TLCA.org
Go Back   IH8MUD.com > TLCAForum.com > Toyota Land Cruiser Association Forum > North American Clubhouses - East Region > NC- Olde North State Cruisers
Old 07-31-09, 06:35 AM   #1 (permalink)
southerncruiser62's Avatar
TLCA# 17608
Head Gasket Replacement-FJ55
Alright so some of you have probably been wondering why I haven't been doing keeping up on the board recently, well it's because for whatever reason I am bound and determined to make something of this here 55. I know I had mentioned that in the past I had been having cooling problems with the truck and thought after replacing the thermo and hoses that the water pump may have been clogged. Well it turns out that from the boiling coolant in the overflow container that the head gasket was gone, well actually the head gasket was fine it was a cracked head. So with the help of a few of our members I was able to located the sought after 1.5F head which in my case with the 79 block increases the compression slightly. Josh in High Point was able to help me out and I thank him for that. So then it was off to the machine shop for a magnaflux, new valve seats, seals, springs, and valve regrind with a small decking of the head. In the meantime I figured why not just start this project from the inside out, so new alternator, regulator, and water pump. Here's a few pictures to get started. Last photo is the common oil galley plug mod.
Greg
95 FZJ80, "D" light works...oh and a few other things
92 P/U, 1KZ-TE/R151F 5 Speed M/T Diesel, 2" OME, 255/85/16, DD. July ROTM
79 FJ55, 2F w/1.5F Head and 3FE manifolds, H55F/Split Case, Factory PS, Rusty but I'm working on it...
southerncruiser62 is offline   Reply With Quote
Old 07-31-09, 06:39 AM   #2 (permalink)
TLCA# 17608
Reinstallation
So next up was to reinstall everything, so starting with a 1979 head gasket as JimC said always match the head gasket with the head but in this case because the cylinder walls are larger than that of a 74 it required that I use the 79 gasket. Second Photo is where the oil galley hole to get oil to the rocker arm is, always need to make sure that isn't blocked when reinstalling the head gasket. Following that was a re-torque of the head and rocker arm installation. Be sure when installing the rocker arm to loosen the valve set screws so the valves seat properly then readjust for FSM specs.
Greg
Old 07-31-09, 06:45 AM   #3 (permalink)
TLCA# 17608
More Reinstallation photos
So once the rocker arm was installed I moved on to the intake/exhaust. I was in debate on what to do here but since I had already put more into it than I anticipated I had decided to go back with the factory intake and exhaust, after getting it installed I found that the surface needed to be milled .003 and that was going to cause a problem. Not to mention the 6 potential areas for exhaust leaks through the combo. Well this led me to searching for 3FE manifolds which a IH8MUD member in OR was able to ship to me. I clearanced the mounting holes to match up with the 2F intake manifold and bolted here up. What made things interesting is that the seller didn't send the flanges to I had to have some made. Then off to Henry Muffler for a Y-pipe and installation.
Greg
Old 07-31-09, 06:48 AM   #4 (permalink)
TLCA# 17608
Few More Photos
Y-pipe and flanges, then off to the top side for carb installation, DESMOG, and air cleaner install. The Desmog went much smoother than I anticipated after trying to guage everything through the diagrams JimC and others had posted. I may reroute a few lines but all in all it was not to bad.
Greg
Old 07-31-09, 06:58 AM   #5 (permalink)
ONSC-Event Co-Ordinator
GarnerFJ40's Avatar
TLCA# 17351
That engine is looking nice....
Brian, Heather, and Lily
1974 FJ40 JD Green, list too long but it's drivable
1995 FZJ80 Black, knuckle rebuild done, lift next
1974 FJ40 White,Back Axle removal,tub restoration
ONSC, UC, MATLCA
GarnerFJ40 is offline   Reply With Quote
Old 07-31-09, 07:09 AM   #6 (permalink)
77cruiser's Avatar
the cleanliness makes me jealous. I belive my trucks have not been desmogged. This helps a good bit with Gas mileage right?
Josh Jones
77 Yellow FJ40
2.5OME, Custom bent Front bumper and rear tire carrier,33x10.5 BFG m/t's, Arb in rear
89 FJ62
33"s, arb's front and rear, slee tire carrier, arb bull bar w/9500xdi,engel Fridge.
Charlotte, NC
GO WOLFPACK!
