TLCA HOME : BOARD & BYLAWS : EVENTS: MERCHANDISE : BUSINESSES : PHOTO GALLERY : CLASSIFIEDS
HISTORY : TOYOTA TRAILS : MEMBERSHIP : CLUBS : MISSING VEHICLES : LAND USE : CHAT : LINKS
Go Back   IH8MUD™ Forums > TLCAForum.com > Toyota Land Cruiser Association Forum > Clubhouse Corner > PA- Appalachian Land Cruiser Association
LinkBack (4) Thread Tools Display Modes
Old 12-04-07, 01:43 AM   #31
Straydog's Avatar
TLCA# 16782
I have an IFS front end laying out here. And you are going to be down on Sat. I can pull it and bring it along.
Oh goody, more work out in the cold. Global warming my ass.
SEAN
85 extra cab
Go outside and do that!
Straydog is offline   Reply With Quote
Old 12-04-07, 11:09 AM   #32
lol...its only 6 little bolts...ya dont even have to pull the whole hub
97 3500 dually cummins
72 fj40/tube chassis, in progress
83 lwb minitruck..needs work
85 sr5 mini, woods truck
92 zuk
88 zuk/yota buggy..amateur comp buggy
95 zuk..needs work
90 tracker dd
93 idi diesel f350
...and a pos trailer
zucruisers is offline   Reply With Quote
Old 12-04-07, 11:43 AM   #33
Wayneraintree's Avatar
TLCA# 9720
I will be there Sean, thanks for the offer to freeze a little on my behalf : )
Jeffrey
Save Tellico!
TreadLightly
BlueRibbon Coalition
United Four Wheel Drive
TLCA.org
ALCA- Fledgling Cruiser group of eastern PA
Wayneraintree is offline   Reply With Quote
Old 12-05-07, 02:31 AM   #34
shmukster's Avatar
TLCA# 12019
hub parts
Jeff- I have anything you need in the way of Aisin hub parts. Let me know exactly what you want and I can mail it to you. Gary S
shmukster is offline   Reply With Quote
Old 12-05-07, 12:33 PM   #35
TLCA# 9720
Hey thanks Gary! I'll let you know how it comes together for me. You are generous as always!
Jeffrey
Save Tellico!
TreadLightly
TLCA.org
Old 12-06-07, 04:40 PM   #36
TLCA# 9720
I8conewashers
almost got the front axle stripped ready for cleaning and installation of the goods
anyone else not able to feel their toes? needs me a shop heater
Jeffrey
Save Tellico!
TreadLightly
TLCA.org
Old 12-06-07, 05:22 PM   #37
TLCA# 9720
anyone done the IFS box swap? Should I keep the rag joint at the end of the shaft for use with the IFS box? How did you make the shaft longer (since I plan to mount the new box forward)?
Jeffrey
Save Tellico!
TreadLightly
TLCA.org
Old 12-06-07, 06:22 PM   #38
rag joints are the devil!...eliminate it if at all possible...and i forgot to look and see if i have any extra steering shafts
and why do ya hate conewashers?...they're fun
92 zuk
95 zuk..needs work
90 tracker dd
93 idi diesel f350
Old 12-06-07, 06:30 PM   #39
TLCA# 9720
got the front 3rd out and ready to put in the lockrighted 3rd once I get gaskets for the front and rear.
Weld up that rear yet?
I need to search and find out what to use instead of the rag joint.
Once I clean up the housing, I need to install all the long's stuff, that's the fun stuff! And I don't so much mind the conewashers as much as Eva minds the BFH LOL : )
Jeffrey
Save Tellico!
TreadLightly
TLCA.org
Old 12-06-07, 06:52 PM   #40
havent had a chance to weld that yet, ill let ya know when i do
gaskets?...i always use ultra grey or ultra black rtv
if i have an extra steering shaft it should be one with a ujoint on the end and a slip joint in it, i think i still have an extra
92 zuk
95 zuk..needs work
90 tracker dd
93 idi diesel f350
Old 12-06-07, 09:21 PM   #41
i have a steering shaft that should work for ya, you gonna be around tomorrow?
92 zuk
95 zuk..needs work
90 tracker dd
93 idi diesel f350
Old 12-07-07, 07:31 AM   #42
TLCA# 9720
PM'ed ya : )
Jeffrey
Save Tellico!
TreadLightly
TLCA.org
Old 12-16-07, 12:19 PM   #43
updates?...i know you've made some progress
92 zuk
95 zuk..needs work
90 tracker dd
93 idi diesel f350
Old 12-16-07, 05:38 PM   #44
TLCA# 9720
Well, updates are as follows:
Locked right 3rd installed up front
Got the pass side longfield and chromo hub gear installed
Got the pass side completely reassembled
Since I found a broken birf on the driver side, I cleaned it up enough to see booger'ed metal around the seal seating surface. This is a good reason not to drive far engaged with a broken birf
John and Dom came over and cleaned up the surface with my dremel tool, seal is now seated thanks guys
I would be out in the garage reassembling the driver side of the front axle but the 40MPH winds and dropping temps coupled with an open garage door have me here, web wheeling
I should be able to get the side reassembled, mock up the steering and place the IFS box this week. I am looking forward to getting on with this project.
