TLCA.org
Go Back   IH8MUD.com > TLCAForum.com > Toyota Land Cruiser Association Forum > North American Clubhouses - East Region > PA- Appalachian Land Cruiser Association
Old 12-03-07, 11:26 AM   #31 (permalink)
jtaco1's Avatar
Originally Posted by zucruisers View Post
the one i have is a trail gear adapter, i bought a complete drivetrain for my buggy project(rebuilt 22re, g52, dual cases, and 4.7's in the rear case), as of right now, the trans/tcases are all assembled, only reason i want to sell it is because i want to lower my drivetrain as much as possible and still have a flat belly skid, so i want to order marlin's clocked adapter
i was kinda thinking of waiting until i get the marlin adapter and installed, so i dont have my tcases opened up for long, if you want it, you can have first dibs, but i dont know if i'll even have a chance to pull it apart this week
Well, let me know, cause if I order today or tomorrow, I can have a Trail Gear setup to my office by Friday. What are you asking for it?? I couls also just get the front crawl box and adapter setup from you and give you one of my other cases for ease of removal and install.
JT
DD - 05 Toyota 4 Runner
Trail Rig - 88 4 Runner with dual cases w/ 4.7's, 35's and no lift
Was
99' Toyota Tacoma Crushed by Toyota
jtaco1 is offline   Reply With Quote
Old 12-03-07, 11:26 AM   #32 (permalink)
jtaco1's Avatar
Originally Posted by Wayneraintree View Post
awe just pull it JT would be stoked and it might light the fire you've been missing from under your arse to get some shit done
...and make room for my mini
Win Win situation
JT
Was
Old 12-03-07, 11:57 AM   #33 (permalink)
jtaco1's Avatar
Oops, looks like the crawl box you have is for a forward shift tranny, I have a W56 and need a top shift, looks like I would need just the adapter and associated parts.
JT
Was
Old 12-03-07, 12:51 PM   #34 (permalink)
blah blah blah...the zuk will be movable today or tomorrow, just not done yet...i'll have room for the mini soon enough
besides, selling the adapter just means more work for me to do, and more $ to spend too
and yeah jt my front case is a forward shift, if i were to post the adapter for sale i was going to ask for $300 shipped, the parts were installed, and have never been ran once yet, would $275 work for ya?...if you really want it before this weekend i'll make the time to get it pulled apart...ill just have to place my order with marlin sooner than i was thinking
2002 vw jetta tdi
sidekick comp buggy
85 sr5 mini
95 zuk
zucruisers is offline   Reply With Quote
Old 12-03-07, 12:57 PM   #35 (permalink)
jtaco1's Avatar
I can do $275 if we want to install it Saturday as well, it is 21 spline correct? Don't want you to kill your self though if you have more pressing stuff.
It would be sweet if we could get the engine swapped and install dual cases, just hope the engine going in doesn't have any issues and we can gettting running well. Probably wouldn't take too long to swap in duals with the number of people.
JT
Was
Old 12-03-07, 01:07 PM   #36 (permalink)
yeah its 21 spline, and its not that big of a deal, the only thing i have to do this week other than work in the shop is go hunting..i have a couple cages i'd really like to get done and outta the way, but if i dont its no big deal
2002 vw jetta tdi
sidekick comp buggy
85 sr5 mini
95 zuk
Old 12-03-07, 01:19 PM   #37 (permalink)
jtaco1's Avatar
Ok John, if it isn't too much trouble, I'll take it for Saturday and hopefully we can install it too. Probably just re-weld the stock shafts or I can tackle that later depending on time.
I guess we will need any of the required/special tools for a dual case install as well.
JT
Was
Old 12-03-07, 03:18 PM   #38 (permalink)
Wayneraintree's Avatar
TLCA# 9720
So what time are you planning to start JT?
I will be bringing a pack and play for Eva to nap around noon in a room if ya have a room she can use. This assumes we are starting in the AM.
Wayneraintree is offline   Reply With Quote
Old 12-03-07, 05:43 PM   #39 (permalink)
kb3gun's Avatar
TLCA# 17295
Can I bring my "Pack and Play" too. I could go for a nap around noon time...
Earliest I can be there is about 7:30 if I leave here at 5:30AM. Hopefully the turnpike will be clear by then.
