Go Back   IH8MUD™ Forums > General Tech Forums > 'Other' Vehicle Tech
Old 04-06-08, 05:43 PM   #1
Guy Fawkes Lives!
Miescha's Avatar
TLCA# 8094
'96 Camry antenna repair?
I've read several posts on repairing the antenna mast/motor etc. .. on a TLC, but I've never had the problem. However, my neighbor has a '96 Camry and the antenna doesn't go up. It looks like many of the interior parts and non-offroad parts are very similar. Does anyone know what parts are needed for repair or replacement of the camry antenna?
If it matters, when the car is first started, I can hear the motor running on the antenna, but it doesn't move. I'm told that over the course of several weeks the antenna will actually go up a bit, but never get past 1/4 . It can be easily pushed back down at any time.
Any advice including part numbers and estimated prices would be appreciated.
1996 FZJ80 (original owner) Black & Oak, 105k miles with factory F/R lockers, CDL switch, hand throttle, OME Springs & Shocks, ARB, Warn M12000, Milford Barrier, Dual Optima Blues, extended breathers, OEM dash cupholder, 285/75/16 BFG AT, Landtank seat rails, Slee AC dryer & T-case skid plates, Slee light & aux harnesses, Slee SS brake lines (frame->axle->caliper), V-1 with remote display, Icom IC-7000, Yaesu 8900R, Cobra 75wstx, Larsen NMO-2/70 & NMO-27, 100-series pads
Miescha is offline   Reply With Quote
Old 04-06-08, 06:49 PM   #2
cruiser88's Avatar
TLCA# 17319
Advance sells a after market setup for the 60....i will see if i can hunt up a part#
cruiser88 is online now   Reply With Quote
Old 04-06-08, 07:00 PM   #3
cruiser88's Avatar
TLCA# 17319
I am not coming up with a part # in the 60 section......which my 62 looks just like my 92 Camry antenna from what i can tell externally.
Search the 80s section maybe or take his out and run to Adavce and see if make something up.......they sell a bunch of universal ones.
Here is a example from Autozone
AutoZone.com | Shopping | Results for power antenna
Old 04-09-08, 11:42 PM   #4
KliersLC's Avatar
Pull it out and see if the cable is broken or if the mast is broken. Whatever it needs, order it and reassemble.
No problem, I'll just tow the pig to Salt Lake on a UHAUL trailer......
95 T100, beater edition
01 Sequoia Limited
02 Camry--Poor replacement for an 80
"A vehicle's capabilities are inseparably linked to the mental instability of the driver"
KliersLC is offline   Reply With Quote
Lockers | Free Ringtones | Loans | Loan | Debt Help
