TLCA.org
Go Back   IH8MUD.com > TLCAForum.com > Toyota Land Cruiser Association Forum > North American Clubhouses - West Region > NV- Battle Born Cruisers of Northern Nevada
Old 03-16-09, 08:20 PM   #91 (permalink)
Dain Bramaged Member
rusty_tlc's Avatar
TLCA# 15069
Originally Posted by DesertLake View Post
Why will the autos be better than selectables on the 40?
(Gittin my learn on)
One less thing to think about. They are just there and work. The disadvantage is they can get the front end bound up when they lock while in an obstacle. The solution is to grind out the shift gate so you can stay in low gear but shift into 2WD long enough to line back up. The 40 has a twin stick set up so I can already do that. Or I can do a hydro assist. The PS box on my 40 is tapped for hydro and I have the ram and all the stuff to set it up.
Dan Johnson
What the large print giveth, the fine print taketh away.
1975 FJ40, A couple of thingamajigs and a deally bob, fully integrated whatzits, dash board Hula girl (pending spousal approval.)
1998 pair of Pink Panties, now with a doohicky in the front.
1984 FJ60, Detroits F&R and a gawd awful spring lift.
Rust never sleeps.
rusty_tlc is offline   Reply With Quote
Old 03-16-09, 08:25 PM   #92 (permalink)
rusty_tlc's Avatar
TLCA# 15069
Originally Posted by CaliCruiser View Post
Why do you need lower gears in your 40, don't you still have the toybox and Orion?
It would be ideal to have the 4.88's and ARB's in the 60 with the 4.11's and detroits in the 40 IMO. It would keep a stonger gear set in the 40 (more hardcore rig) and give you some good grunt in the 60 for the occasional hard trail. Unfortunetly this means swapping ring and pinions and introduces $$ into the picture.
I hate decisions like this. . .
Dylan
Lower gears in the differential would reduce stress on the axles and birfields, and I could go to a larger tire size and still have reasonable gearing for the paved roads.
The sixty will be used for longer trips so the higher gearing will be better.
Dan Johnson
Rust never sleeps.
Old 03-16-09, 08:26 PM   #93 (permalink)
rusty_tlc's Avatar
TLCA# 15069
Originally Posted by chicago View Post
Im gonna take a stab and say that it is because the 40 is primarily on the more heavy duty TRAILS where lockers are pretty much always used. So less of a need for OPEN diffs.
The beauty of the selectable locker is the ability to have open diffs on the road, and lock em up when on the trail.
the 60 (from what it seems) will be used for more distance/ expedition type wheeling where there will not be a need for full time lockers.
Why not use the ARB's on both...theyre FU*KING EXPENSIVE. Most people would love to have ARB's, but theyre cost prohibitive. Personally, I LOVE my auto lockers, expecially in the rear. However, I compromised on the front. I would actaully preferred ARB's in the front, but I didnt want to spend the money. If you do Longs, a lunchbox locker (aussie, lockright) AAAAAND a basic hydro assist youll STILL be money ahead than what an arb with install and longs would cost.
So, when I do my V8, Ill be adding the ram assist too.
Something like that...
K
That too.
Dan Johnson
Rust never sleeps.
Old 03-16-09, 08:30 PM   #94 (permalink)
Addicted to MUD Porn
locrwln1's Avatar
TLCA# 16879
Originally Posted by rusty_tlc View Post
I think my brain has formulated a plan. Being kind of a small pot it took awhile to percolate a plan in it. I'm just going to throw it out here to see what the collective wisdom thinks about it.
I think what I'm going to do is swap the differentials with the 4.88 gears and Detroit lockers from the FJ60 into the FJ40 and the differentials with the ARB lockers with the 4.11 gears from the FJ40 into the FJ60.
Here is why;
The FJ40 needs lower gearing because I want to go to a larger tire size, the FJ60 needs higher gearing because it will see a lot more highway miles.
The auto lockers will be a lot easier to deal with on a mostly trail rig, actually they may be better than selectable lockers on the FJ40.
The FJ40 has Longfields which will take the auto locker "snap" better than the stock birfs on the FJ60
It's basically free, all it will cost is a few gallons of gear lube and some Permatex gasket maker.
Comments?
That is exactly what I would do.
The tired 2f in the 40 will really appreciate the additional gearing for the highway, plus the 60 will do a better job of pulling the trailer/highway runs.
Jack
KE7NCK
1996 FZJ 80 (explorer)
2002 F350, PSD, 6SPD,4X4,CC, LWB (hauler)
1995 Mazda MX-6 (speedster)
locrwln1 is offline   Reply With Quote
Old 03-18-09, 10:48 AM   #95 (permalink)
rusty_tlc's Avatar
TLCA# 15069
I need to make sure the drive shaft flanges will work.
