TLCA.org
Go Back   IH8MUD.com > TLCAForum.com > Toyota Land Cruiser Association Forum > North American Clubhouses - East Region > PA- Appalachian Land Cruiser Association
Old 03-19-08, 07:52 AM   #121 (permalink)
jtaco1's Avatar
Got my new front brake line today, 36" stainless braid with nylon sleeve, bolts into the hard line junction and the V6 caliper. They are from Techna-Fit out in California, and cost less than $45 for the pair with shipping. Just gotta run down and get another stock rear line to double up the rear one.
Gonna have brakes soon
Then I'll swap in the elocker Tacoma rear later next month, just gotta figure out the ebrake setup since it is a little different from the 4 Runner.
JT
DD - 05 Toyota 4 Runner
Trail Rig - 88 4 Runner with dual cases w/ 4.7's, 35's and no lift
Was
99' Toyota Tacoma Crushed by Toyota
jtaco1 is online now   Reply With Quote
Old 03-20-08, 01:43 PM   #122 (permalink)
jtaco1's Avatar
Ordered up a front spring hanger setup today for the SAS, just a few more parts and I'll have everything for that project when it comes, gotta tear the axle apart and what not.
JT
Was
Old 03-20-08, 03:32 PM   #123 (permalink)
jt i think i have an extra pair of ford shock towers if you'd be interested in them for when ya do the sas
2002 vw jetta tdi
sidekick comp buggy
85 sr5 mini
95 zuk
zucruisers is offline   Reply With Quote
Old 03-20-08, 06:59 PM   #124 (permalink)
Wayneraintree's Avatar
TLCA# 9720
and I have nothing but encouragement for ya : )
your runner will be perfect with a SAS! refesh me on the springs you used?
Wayneraintree is offline   Reply With Quote
Old 03-21-08, 06:45 AM   #125 (permalink)
jtaco1's Avatar
Sounds good, I was planning on using the Ford mounts anyway.
I will be using rears up front, I picked up a set of 85 rears with the front axle and use the ones off the Runner. For the rear I am getting a set of 56" chevys and may also run a buggy spring.
Gotta find someone getting rid of their Hysteer setup for a decent price yet and some other stuff to rebuild the axle.
Also ordering my BudBuilt crossmember with drivetrain lift today, so that can go in after the body lift.
JT
Was
Old 03-24-08, 05:36 AM   #126 (permalink)
Lugboot's Avatar
TLCA# 17677
Hey, JT, I wonder if I can use the rear shaft off your Tacoma for my front driveshaft?
Brett
Lugboot is offline   Reply With Quote
Old 03-24-08, 06:04 AM   #127 (permalink)
jtaco1's Avatar
I would have given it to you, but Toyota says the Tacoma has to be able to be moved around under its own power, so I gotta keep it :( I am keeping an I out for some others for you.
JT
Was
Old 03-24-08, 07:02 AM   #128 (permalink)
Lugboot's Avatar
TLCA# 17677
I figured there'd be some rule like that but it didn't hurt to ask! Thanks!
I've decided to go the Taco drive shaft route instead of buying a new one.
Old 03-24-08, 08:00 AM   #129 (permalink)
jtaco1's Avatar
I would have loved to strip everything from the Tacoma, but trying to stay within the rules. Like I said, I will keep an eye out.
JT
Was
Old 03-28-08, 12:41 PM   #130 (permalink)
jtaco1's Avatar
Well the BudBuilt showed up yesterday and the front spring hanger and frame sleeves showed up today, just need high steer and an axle rebuild kit and we are ready to go with the SAS. Gonna finish the brakes over the next week or two and body lift on the 12th, then we'll hit the trail wth IFS until the fall and then start the cutting, by then i should have everything else and have the axle rebuilt and can put the rear TRD axle in as well
JT
Was
Old 03-31-08, 12:59 PM   #131 (permalink)
jtaco1's Avatar
Well, I got lucky and found a new, never used high steer setup for a great price, so that should be here next week. Now if I can unload some more Tacoma parts, I will have everything for the 4 Runner
JT
Was
Old 04-08-08, 12:14 PM   #132 (permalink)
jtaco1's Avatar
New high steer kit came today with a new pitman arm, so that will be ready to install soon. Going to be doing the brakes tonight and maybe the body lift and crossmember this weekend. Hope to have it ready for the trail ride next weekend.
