TLCA HOME : BOARD & BYLAWS : EVENTS: MERCHANDISE : BUSINESSES : PHOTO GALLERY : CLASSIFIEDS
HISTORY : TOYOTA TRAILS : MEMBERSHIP : CLUBS : MISSING VEHICLES : LAND USE : CHAT : LINKS
Go Back   IH8MUD™ Forums > TLCAForum.com > Toyota Land Cruiser Association Forum > Clubhouse Corner > NM- High Desert Cruisers
Old 06-29-08, 03:44 PM   #1
In debt to the Shaman
pappy's Avatar
TLCA# 10004
Clutch Help
I posted this in 40 Tech too. I need help. When I push in the clutch the rod on the slave moves the fork, but the tranny doesn't disengage from the engine. Any idea what I did wrong?
2F engine
4-speed bellhousing
Diaphragm clutch
Late 70's master cylinder (used)
Late 70's slave cylinder (new)
aka Bushrat
1969 FJ40 Project TEROTE: Tim@DOA 3FE stroker (aka 2FE), H55F, SOA/SR, 35" MT/R, 3:1TC ... assembly in process
1985 4Runner: lifted, locked, Tim@DOA 22RE, 4.7 tc, with 33" training wheels. R151F with dual 23-spline TCs in the garage.
McCain/Obama - Four more years of hell.
pappy is offline   Reply With Quote
Old 06-29-08, 03:52 PM   #2
The quick brown fox .....
Beowulf's Avatar
Wrong pressure plate?
-Mike-
97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress...
Old 06-29-08, 04:34 PM   #3
pappy's Avatar
TLCA# 10004
Wiser men have suggested my disk is in backwards. I guess the tranny will be coming off.
Poop.
aka Bushrat
Old 06-29-08, 05:48 PM   #4
Beowulf's Avatar
Too bad. I have heard that it is possible to assemble automotive parts incorrectly but that has never happened to me so I wouldn't know much about that.
-Mike-
Old 06-29-08, 05:55 PM   #5
pappy's Avatar
TLCA# 10004
-Mike-
Thanks Mike. This is twice this month. You would think that after all these years I'd learn to read a service manual.
aka Bushrat
Old 06-30-08, 08:19 AM   #6
alia176's Avatar
TLCA# 15941
Poop.
Curious, if the clutch disk is backwards, that would be an engaging issue while the flywheel is spinning. As in, the clutch is slipping and the vehicle isn't going anywhere. Or is my logic wrong?
You are not able SHIFT out of gear from what I gather. Wouldn't that be a linkage/clutch fork/TOB type of issue?
Can you somehow move the fork even more to see if anything changes?
TLCA # 15941
KE5LED
Currently working PA
alia176 is offline   Reply With Quote
Old 06-30-08, 09:07 AM   #7
pappy's Avatar
TLCA# 10004
From what the wise men said the clutch disk is bound up on the flywheel bolts preventing it from spinning.
aka Bushrat
Old 06-30-08, 10:43 AM   #8
alia176's Avatar
TLCA# 15941
ahhh.....
Sucks that you gotta drop that SOB again
TLCA # 15941
KE5LED
Old 06-30-08, 02:53 PM   #9
Cruisergreg's Avatar
Make sure to think through your clutch fork and hydraulics. There's a whole mishmash of parts that had been used in the late 40 and 60 eras. Getting the wrong collection can cause the problems you describe. IIRC the H55FF MUST use the later 60 series hydraulics and fork to get the correct throwout.
1986 V8J60
There's a feeling I get, when I look to the West...
Cruisergreg is offline   Reply With Quote
Old 06-30-08, 05:09 PM   #10
SteveLCetc's Avatar
TLCA# 10821
Originally Posted by alia176 View Post
ahhh.....
He's gonna drop it all again anyway, just for fun...
'78 40, 4" Skyjacked, Aussie Locker, 33" MT's, Warn 8274
'99 4Runner with Jayco Baja Pop-up
'04 Corolla LE 5-Sp
Yaesu FT-7800R Dual Band
VP, High Desert Cruisers
Drill Baby Drill
SteveLCetc is offline   Reply With Quote
Old 06-30-08, 06:50 PM   #11
pappy's Avatar
TLCA# 10004
I researched this before I started. What I learned is:
  • Clutch disk was used from: 1958-1987
  • Pressure plate was used from: 1975-1987
  • TO Bearing was used from: 1975-1987
  • Flywheel was used from 1975-1987
  • Clutch fork was used from: 1975-1985
  • Bellhousing was used from 1975-1980
  • Clutch master was used from: 1975-1980
  • Clutch slave was used from: 1975-1980
So, the only parts that seem to be paired were the clutch master, slave, and bellhousing. Otherwise, the clutch guts are consistant from 1975 up to 1987. My master, slave, and bellhousing fall into the 1975-1980 range.
Actually I was going to try and keep the engine and tranny attached when I pull it, and install it. Might take two engine hoists, but that was my intention.
aka Bushrat
Old 07-01-08, 08:40 AM   #12
Did you give up?
FJ40
FJ40 - $3000 (ALBUQUERQUE)
Reply to: sale-738790072@craigslist.org
Date: 2008-07-01, 12:05AM MDT
FJ 40 1968 NEEDS CLUTCH
1999 Toyota Landcruiser - 285/75/16 BFG AT, Slee SliderSteps™
slimbuddha is offline   Reply With Quote
Old 07-01-08, 11:51 AM   #13
I see two potential problems
H55F was only ever used with the 3F (or diesel equivalent) bell house as far as I know. I know for a fact that the 3F bellhouse has a cant to it compared to the earlier one and could have other dimensional differences (too long or too short).
The hydraulics need to match the other components to work correctly - I imagine that's why they were used only until 1980. For shits & giggles you might try adjusting both the master and slave rods, if they have that capability.
1986 V8J60
Old 07-01-08, 08:11 PM   #14
BionicCruiser's Avatar
i had the same problem when i put the SM465 in my 40. of course, my problem was that the chevy disk came in multiple sizes and the disk was being caught in between the pressure plate and the fly wheel once bolted together. (disk too big). i'm not good with the toyota stuff as well, so good luck.
'77 FJ40-Bionic- LT1, 4L60E, NP208, 14B/Detroit, D60/ARB, 4.56's, SR, SOA/FJ55 rears, 96"wb, saginaw PS.
'63 FJ45 SB
'69 FJ40 Trailer
'97 F350 PSD
BionicCruiser is offline   Reply With Quote
Old 07-01-08, 08:26 PM   #15
pappy's Avatar
TLCA# 10004
Fortunately, they are adjustable. That was the first place I started and I was able to get the slave rod to move the fork enough to where I thought it would work. Not.
aka Bushrat
YOU MAY CONTACT US AT MEMBERSHIP@TLCA.ORG | (800) 655-3810 | PO BOX 230, VERONA, KY 41092