Dan Johnson
Rust never sleeps.
Old 03-18-09, 10:36 PM   #96 (permalink)
locrwln1's Avatar
TLCA# 16879
Just rotate the drive shaft 90 degrees, mark and drill new holes for the flanges to bolt up to.
Jack
KE7NCK
Old 03-19-09, 09:01 AM   #97 (permalink)
rusty_tlc's Avatar
TLCA# 15069
Jack
I should be okay, the companion flanges on the FJ40 diffs are the one size fits all style from High Angle. The front DS on the 40 has stock flanges and the rear has a one size fits all flange on the diff side. It's just one of those things I'd like to make sure of before I start draining 90WT and pulling the diffs.
Dan Johnson
Rust never sleeps.
Old 04-02-09, 09:40 AM   #98 (permalink)
rusty_tlc's Avatar
TLCA# 15069
A couple of things.
After actually taking the rig through Eldorado I don't think I want to screw with it. It drives fine off road and even though it's slow I can live with driving it on the highway.
I did bash one of the rockers a little on the trip. A set of sliders is in the back of the truck ready for install.
I wonder who could weld them on for me?????????????
Dan Johnson
Rust never sleeps.
Old 04-02-09, 07:46 PM   #99 (permalink)
chicago's Avatar
TLCA# 16202
What sliders did you get?
K
TLCA#16202, KE7VAT
Toyota family:
88 FJ62 (Sold to a good home. Goodbye old friend!)
76 FJ40 (Blotch rig part deux)
06 4runner...wifes rig!
06 Tacoma, DD, BONE STOCK and staying that way!
PROUD member of the WEST COAST BLOTCHERS and the Battle Born Cruisers of Northern Nevada!
FAWKING CUBS!
chicago is offline   Reply With Quote
Old 04-02-09, 08:41 PM   #100 (permalink)
rusty_tlc's Avatar
TLCA# 15069
K
Trail gear.
They were cheap and it gave me a chance to give ORI some business.
Dan Johnson
Rust never sleeps.
Old 04-02-09, 10:49 PM   #101 (permalink)
450 DUDE's Avatar
ahhhh man! you supported tg?
ken
97 with thingy's and dodads
Now with added geek KI6JEO
450 DUDE is offline   Reply With Quote
Old 04-03-09, 01:32 PM   #102 (permalink)
rusty_tlc's Avatar
TLCA# 15069
ken
What is up with the heart burn everybody has with TG?
Dan Johnson
Rust never sleeps.
Old 04-03-09, 01:59 PM   #103 (permalink)
Triple O G
slvrbck's Avatar
TLCA# 19348
They call it Trail Mart.......
slvrbck is offline   Reply With Quote
Old 04-03-09, 02:15 PM   #104 (permalink)
Cruiserdrew's Avatar
TLCA# 11734
Or China Trail.
I think it's basically that they ahem,,"borrowed" the designs and ideas of Marlin and opened on their own, building bits and parts cheeply in China. Notice their sliders are essentially exact copies of Marlin's and sell for $100 less. Marlin's though are DOM and Trail Gears are Chinese mystery metal that in some cases is iron based and attracts a magnet.
Marlin's main dude for awhile, jumped ship, and went to work for TG, though I understnd he is now out of TG due to a dispute there. Lots of bad blood in the Mini-truck world.
Me personally have no beef with TG. I bought the 6 stud knuckles from them when no one else was offering a similar solution. Now you can make add on 6 stud knuckles with parts from 4x4 Labs.
Andrew
Cruiserdrew is online now   Reply With Quote
Old 04-03-09, 03:10 PM   #105 (permalink)
Triple O G
slvrbck's Avatar
TLCA# 19348
Yep, that's about it....it's true, there is a lotta drama in the LBC.
Old 04-03-09, 03:10 PM   #106 (permalink)
rusty_tlc's Avatar
TLCA# 15069
So how long was Marlin working on the six stud knuckles with no product for sale?
In my world you better be ready to take advantage of the sales opportunities before you start promoting a product.
Based on the weight of the package whatever TG made my sliders out of they didn't skimp on the quantity of material. I guess time will tell if they are sturdy or not, the die has been cast.
Dan Johnson
Rust never sleeps.
Old 04-05-09, 09:40 AM   #107 (permalink)
chicago's Avatar
TLCA# 16202
I had the opportunity to see them Friday over at Rusty's...Theyre BEEFY for sure.
Theyll do great. I have no doubts.
K
TLCA#16202, KE7VAT
Toyota family:
FAWKING CUBS!
CONTACT US AT MEMBERSHIP@TLCA.ORG