JoshJones77@hotmail.com
77cruiser is offline   Reply With Quote
Old 07-31-09, 07:33 AM   #7 (permalink)
TLCA# 17608
I think more than anything it lets the engine breath better and increases performance, I don't think you will see a drastic improvement in MPG though
Greg
Old 07-31-09, 10:36 AM   #8 (permalink)
S4Cruiser's Avatar
TLCA# 18505
That's alot of progress and a super clean engine.
Did you paint the valve cover or is that just the look after blasting?
Jon
'97 40th OEM Locked - F.O.R. GEN II - CDL - 315 Toyo MTs - slee'd - ipor'd - custom drawers
'74 40 - lifted, locked, PTO'd, 4+ rear bumper, 4+ flip kit (F&R), and other stuff
'06 Chevy Duramax - DD and Tow Rig
S4Cruiser is offline   Reply With Quote
Old 07-31-09, 11:10 AM   #9 (permalink)
TLCA# 17608
It is painted with Heat temp. paint for up to 2000 degrees. as is the manifold and thermo housing. They were all sandblasted prior to painting.
Used the same paint for the head, manifolds and flanges.
Greg
Old 07-31-09, 01:14 PM   #10 (permalink)
Mtbcoach's Avatar
TLCA# 17784
Garage
Damn Greg, you said it would look nice and you didn't lie. Very nice work, glad it all came together despite all the hurdles you had to jump through. Very well done...
Jerry - Olde North State Cruisers TLCA Delegate
'07 GJS15 well enhanced
'97 FZJ80 40th OME J
'71 FJ40 stock
Train Hard, Rest Harder
TLCA 17784 - FCC KJ4KGF
Mtbcoach is offline   Reply With Quote
Old 07-31-09, 03:53 PM   #11 (permalink)
rutbeer's Avatar
Awesome. Congrats on getting it back together. When I put my head back on, I found that one of the lifters had jumped slot on me.......lots of fun taking things back apart to get the lifter back in.
So....where's the turbo on this truck?
78FJ40 13B-T, 5speed, split, full floater 70 series, cable lockers,4 disk, a/c, 60 pwr steering, all toyota except the a/c.
www.importpurist.com
Oh, and a bitchin FJ45 that may or may not be for sale.
"Much like a cat or hot buttered toast, the correct side will always try to land down. If the bezel is on upside down, then the force of it trying to right itself may cause you to roll your cruiser unexpectedly."
rutbeer is offline   Reply With Quote
Old 07-31-09, 05:49 PM   #12 (permalink)
TLCA# 5330
Darn Greg, engine almost purdy enough to eat off of now.
Proud Patriot Guard Rider
Only two defining forces have ever offered to die for YOU, Jesus Christ and the American GI.
One died for your soul and the other for your Freedom
Looking for a hardtop for a 45 lwb. Along with all hardware.
krzyabncanuck is offline   Reply With Quote
Old 08-01-09, 05:12 AM   #13 (permalink)
little_joe's Avatar
TLCA# 10568
I totally dig the masking-tape block-off and the open air intake. Bet those mods get ya 11hp!
Joe
Olde North State Cruisers of NC
1995 FZJ80, locked, 228K and counting
295/75R16 Hankook MT, FOR cut down to 2.5", 4x4Labs rear bumper, Corbeau Sport Seats
little_joe is offline   Reply With Quote
Old 08-01-09, 07:23 AM   #14 (permalink)
diggity's Avatar
TLCA# 18745
Looking good Greg, let me know if you ever need a hand working on something. I am happy to help.
diggity is offline   Reply With Quote
Old 08-01-09, 04:41 PM   #15 (permalink)
ONSC triad VP
jfz80's Avatar
TLCA# 16634
looks great greg!
You guys are makin me jealous... gotta get a move on to have the piggy at our URE ride.
Whats the benefit of the 3F manifolds ?
Ive read so much im bout blue in the face but ive read of putting 3F heads on a later 2F but i didnt think a 79 qualified for that (thats what im building) again it looks great, youve got to love having that behind you and getting on or one step closer to the road.
Jason---- I live vicariously..........................through myself
__________________________________________________ __________
95 80 -- Slee4''/omeJ, 37's, factory locked, full armor and a s/c too
72 55-- w/ 76 4sdp 78 f. disc 79 2F -- SOA + 3'' w/ 35's, IPOR protection
92 P/U -- no "D" light, no umph, no fun except at the pump
jfz80 is offline   Reply With Quote
Old 08-01-09, 10:44 PM   #16 (permalink)
TLCA# 17608
well actually because the 79 has the domed pistons and a larger chamber head the early model F heads won't work. However because the late model 1973 and the 1974 had the 1.5F head and smaller domed pistons than the earlier models along with the enhanced oiling system for the rocker arms the 73-74 1.5F heads are ideal for the later blocks 75-80. Also with the large cylinder and domed pistons coupled with the smaller chamber on the 73-74 heads you increase your compression.
