TLCA HOME
: BOARD & BYLAWS
: EVENTS: MERCHANDISE
: BUSINESSES
: PHOTO GALLERY
: CLASSIFIEDS HISTORY : TOYOTA TRAILS : MEMBERSHIP : CLUBS : MISSING VEHICLES : LAND USE : CHAT : LINKS |
In debt to the Shaman
Clutch Help
I posted this in 40 Tech too. I need help. When I push in the clutch the rod on the slave moves the fork, but the tranny doesn't disengage from the engine. Any idea what I did wrong?
![]() 2F engine 4-speed bellhousing Diaphragm clutch Late 70's master cylinder (used) Late 70's slave cylinder (new) __________________ aka Bushrat 1969 FJ40 Project TEROTE: Tim@DOA 3FE stroker (aka 2FE), H55F, SOA/SR, 35" MT/R, 3:1TC ... assembly in process 1985 4Runner: lifted, locked, Tim@DOA 22RE, 4.7 tc, with 33" training wheels. R151F with dual 23-spline TCs in the garage. McCain/Obama - Four more years of hell. |
The quick brown fox .....
Wrong pressure plate?
-Mike- __________________ 97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress... Sometimes you find yourself in the middle of nowhere. And sometimes in the middle of nowhere, you find yourself. |
Wiser men have suggested my disk is in backwards. I guess the tranny will be coming off.
Poop. ![]()
Too bad. I have heard that it is possible to assemble automotive parts incorrectly but that has never happened to me so I wouldn't know much about that.
![]() -Mike- __________________ 97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress... Sometimes you find yourself in the middle of nowhere. And sometimes in the middle of nowhere, you find yourself. |
#5 | |
You would think that after all these years I'd learn to read a service manual.
#6 | |
You are not able SHIFT out of gear from what I gather. Wouldn't that be a linkage/clutch fork/TOB type of issue? ![]() Can you somehow move the fork even more to see if anything changes? __________________ TLCA # 15941 KE5LED Currently working PA |
From what the wise men said the clutch disk is bound up on the flywheel bolts preventing it from spinning.
#8 | |
ahhh..... Sucks that you gotta drop that SOB again
Make sure to think through your clutch fork and hydraulics. There's a whole mishmash of parts that had been used in the late 40 and 60 eras. Getting the wrong collection can cause the problems you describe. IIRC the H55FF MUST use the later 60 series hydraulics and fork to get the correct throwout.
__________________ 1986 V8J60 There's a feeling I get, when I look to the West... |
#10 |
He's gonna drop it all again anyway, just for fun...
__________________ '78 40, 4" Skyjacked, Aussie Locker, 33" MT's, Warn 8274 '99 4Runner with Jayco Baja Pop-up '04 Corolla LE 5-Sp Yaesu FT-7800R Dual Band VP, High Desert Cruisers Drill Baby Drill |
#11 | |
So, the only parts that seem to be paired were the clutch master, slave, and bellhousing. Otherwise, the clutch guts are consistant from 1975 up to 1987. My master, slave, and bellhousing fall into the 1975-1980 range. Actually I was going to try and keep the engine and tranny attached when I pull it, and install it. Might take two engine hoists, but that was my intention. __________________ aka Bushrat 1969 FJ40 Project TEROTE: Tim@DOA 3FE stroker (aka 2FE), H55F, SOA/SR, 35" MT/R, 3:1TC ... assembly in process 1985 4Runner: lifted, locked, Tim@DOA 22RE, 4.7 tc, with 33" training wheels. R151F with dual 23-spline TCs in the garage. McCain/Obama - Four more years of hell. |
#12 |
Did you give up?
FJ40 FJ40 - $3000 (ALBUQUERQUE) Reply to: sale-738790072@craigslist.org Date: 2008-07-01, 12:05AM MDT FJ 40 1968 NEEDS CLUTCH __________________ 1999 Toyota Landcruiser - 285/75/16 BFG AT, Slee SliderSteps™ |
#13 | |
H55F was only ever used with the 3F (or diesel equivalent) bell house as far as I know. I know for a fact that the 3F bellhouse has a cant to it compared to the earlier one and could have other dimensional differences (too long or too short). The hydraulics need to match the other components to work correctly - I imagine that's why they were used only until 1980. For shits & giggles you might try adjusting both the master and slave rods, if they have that capability. __________________ 1986 V8J60 There's a feeling I get, when I look to the West... |
#14 |
i had the same problem when i put the SM465 in my 40. of course, my problem was that the chevy disk came in multiple sizes and the disk was being caught in between the pressure plate and the fly wheel once bolted together. (disk too big). i'm not good with the toyota stuff as well, so good luck.
__________________ '77 FJ40-Bionic- LT1, 4L60E, NP208, 14B/Detroit, D60/ARB, 4.56's, SR, SOA/FJ55 rears, 96"wb, saginaw PS. '63 FJ45 SB '69 FJ40 Trailer '97 F350 PSD |
#15 |
Fortunately, they are adjustable. That was the first place I started and I was able to get the slave rod to move the fork enough to where I thought it would work. Not.