See you all Saturday!
Bill
Somerset, PA USA
2007 FJ Cruiser
1966 FJ40 :Buildup thread: Progress (or lack of) info here
Proud member of ALCA!
kb3gun is online now   Reply With Quote
Old 12-04-07, 06:36 AM   #40 (permalink)
jtaco1's Avatar
Yeah, Eva can sleep in Addy's room , Addy usually goes down around 11:00 or so and is out for about 2 hours, so that should work out well.
As for starting time, I will be in the shop probably between 7 and 7:30 to fire up the heater so it isn't too cold I was out there last night without the heat and it wasn't bad at all. So pretty much whenever you want to show up, but I would imagine the earlier the better incase of any issues.
JT
Was
Old 12-04-07, 06:45 AM   #41 (permalink)
jtaco1's Avatar
Whatever time works best for you, but 7:30 should be good.
JT
Was
Old 12-04-07, 12:56 PM   #42 (permalink)
jtaco1's Avatar
So you will be able to bring all of the following for the adapter:
Dual Adapter Parts List:
21 Spline coupler
Adapter plate with bearings installed
Bearing spacer
11 Studs and nuts
Drain plug
Rear transmission output seal
2.28 Shift knob
Snap Ring
Shifter keystock
Detent plug
Three paper gaskets
I have most of the tools for the install except for a 30mm socket, gear puller, 3/16 Diameter Pin Punch and snap ring pliers
JT
Was
Old 12-04-07, 01:07 PM   #43 (permalink)
21 Spline coupler
Bearing spacer
11 Studs and nuts
Drain plug
2.28 Shift knob
Snap Ring
Shifter keystock
Detent plug
Three paper gaskets
ill pull it apart tonight or tomorrow, i should have almost everything, as its all installed
i wont have the output seal, i'd assume its in my trans, and hopefully i have the shift knob, its probably in my box of toy parts...and the gaskets should still be good, the shifter keystock is tacked on my shifter rail, it's just a tiny piece of metal, i can make one if ya need me to
i have a 30mm socket i can bring, and snap ring pliers, i might have a pin punch too
2002 vw jetta tdi
sidekick comp buggy
85 sr5 mini
95 zuk
Old 12-04-07, 01:19 PM   #44 (permalink)
jtaco1's Avatar
Is the output seal 100% necessary?? I have metal that we can make a new keystock from.
Sorry to be a pain, I tend to over analyze things and be a little OCD
JT
Was
Old 12-04-07, 02:08 PM   #45 (permalink)
no the seal's not necessary, just a replacement just in case the original gets messed up removing the case, most of the time it doesnt need replaced...im sure napa could get one if ya really want one
2002 vw jetta tdi
sidekick comp buggy
85 sr5 mini
95 zuk
Old 12-04-07, 02:13 PM   #46 (permalink)
jtaco1's Avatar
I'll get one anyways just in case we have any issues I can always return it or keep as a spare. Thanks
JT
Was
Old 12-07-07, 07:30 AM   #47 (permalink)
jtaco1's Avatar
Alright picked up the final parts this morning, so we should have everything, I hope. Picked up a tranny rear output seal, rear main engine seal, cap, rotor, plugs, upper and lower radiator hoses, and gear oil for the tranny and transfer cases.
For the new engine we will have the oil pump and crank pullies to install, some vacum lines and the damn coolant bypass hose that I can't figure out where it goes :( rear main seal, flywheel, clutch and TO bearing.
22re Engine is pretty much ready to pull, unbolt the motor mounts and tranny bolts. Figure out what we want to do with the exhaust, you'll see when you get there, but nothing bad, pretty easy actually. Once that's done the engine is ready to come out.
For the dual cases, I have a good complete topshift case that I want to use for the rear case instead of the one in the truck, we can use that one for the crawl box. I haven't done anything with the tcases yet, but it shouldn't be too bad to get out just a little crammped since the truck is on 28" tires. We can shorten the rear 2 piece shaft to make it work until I build a new front and rear shaft out of 2.5" Schedule 40.
Anyone think of anything else?? Thanks again.