JT
Was
Old 04-08-08, 12:48 PM   #133 (permalink)
TLCA# 9720
GET IT!!!!!
Old 04-09-08, 07:26 AM   #134 (permalink)
jtaco1's Avatar
Well brakes are in, they are better than before, but still not great, I think the rear brakes aren't adjusted right or something, so once I get the Tacoma axle for it this weekend, I am going to thrash to get it installed, since I know the brakes are good on it. Also finally got to take it for a spin, does pretty good. Hopefully I can get everything finished this weekend and during the next week to make it for the monthly ride.
Jeff you running the Mini or the FJ60 next weekend??
JT
Was
Old 04-09-08, 09:59 AM   #135 (permalink)
TLCA# 9720
Likely the 60 or riding along... the mini is coming along but not within reason to get it done before the 19th... : (
Old 04-18-08, 07:54 AM   #136 (permalink)
jtaco1's Avatar
Well we had a jamb packed day on Saturday. Got everything swapped over to Jeremy's Tacoma and I got his 4.10 rear e locker axle. Also got my 1" body lift on. Last night I got a some time to install the BudBuilt crossmeber and skid plate, all I can say is BEEF. Have a bout 16-18" under the t-case with 35's on. Frame height is at about 20" as well.
Now the bad news, the Tacoma axle needs some major attention :( Was hoping to just bolt it in, but looks like I need to do a major cleanup on the brakes, both axle seals were blown. Got the seals to fix it, now just need to clean up the huge mess that is in the backing plates and maybe replace the rear drums. Should be able to get it all back together this weekend and then modify the e-brake setupfrom the 4 Runner to work with the Tacoma axle, since it is wider. Probably just lengthen the stock e-brake cables for now. Also since I don't want to re-do the brake hard lines, my rear brake hose is going to be pretty long since the soft line connection is on the drivers side of the axle and is on the passenger side of the frame. May get a custom stainless line from the place I got my front lines from, since they are cheap and great quality.
Just going to run the stock axle for now until I get everything worked out with the Tacoma axle. Defiantely going to make the next trail ride in May.
JT
Was
Old 04-18-08, 10:53 AM   #137 (permalink)
why dont you flip the two pieces of hardline on the taco axle so that the soft line junction is on the right side?
2002 vw jetta tdi
sidekick comp buggy
85 sr5 mini
95 zuk
Old 04-20-08, 03:38 PM   #138 (permalink)
jtaco1's Avatar
I had planned to do that, but the hard lines on a Tacoma rear have a bunch of weird bends in them, so it won't work. I may cut the hard line junction off and relocate it to the crossmember and then splice in some additional hard line, so I don't have such a long soft line. Pretty much put the junction in teh middle of the frame.
JT
Was
Old 04-29-08, 09:44 AM   #139 (permalink)
jtaco1's Avatar
Got my sliders welded up on Friday afternoon and painted, just have to weld them to the truck now, probably some evening this week. Got the Tacoma rebuilt and that is ready for install. For the brake line, I am just going to modify the hardline on the frame and bring it over to the middle of the tubular crossmember and run the soft line from there. Should work well. I am also going to lengthen the stock 4 Runner ebrake cable to work with the axle. Just placed an order for the Off Road Solutions stand alone elocker wiring harness, so that should be here soon and be ready for the 17th.
Once I get the axle swapped in and put on different tires on it, I am going to get it inspected, so hopefully by the 17th it will be a state inspected and insured rig
JT
Was
Old 05-01-08, 06:49 AM   #140 (permalink)
jtaco1's Avatar
Quick picture in the garage. Still gotta paint the front fenders and what not.
