08-05-09, 06:28 AM
80 Series Front Windshield
After taking a lug nut to the front window and finding out it cannot be fixed and water stating to leak through I figure it's time to get it replaced.
I checked with a few places here in Burlington and wasn't sold on their service/price/attitude. One dude told me all the windshields and seals were the same...I seriously doubt that they are  .
I also checked with Cox Toyota and a new OEM windshield is 630ish wholesale which is major $$$.
Anyone have a place in the RDU/GSO/WS area that they would recommend?
Also what aftermarket brands for the windshield have people had good luck with (I plan on purchasing a new OEM seal which isn't that pricey)?
Thanks in advance!
-Jon
Jon
Olde North State Cruisers
'97 40th OEM Locked - F.O.R. GEN II - CDL - 315 Toyo MTs - slee'd - ipor'd - custom drawers
'74 40 - lifted, locked, PTO'd, 4+ rear bumper, 4+ flip kit (F&R), and other stuff
'06 Chevy Duramax - DD and Tow Rig
08-05-09, 06:38 AM
my neighbor owns/runs a small windshield co. i'll see if he can get us something at a good price.
Eric J
94' de-flared FJ80 on OME heavies with slee blue's on some 33's, Aussie locked rear, ARB front loaded with a re12000 & Kaymar rear, home made sliders, budbuilt drag links and 250K+ on the clock. cdl switch w/7-pin.
OLDE NORTH STATE CRUISERS
08-05-09, 06:43 AM
Great!! I'll stay tuned and hold tight for the time being.
Jon
08-05-09, 06:49 AM
ONSC-Event Co-Ordinator
I have seen in threads that a lot of people also want the company to use a sealant/glue on the seal. I'm not sure if it's becuase they're using aftermarket seals, or what. But I'm sure you might have seen some threads on it.
Let me know how it goes, becuase I need to change mine. PO said it leaks during rain, but no real major cracks/stars. I did notice my driver side floorboard was wet after the last couple days of rain...
Brian, Heather, and Lily
1974 FJ40 JD Green, list too long but it's drivable
1995 FZJ80 Black, knuckle rebuild done, lift next
1974 FJ40 White,Back Axle removal,tub restoration
ONSC, UC, MATLCA
08-05-09, 07:18 AM
ONSC triad VP
OK without checking my facts the way i understand it is that you must use glue on BOTH the surfaces from gasket to vehicle and glass to gasket. Lots of places want to skip this step saying its not necessary but its in the FSM and per toyotas specs.
Also i believe it was PPG that made a run of windsheild replacements for the 80 series that were cut just a fraction too small.
Ive used Matkins in the past but not for the cruiser. There are several around but the one here in GSO is on Norwalk off Wendover.
Jason---- I live vicariously..........................through myself
__________________________________________________ __________
95 80 -- Slee4''/omeJ, 37's, factory locked, full armor and a s/c too
72 55-- w/ 76 4sdp 78 f. disc 79 2F -- SOA + 3'' w/ 35's, IPOR protection
92 P/U -- no "D" light, no umph, no fun except at the pump
08-05-09, 09:32 AM
Wet floorboards is likely the sunroof drains. Clean the slits in the rockers where they drain from the body, that fixed Emma's on the D.S., but the P.S. still gets wet some only during DOWNPOURS. I suspect there's a plastic part that in the sunroof pan that is warped per some threads I have seen, so that will be the next steps for us to get rid of in-cab moisture.
 R
Sorry for the hijack Jon.
"Ramon" Weller
'78 FJ40 - Dune Beige - SOA (FJ55 rears, flipped fronts), SM465, MT Tube Fenders, MT Family Cage, 35x10.5 BFG MT, Aussie Rear, ARB Front, Saginaw, 8274-50, homebrew bumpers
Olde North State Cruisers - "And if I die in Raleigh, At least I will die free"
08-05-09, 09:36 AM
Good info Ramon...I need to do this on the PS...but the 80 hardly ever sees rain  .
Jon
08-05-09, 10:42 AM
I have a PPG windshield in my 80 with no issues. It was replaced before I bought it.
