyone else has work they need done, we can do some as well, we should have about 7-8 guys that have some pretty good know-how.
JT
Was
Old 12-03-07, 07:17 AM   #26 (permalink)
CJBury's Avatar
TLCA# 15636
I am really bummed that I'm gonna miss this tech day. Hope all goes well for you fellas.
Chris
96 FZJ
ALCA
Wheel it till it's a buggy
CJBury is offline   Reply With Quote
Old 12-03-07, 09:23 AM   #27 (permalink)
if you really want a dual case adapter i have one i might sell
2002 vw jetta tdi
sidekick comp buggy
85 sr5 mini
95 zuk
Old 12-03-07, 09:31 AM   #28 (permalink)
jtaco1's Avatar
Please tell me more, I am going to get a Trail Gear one eventually, but if you have one, we could do that as well Satuday, maybe. I already have another top shift t-case to use.
JT
Was
Old 12-03-07, 10:43 AM   #29 (permalink)
the one i have is a trail gear adapter, i bought a complete drivetrain for my buggy project(rebuilt 22re, g52, dual cases, and 4.7's in the rear case), as of right now, the trans/tcases are all assembled, only reason i want to sell it is because i want to lower my drivetrain as much as possible and still have a flat belly skid, so i want to order marlin's clocked adapter
i was kinda thinking of waiting until i get the marlin adapter and installed, so i dont have my tcases opened up for long, if you want it, you can have first dibs, but i dont know if i'll even have a chance to pull it apart this week
2002 vw jetta tdi
sidekick comp buggy
85 sr5 mini
95 zuk
Old 12-03-07, 11:08 AM   #30 (permalink)
TLCA# 9720
awe just pull it JT would be stoked and it might light the fire you've been missing from under your arse to get some shit done
...and make room for my mini
CONTACT US AT MEMBERSHIP@TLCA.ORG
