Go Back   IH8MUD™ Forums > General Tech Forums > 'Other' Vehicle Tech
Old 05-06-08, 09:32 AM   #1
Whitey
FJBen's Avatar
TLCA# 15530
FJBen is an unknown quantity at this point
Yamaha TW200 rebuild
I just got (for free) an 87 Yamaha TW200 bike.
Very cool, same story, it did run but blah blah blah...
Anyways, it's at home and I've begun to start the repairs. Pulled the tank, it's leaking, I either need to seal or get a new tank.
At the moment I have no Spark. I've tried the old pull the plug, put it on the cylinder and kick it over but no fire. Even with the battery charger plugged in showing full juice, no spark. No electric start either, thats not working. When I check the coil I dont' have any power to it with key on. I would assume I should?
Now in the second picture, it shows I have power from the battery to this relay (assuming it's the starter relay) but none on the other side, which I shouldn't unless I'm trying to start.
Any other thoughts on where to go/start?
pics, the bike, wiring
93 FJZ80 Slee 4"/OMEJ, 35's, 4.88's, ARB's, Metal Tech sliders, On Board Air, caster plates, DC drive shaft, Pin7, CDL, adjustable rear uppers, ARB front bumper, homemade rear, Slee Skid Plate, extended brakelines, backup camera
96 FZJ80 285's OME 's ride
FJBen is offline   Reply With Quote
Old 05-06-08, 09:36 AM   #2
pint's Avatar
TLCA# 17493
pint is on a distinguished road
Sorry, no help from me, but COOL bike! Good luck.
2000 UZJ100, OME 865, OME T-bars, Slee Diff Drop, Slee Step Sliders, TJM T3, PowerStop Cross Drilled & Slotted Rotors, 295 Terra Grapplers
M101 Trailer ridding on Nittos and green primer...
pint is offline   Reply With Quote
Old 05-06-08, 09:51 AM   #3
JJS
JJS's Avatar
JJS is an unknown quantity at this point
Coil failure is pretty common on older 4-stroke Yamahas.
'75 FJ40. V8. SOA. Cage. Lockers. Not done...
"The FJ is Toyota's answer to the Jeep CJ, and flame wars between fanboys of the two vehicles will continue long after the apocalypse begins. The consensus is the Toyota will take more abuse -- a big plus when roaming the desolation -- but it's harder to fix when something goes sideways. Fortunately, it's a Toyota, so you'll break before it will."
JJS is offline   Reply With Quote
Old 05-06-08, 09:54 AM   #4
When In Doubt, Go Higher!
Hltoppr's Avatar
Location: Port of Indecision...otherwise Northern Arizona
Hltoppr is on a distinguished road
You might try searching and posting on Adventure Rider Motorcycle Forum It's kinda the IH8MUD of dual sporting....lots of info...
-H-
2003 BMW R1150GS Adventure
1983 FJ45 Troopy
KE7TYL
...and then there is always Mexico....
Hltoppr is offline   Reply With Quote
Old 05-06-08, 10:00 AM   #5
Whitey
FJBen's Avatar
TLCA# 15530
Cool, I'll check avrider, I've looked on there before.
I think I remember something about the coil failure. Anyone know how to test the coil?
Old 05-06-08, 09:57 PM   #6
Oh...Durka Durka Durka.
Poser's Avatar
TLCA# 1856
Poser is on a distinguished road
Ben-
Might want to try these folks out as well.
Good people and good info:
TW200 forum
Old 05-07-08, 07:47 AM   #7
Whitey
FJBen's Avatar
TLCA# 15530
Originally Posted by Poser View Post
Ben-
TW200 forum
thatnks Poser, I found that yesterday. From the sounds of it, I think the neutral sensor may be causing some issues. I can use a screwdriver to jumper the starter relay and it turns over, just no spark.
I downloaded a FSM so I'll start the tear down into that.
Old 05-07-08, 06:28 PM   #8
lurker
NW-sickboy's Avatar
NW-sickboy
no help but i can say i have charged some insane single track trails on the 85-86 BW versions that were not road legal, we geared them down a a few teeth and could haul out quarter of an elk on the rear racks... ours ran ridiculously well for YEARS... great bikes.
I had to track this pick down.... we want on some pretty hairy single track with all of us on that rig... thinking this was taken in 93ish.. i am on the very back....
Tri4Life
http://gdigitalborgsneed.blogspot.com/
NW-sickboy is offline   Reply With Quote
Old 05-12-08, 07:58 AM   #9
Whitey
FJBen's Avatar
TLCA# 15530
nice pics!
I got the bike started and running this weekend. Needs some adjustment here and there, but overall, I"m super happy!
Old 06-13-08, 10:21 AM   #10
Whitey
FJBen's Avatar
TLCA# 15530
thought I'd post an update...
Pro-Grip 791's
Tusk roost guards
New Oil and Filter
Seat is getting recovered
Rebuilt carb
Junkyard bar risers
Still need to do:
Baja Designs rear LED taillight
New Fork Seals
Seal Savers
New/used gas tank
New muffler
She's running pretty good, I haven't got to mess around too much yet because of the tank, (leaking slowly)
Bad Credit Mortgages | Babb Fest | Debt Consolidation | Desktop PC | Mortgage