We replaced the windshield in the 100 with a PPG and it is also fine. I believe we used Raleigh Glass who I think also repairs windshields for Fred Anderson. The tech was very helpful with diagnosing a previous bad install which caused wind noise and water leaks. I can check when I get home if we have the particular tech's name for you.
The previous windshield in the 100 was not a PPG and was not properly installed (maybe only glued and no gasket?). I think it was done by Glass Masters. I can try and confirm later today.
I would highly recommend buying the necessary seals from Fred Anderson, but the PPG windshield should be OK.
Clint and Stacy
1997 FZJ80 (his), 154k, lockers+cdl+pin7, ome 851/863, hanna sliders, 285 nitto at's, hir's, led's, seat recline mods, slowly becoming not-so-stock dd
2000 UZJ100 (hers), 92k, slee step sliders, hir's, led's
08-05-09, 11:01 AM
This info sounds good and what I was looking for Clint...I'll stay tuned to see what you can find tonight.
Jon
08-05-09, 12:32 PM
#10 (permalink)
Chad Cox - 336-416-0911 is my brother in law and has been installing glass for 12-15 years or more? He owns "A Touch of Glass" and he will guarantee your window won't leak!! (He uses MORE sealant than alot of other guys / it costs him more but worth it in the end)
I am 90% sure he put one in my 80 series before I traded it to a guy in TN. He has done all my glasswork over the last 10 years, never a leak in any of em.
Guarantee he will do you right on the price too
FOREIGN CARS ITALIA won't let anyone else touch their glass work and he does everything for Rice Toyota Auto body shop too... but going direct to Chad will save you BIG $
Sam
2004 Lexus GX470 (120 series!!) No lift except the air system, not sure it will see anything except OBX sand!!
08-05-09, 07:23 PM
#11 (permalink)
I spoke with my neighbor Will @ Absolute Vision (919) 771-7986. He wasn't home (at beach)but said he would get back to me with a price, so i will let you know what he says. He does do good work.
Eric J
08-05-09, 09:50 PM
#12 (permalink)
Unfortunately, I looked and couldn't find the receipt for the 100's windshield. I'll keep looking. From the checkbook the cost of the windshield and install was about $240. I think the gasket from Toyota was about $75.
Clint and Stacy
08-06-09, 01:10 AM
#13 (permalink)
PPG with the OEM seal. I had one of the PPG Prostar dealers do the work, so far, so good. The OEM gasket is way better than what the aftermarket installers use fo sho.
As long as you make sure they use the glue on both sides like every body else said, you'll be fine. You might get lucky, but if they don't, it most likely will leak. The installers will act like it is a big pain in the ass and won't want to do it, and sometimes won't even if you ask them to.
Alex
トヨタ ランドクルーザー
'76 Yella FJ40 短いバス
'94 FJZ80 Cummins 4BTA Conversion
'07 Tacoma, stock but locked
Ronaldus Magnus
It has been said that politics is the second oldest profession. I have learned that it bears a striking resemblance to the first.
08-12-09, 06:02 PM
#14 (permalink)
Jon, $175.00 installed using ppg glass and you can add $32.75 if you need a replacement toyota oem gasket.
update, I forgot to mention this:
there is a bronze tint and a blue/green tint that was used from the factory based on the color of your interior. The bronze is more expensive ($20.00) so there might be bump in the price, but i thought he quoted me bronze.
Eric J
08-12-09, 06:15 PM
#15 (permalink)
Wow that is much cheaper than I expected I will keep him in mind.
Greg
95 FZJ80, "D" light works...oh and a few other things
92 P/U, 1KZ-TE/R151F 5 Speed M/T Diesel, 2" OME, 255/85/16, DD. July ROTM
79 FJ55, 2F w/1.5F Head and 3FE manifolds, H55F/Split Case, Factory PS, Rusty but I'm working on it...
08-12-09, 07:14 PM
#16 (permalink)
Thanks Eric. PM me the guy's contact info and I'll work with him on setting up an appointment in the next few weeks.
Jon
08-12-09, 08:03 PM
#17 (permalink)
see post #11
i didn't remember the year of your cruiser so i told him mine 94' , but it should be the same. he is the my daughter's friends dad, so if he forgets my name just tell him Hannah's dad.
Eric J