JT
Was
Old 12-07-07, 07:31 PM   #48 (permalink)
sounds like you've pretty much got it covered, i'll bring some random extra parts just in case...would you be interested in a header for it?
oh and btw jeff might not make it because eva is kinda sick i guess, he wasnt really sure, but i'll be there as soon as i can
2002 vw jetta tdi
sidekick comp buggy
85 sr5 mini
95 zuk
Old 12-08-07, 04:58 PM   #49 (permalink)
TLCA# 9720
SOrry I could not make it JT! Eva has something and I thought not to share : )
Old 12-08-07, 07:12 PM   #50 (permalink)
Straydog's Avatar
TLCA# 16782
Yeah, yeah, its always something.
SEAN
Go outside and do that!
Straydog is offline   Reply With Quote
Old 12-08-07, 08:19 PM   #51 (permalink)
if you wouldve came i'd be $160 richer right now
the f'n tracker broke down on the way home for now apparent reason, called triple A, had it towed home...oh well, shit happens, and JT's engine is in along with dual cases...not running yet, but almost there
2002 vw jetta tdi
sidekick comp buggy
85 sr5 mini
95 zuk
Old 12-09-07, 09:12 AM   #52 (permalink)
TLCA# 9720
John that really stinks! I thought AAA would be cheap not the opposite
What all did you guys accomplish?
Old 12-09-07, 10:03 AM   #53 (permalink)
we got the old engine pulled, pulled the tranny out, got the new engine ready, assembled the dual cases, dropped the new engine in, and put the tranny/tcases back in, i think JT has a little bit of the wiring to plug in, install the radiator/starter and battery, and cut a hole in the floor for the 2nd tcase shifter/reinstall the shifters...that should be about it
2002 vw jetta tdi
sidekick comp buggy
85 sr5 mini
95 zuk
Old 12-09-07, 05:26 PM   #54 (permalink)
kb3gun's Avatar
TLCA# 17295
It was a good day overall. Pizza was good. Donuts were good. Beer was good. Working on the 4runner was a good learning experience. (Note to self.... buy a few more 14mm wrenches & sockets.)
I had fun. Can't wait to see it on the trail!
I'll post the pictures after work tomorrow.
Bill
Somerset, PA USA
2007 FJ Cruiser
Old 12-10-07, 06:51 AM   #55 (permalink)
jtaco1's Avatar
What a day, I can't say enough about the guys that came down to help out I owe all of you big time, I would still be pulling the engine if not for you guys John prety much summed up what is left to do and there is a little bit of other stuff. Hopefully I can sneak off and get some things done over the next few weeks plus the upcoming vacation for X-mas will help me with trying to get the truck on the trails for the run at the end of the month.
The only issue that I have at the moment is from looking at the front driveshaft position is that it looks like it may not clear the tranny crossmember?? Have to do some mockup and measuring to see, soon enough.
John that sucks about your ride home, wonder what happened.
JT
Was
Old 12-11-07, 07:00 PM   #56 (permalink)
kb3gun's Avatar
TLCA# 17295
Here are the pics I took.
Bill
Somerset, PA USA
2007 FJ Cruiser
Old 12-12-07, 01:19 AM   #57 (permalink)
Straydog's Avatar
TLCA# 16782
JT was a terrific host, with good food and tasty beer. Just need to get a little more heat in that garage.
SEAN
Old 12-12-07, 06:25 AM   #58 (permalink)
jtaco1's Avatar
I have another heater at the cabin, just didn't bring it down, may put an infrared heater in as well that runs on propane, but I gotta clean out a bunch of crap first.
Hoping to get some work done on it Saturday morning before we go do some x-mas shopping, mainly the remaining bolts for the engine, starter, fan, and wire harness.
Maybe I'll get some more tools for x-mas so things go easier next time
JT
Was
Old 12-12-07, 06:32 AM   #59 (permalink)
Lugboot's Avatar
TLCA# 17677
Looks like you guys were productive--awesome! Wish I could've been there.
Lugboot is offline   Reply With Quote
Old 12-12-07, 07:04 AM   #60 (permalink)
jtaco1's Avatar
I was very surprised at all that we got done and everyone that showed up made for a great team.
Now we gotta come up with a name for the project. thinking something along the lines of cheap since this is an extremely cheap build.
JT
Was
CONTACT US AT MEMBERSHIP@TLCA.ORG