On to the manifolds, well for me it was the decison that besides the flanges and the head there were no other opportunities for exhaust leaks. With my original intake/exhaust combo I had the following potential leaks:
-Head
-Rams Horn and each end
-heat riser plate and bushings-both top and bottom gaskets
-Second 1 to 2 exhaust coupling
-Finally the downpipe flanges
To me the benefit of better flow and less potential leak areas warranted the enhancement. Granted I had to modify the exhaust slightly, but now I have a new stailess exhaust front to rear.
She has been back on the road for a quick trip around the neighborhood but now I am working on the rear spring to get it tempororarily fixed to make sure all else is fine and then come the suspension mods.
Greg
Old 08-02-09, 06:05 AM   #17 (permalink)
Mtbcoach's Avatar
TLCA# 17784
Garage
Since that last post is so late, I'm hoping you weren't spending that whole time getting the shackles free. I didn't see anything on the news about a car fire so I'm assuming you were either successful or ran out of gas...
'71 FJ40 stock
Old 08-02-09, 06:51 AM   #18 (permalink)
TLCA# 17608
Succesful, I'll probably be coming by later to get the spring welded up if thats alright.
Greg
Old 08-02-09, 08:35 AM   #19 (permalink)
Mtbcoach's Avatar
TLCA# 17784
Garage
No problem, glad you got it free...
'71 FJ40 stock
Old 08-02-09, 09:20 AM   #20 (permalink)
1974FJ's Avatar
Holy Crap, thats sweet Greg! Good work!
Martin Hovis
1974 FJ40, Freeborn Red, 4BT, NV4500, Dana300, SOA, 35s, Locked...In Progress
1977 FJ40, Smurf Blue, 2.5 lift, 33s.
"Correct me if I'm wrong Sandy, but if I kill all the golfers, they're gonna lock me up and throw away the key"
1974FJ is offline   Reply With Quote
Old 08-02-09, 10:17 AM   #21 (permalink)
ONSC triad VP
jfz80's Avatar
TLCA# 16634
Yeah I had wanted to get an F.5 head for my build to bump up compression but the one i had is an early head and each one i found locally were also early F's; plus i had a perfectly good matching 2f head. Now you got me wondering about my manifold decision; so much for the budget rebuild
Old 08-02-09, 10:52 AM   #22 (permalink)
TLCA# 17608
I don't want to start about budget, I never intended on taking this as far as I did but I thought. I am already here might as well not do it twice......then I am reminded about that top right gear.....
Greg
Old 08-04-09, 11:53 PM   #23 (permalink)
ONSC Vice-President
Fort Knox's Avatar
TLCA# 6318
Awesome Greg! Agreed on your decision to do it right and not regret doing things differently. I assume there are no more cooling issues now, right?
Allen
1995 4Runner UnLimited - "Fort Knox" - SAS'd, Marlin’d, Locked, Warn'd, Snorkeled & Dented.
1977 FJ-40 - Stock
2007 Tundra CrewMax - Daily driver / tow rig
Fort Knox is offline   Reply With Quote
Old 08-05-09, 09:18 AM   #24 (permalink)
concretejungle's Avatar
TLCA# 14646
J, stop thinking about head and get that thing finished!!
95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 35" truxus, Aussie locker-rear, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . .
Go 80, or go unsatisfied
concretejungle is offline   Reply With Quote
Old 08-07-09, 04:51 AM   #25 (permalink)
TLCA# 17608
well, first day back on the job and she did well.....and damn that 5th gear is cool. It's nice to be cruising 75 and only taching a little over 1,800 RPM's. It's tempting to put her on the highway sunday morning and head west.
Greg
Old 08-07-09, 12:48 PM   #26 (permalink)
uzj100's Avatar
Great work! Need more pics.
How rare are 5 speed 55s? Was it an option?
00 - UZJ100 - Step Sliders, Diff Drop, 865s, FRB's, BAK - 285/75 R 16
03 - UZJ120L
uzj100 is offline   Reply With Quote
Old 08-07-09, 01:19 PM   #27 (permalink)
rutbeer's Avatar
How many states will you go before you stop?
Old 08-07-09, 01:21 PM   #28 (permalink)
TLCA# 17608
This time round might not be best to leave the state....
Greg
CONTACT US AT MEMBERSHIP@TLCA.ORG