JT
Was
Old 05-05-08, 08:01 AM   #141 (permalink)
jtaco1's Avatar
Got the sliders on 95%, ran out of welding wire on the passenger side so I still need to finish that off. Got the Tacoma elocker rear axle in, it realy isn't much wider, but the locker will be nice. Need to weld the ebrake pivot point to the axle and it will be done. Probably going to put the stock rear bumper back on to get it through inspection until I build one. With any luck I may also have a trailer for the upcoming ride on the 17th, planning on heading up on friday and camping.
JT
Was
Old 05-08-08, 06:37 AM   #142 (permalink)
jtaco1's Avatar
Well I stayed out in the shop until about 3:30 this morning trying to get everything done. Well other than some new wiper blades for the front and putting smaller tires on it, it is ready to get inspected. Got it registered and insured yesterday, only $300 a year, not too bad. The only part that I am waiting for is my ORS Elocker harness, hopefully that gets here early next week, but I have a feeling it won't be in in time.
JT
Was
Old 05-08-08, 12:20 PM   #143 (permalink)
OffRoadSolutions's Avatar
JT, Im pushin to try and get it done for ya! I can't promise anything since we have quite a few harness orders in front of ya, but I am trying I will let you know once it gets shipped!
~Una
Off Road Solutions
Arvada, CO
303-278-6267
www.offroadsolutions.com
Offering offroad products, engine conversions & custom fab work for your Toyota (& much more...)
[sigpic][/sigpic]
OffRoadSolutions is offline   Reply With Quote
Old 05-08-08, 01:09 PM   #144 (permalink)
jtaco1's Avatar
Wow, Thanks, I really appreciate it. For anyone that needs Toyota stuff, Off Road Solutions has been great to work with thus far, will definately be gettting more stuff from them in the future
JT
Was
Old 05-11-08, 05:45 PM   #145 (permalink)
jtaco1's Avatar
Well the truck had a major set back today, was driving it to the shop to get inspected and something in teh engine let go, not sure yet, haven't had time to tear it down. Looking for a 22re now :( So it doesn't look like I will make it to Rausch with it this weekend.
JT
Was
Old 05-12-08, 06:32 AM   #146 (permalink)
TLCA# 9720
WTF!? that is pure bad luck...
Old 05-12-08, 09:30 AM   #147 (permalink)
Glad we could help. Really sorry to hear about the bad luck tho, that blows.
Off Road Solutions
Arvada, CO
303-278-6267
[sigpic][/sigpic]
Old 05-12-08, 10:41 AM   #148 (permalink)
that sucks man, check compression if ya can, and check timing too, maybe the chain let go...are you sure it was something internal and not the computer or a sensor?
2002 vw jetta tdi
sidekick comp buggy
85 sr5 mini
95 zuk
Old 05-12-08, 01:39 PM   #149 (permalink)
how did it die? slow or fast? did it make bad sounds? be as specific as you can and well get it going.
Andy
98 Taco-
lifted 3" on 31" BFG at's
Well armored and now e-locked!
jamarquardt22 is offline   Reply With Quote
Old 05-12-08, 02:11 PM   #150 (permalink)
jtaco1's Avatar
Yeah it does suck, haven't had time to check it out yet, but was driving it up a slight incline in 4th gear, it started to loose power so I went down to 3rd, loosing more power, then 2nd and then pulled into someones driveway to get it off the road and it died. Went to fire it again, and it turned over fire, but stumbled really badly an kinda ran but then died again. Now can't get it to really fire at all, don't want to bend any valves. No irregular smoke or noises, my wife was behind me the entire time and said that she saw nothign out of the ordinary. It did make a small bang when I started it, kind of like it popped out of gear, but I had the clutch in. Not sure. Gonna pull the valve cover to see if I have a timing chain still. Maybe get lucky and just have to change that out, figures since that is the one thing we didn't do to it.
JT
Was
CONTACT US AT MEMBERSHIP@TLCA.ORG
