TLCA HOME : BOARD & BYLAWS : EVENTS: MERCHANDISE : BUSINESSES : PHOTO GALLERY : CLASSIFIEDS
HISTORY : TOYOTA TRAILS : MEMBERSHIP : CLUBS : MISSING VEHICLES : LAND USE : CHAT : LINKS
Go Back   IH8MUD™ Forums > TLCAForum.com > Toyota Land Cruiser Association Forum > Clubhouse Corner > NV- Battle Born Cruisers of Northern Nevada
Old 05-22-08, 08:08 AM   #1
DesertLake's Avatar
TLCA# 18080
Weld through primer
Can any of you experienced welders tell me which weld through primer is worth using, and where I can get it? I'll be welding a new layer of sheet metal to my door as seen below, and would like to prevent rust where possible.
IH8MUD.com Forum - View Single Post - FJ55 Door Crack Repair
'74 FJ55, missing this and that, runs mostly on ether
Now with added build thread!
DesertLake is offline   Reply With Quote
Old 05-22-08, 05:19 PM   #2
krokarthecrooked's Avatar
Well you dont want weld through primer for starters as most of it make it hard to weld and can cause perosity you would be better off welding everything then clean it up and then primer when its cooled off and yoiu can also use some stuff called rust mort if you can find it put it on after your done welding first then clean and primer over that. the Rust mort will also take out most of the rust in that area and help to keep it out
Dan
krokarthecrooked is offline   Reply With Quote
Old 05-22-08, 06:39 PM   #3
DesertLake's Avatar
TLCA# 18080
Thanks Dan.
In this case, I'm welding one piece over another, so I won't have access to prime after welding, I just want to prevent rust between the layers. Is there something that would work for that?
Old 05-22-08, 09:31 PM   #4
Dan Dare!
rusty_tlc's Avatar
TLCA# 15069
Contact sisukid1975 on mud. He is the most anal frame off resto guy I know. He will know the best products to use.
Dan Johnson
Originally Posted by DSRTRDR View Post
maybe your life took a vacation without you and that's why you are going crazy........
FJ40, A couple of thingamajigs and a deally bob, fully integrated whatzits, dash board Hula girl (pending spousal approval.)
And a pair of Pink Panties, now with a doohicky in the front.
Rust never sleeps.
rusty_tlc is offline   Reply With Quote
Old 05-22-08, 09:58 PM   #5
Np at all the other thing about weld through primer is youll burn pretty much all of it off in the welding process. if you use Rust Mort or something similar to it it should do the trick and if i remember right you can get that at Napa Auto parts stores
Dan
Old 05-27-08, 09:03 PM   #6
psreno's Avatar
TLCA# 7859
I've used the 3M product.
Not real impressed.
But then my welding isn't real impressive anyway.
psreno 64FJ45, 68FJ40, 71FJ40, 95Runner, 89F250Tow'r, 01Exploder
psreno is offline   Reply With Quote
Old 05-28-08, 06:51 AM   #7
DesertLake's Avatar
TLCA# 18080
Thanks guys!
YOU MAY CONTACT US AT MEMBERSHIP@TLCA.ORG | (800) 655-3810 | PO BOX 230, VERONA, KY 41092
