Carb'd Chevy 350 Question - Carb backfire
My 40 has a 78 350 installed. I run a Rochester 2 barrel carb. There is no smog stuff on it. Recently when running at moderate rpm, say 2000, engine is warm, when I put my foot into it the engine will sneeze through the carb.
My stock 40 used to do this and the solution was a new gasket around the accelerator pump, as I recall. The only PM I have done is fluid changes, air filter and plugs. The PM was done months ago. I run regular CA fuel. Should I check the timing or might something be wrong with the carb? The choke is OK and not stuck closed. Thanks, BigJim __________________ Third generation Californian! If you don't like it here, leave. And take your fat wife and screeming kids with you. |
Engine off, look down the carb throat, move throttle to w/o, look for pump shot.
__________________ 1980 PU 9" lift 383 38" Swampers 1993 FZJ80 6" slee lift 37s 2000 XR671L 83 BJ60 under construction 2008 XR650L |
Former Wheeler
definitely with the engine off. You'll look goofy without eyebrows.
LMAO! I have seen this happen!
__________________ Does the water go all the way around the Island?
my 72 chevy 2 wheel drive long bed with a 350 with a 2 barrel carb does this with bad gas. We just picked the rig up so i plan to get a carb "rebuild" kit. and do the gaskets and new filters for it! Mine only did it around 50-60 MPH. and only when in drive. when i ran premium it stopped doing it so much but still did a little!
__________________ Its not a Passion, its an Obsession Cruiser~95 stock 80 series, Goodyear Forterra Triple-Treds, Samco sport PHH. Princess Ride~2008 Toyota Tundra Crewmax limited ![]() Chevinater~ 77 Chevy 3/4 ton 350/350/203 with 44 front 14ff rear, 4.56s, 6 inchs 35x12.5x16.5 bfg m/t |
Online Loans | eBay | Loans | Loans | Pay Day Loans |