I also scored two 8 gal. propane tanks. Amerigas in white deer, PA reconditioned two steel tanks, new valves, paint, and filled them. 50$ for the tanks, 40$ for the fill Can't beat that... now I need lines and to install the propane set up on the V8.
I am thinking this thing will scream
John is making room in the shop......
and Sean S. gave me an IFS hub and my rear chevy's back to install.
Going rear springs up front so if someone has some stock minitruck rear leaves sitting around... let John or I know.
I am going to set a goal to have this thing running and operable by the end of January provided the tubework can be completed based on John's availability.
Oh yeah, Dom was nice enough to take a t-case and my 4.7 gears and install kit to school this week..... should be able to bolt it up sometime soon for some crawl!
Jeffrey
Save Tellico!
TreadLightly
TLCA.org
Old 12-20-07, 05:21 PM   #45
TLCA# 9720
Updates...
Got started on the IFS steering box install with the Marlins mount kit. Thanks to John for the help with the placement.
Pulled the front antisway bar and got the tierod and draglink installed to mock it up..
I got the holes drilled for the mounting plates, all I need to do is some grinding and welding and I should be able to finish it up soon
The core support only needed to be clearanced a bit to move the box pretty far forward, clearance on the frame, etc looked good!
oh yeah, Dom has my transfer case with the 4.7 gears installed coming tomorrow this is coming along nicely!
Jeffrey
Save Tellico!
TreadLightly
TLCA.org
Old 01-07-08, 12:58 PM   #46
TLCA# 9720
The mini made its way to John's for tubework, thanks for picking it up John! I may take a pic or two today since I am headed over there and it is on all 4 tires. The steering turned out nice!
Jeffrey
Save Tellico!
TreadLightly
TLCA.org
Old 01-07-08, 05:05 PM   #47
Straydog's Avatar
TLCA# 16782
Try to hold still for the next pics. Last ones look like you're going through withdrawl.
SEAN
85 extra cab
Old 01-09-08, 12:07 AM   #48
the next pics taken will be from my camera...and i sent those spring hanger brackets home with jeff today so he can grind the welds off of them
tube work will start very soon, the samurai will be out of the shop tomorrow, and the minitruck will go in, but i want to finish sean's bumper before i start on the mini
92 zuk
95 zuk..needs work
90 tracker dd
93 idi diesel f350
Old 01-09-08, 06:26 AM   #49
TLCA# 9720
allright, post some pics already!!!!
Jeffrey
Save Tellico!
TreadLightly
TLCA.org
Old 01-09-08, 06:45 AM   #50
Ride On...
lowtideride's Avatar
TLCA# 14891
signing in!!!
www.NFCruiserheads.org FJ45 Crawler and a 1983 Hilux...
has had no peers for 50 years...
lowtideride is online now   Reply With Quote
Old 01-09-08, 09:42 AM   #51
TLCA# 9720
Welcome Alex! Sorry I was out of town when you were in
One more pic on all fours cause I like it
Jeffrey
Save Tellico!
TreadLightly
TLCA.org
Old 01-11-08, 01:57 PM   #52
TLCA# 9720
anyone have any feedback on the lines proposed to cut these into half doors? I've looked at the Pirate and other's threads on half doors but am just wondering what ya'll think.
I am going to keep the window frame and make canvas snap-on covers for the openings in case of really incliment weather
I am wondering about how much I plan to take out.... is it too much? I want it to be light and increase visibility, so the tape marked cuts provide that, I do plan to weld in one brace (or armrest) support horizontal along the high part of the cut).
Feedback?
Jeffrey
Save Tellico!
TreadLightly
TLCA.org
Old 01-11-08, 02:29 PM   #53
jtaco1's Avatar
I would change the lines to something like this and just go ahead and move the handle.
I will be doing this as well to a set of mine eventually, or make a set of tube doors.
JT
DD - 05 Toyota 4 Runner
Trail Rig - 88 4 Runner with dual case, 35's and no lift
Was
99' Toyota Tacoma Crushed by Toyota
jtaco1 is offline   Reply With Quote
Old 01-11-08, 02:52 PM   #54
TLCA# 9720
why would ya move the handle if you don't have to? just wondering since it appears that the lines I have are walk though, handle not moved, and good visibility.. maybe lack in style points but... benefits of the angle?
Jeffrey
Save Tellico!
TreadLightly
TLCA.org
Old 01-11-08, 04:38 PM   #55
jeff i dont think cutting down into where the red paint on your doors is going to help much with visibility, otherwise it looks fine to me
92 zuk
95 zuk..needs work
90 tracker dd
93 idi diesel f350
Old 01-11-08, 05:08 PM
