04-16-09, 09:36 AM
40 Rear Frame Advice/Thoughts Needed
My 40 has a near perfect frame except in the rear - where the gussetts mount to the crossmenber. It's not that bad but needs attention. My first thought was to do some clean up hopefully see that it would be ok and POR15 it for the time being.
Well the more cleaning I did the worse it started to look. Now I'm leaning towards replacing the rear two gussets and crossmember with these;
- eBay Motors: TOYOTA LAND CRUISER--Landcruiser FJ40 R.Frame SUPPORTS (item 260358553306 end time May-07-09 16:23:38 PDT)=
- FJ40 Rear Frame Member (This one already has the holes for mounting my 4+ bumper/tire/cooler carrier)
The spring hangers and rest of the rear frame are super solid and look good.
The one trick is I'd "like" to do this with the body on the frame. I really don't want to remove the tub...
Any insight, suggestions, advice. Help is something I'll definitely need if I take this on. I've got the tools and if not I'll just buy them  .
Pics -
Jon
Olde North State Cruisers
'97 40th OEM Locked - F.O.R. GEN II - CDL - 315 Toyo MTs - slee'd - ipor'd - custom drawers
'74 40 - lifted, locked, PTO'd, 4+ rear bumper, 4+ flip kit (F&R), and other stuff
'06 Chevy Duramax - DD and Tow Rig
04-16-09, 02:25 PM
As you seen in my build mine was even worse than yours. I had gotten the pieces from the same place on ebay and have not mounted them on pernamently yet but they seem to be a good fit, as all of the holes line up. I also got the rear frame piece from them.
As for doing it with the tub on i am not too sure about. I took an angle grinder to my rivets and they were still a pain to get out. Hopefully some one else here has tried with the body on.
Proud Patriot Guard Rider
Only two defining forces have ever offered to die for YOU, Jesus Christ and the American GI.
One died for your soul and the other for your Freedom
Looking for a hardtop for a 45 lwb. Along with all hardware.
04-16-09, 02:32 PM
Just thinking out loud here but what if you left it alone for now, maybe coated with POR-15 and then ran a scab plate from where the gusset came into the rear crossmember on each side, bolted it out from the crossmember side in the bumperett holes and hitch bolt holes....structuraly improving it in the interim till you plan to take the bed off?
Greg
95 FZJ80, "D" light works...oh and a few other things
92 P/U, 1KZ-TE/R151F 5 Speed M/T Diesel, 2" OME, 255/85/16, DD. July ROTM
79 FJ55, 2F w/1.5F Head and 3FE manifolds, H55F/Split Case, Factory PS, Rusty but I'm working on it...
04-16-09, 05:22 PM
This was another option that I had in mind too and after looking at the 24 rivets that would need to be ground off I might take this route. Seems much easier and should get me by for a year or so until I get the urge to take the thing apart and get the entire frame blasted and painted.
Jon
04-17-09, 08:00 AM
Downey also sells the rear bumper/frame.
Downey Off-Road
04-17-09, 08:19 AM
All you would really have to do is jack up the bed off of the frame, with the body mounts unbolted and then go at it with the grinder. I would take the extra step now and get the new steel in place instead of letting that stay there. It could end up messing up your rear frame horns that butt into the cross member. Just my 2 cents since I am working from the ground up and ran into that same problem when I first started this whole project. As I ground off the rivets on the top of the cross member to the frame, The frame was much worse and that continued to more and more to where I am now. The downey part looks pretty beefy and nice but gets away from the stock look a little. Just depends on what you want to do.
Spence Wilcox
2007 Silver FJ Cruiser MT
1974 Fj-40 in a million pieces for a ground up build
04-17-09, 11:55 AM
I looked at it again this morning and anything other than replacing them now would not be good enough and would eat at me until I fixed it. So at the least, I'll be replacing the gussetts...we'll see how the crossmember looks after I grind, drill, hammer, grind, drill, hammer, grind, drill, hammer, grind, drill, hammer, the rivets for the gussets out.
Jon
04-17-09, 10:34 PM
Good luck and slow and steady. Grind the heads flat and then drill. That is what worked best for me.
Spence Wilcox
04-18-09, 06:17 AM
You may want to see if someone with a smoke wrench will hit those rivets for you. I have done the grind/drill/punch method and it takes forever. I had a friend in Atlanta torch off my rivets for my steering box (previous truck) which took all of about 5 minutes, then a quick bump with a sledge.
78FJ40 13B-T, 5speed, split, full floater 70 series, cable lockers,4 disk, a/c, 60 pwr steering, all toyota except the a/c.
www.importpurist.com
Oh, and a bitchin FJ45 that may or may not be for sale.
"Much like a cat or hot buttered toast, the correct side will always try to land down. If the bezel is on upside down, then the force of it trying to right itself may cause you to roll your cruiser unexpectedly."
04-18-09, 03:36 PM
#10 (permalink)
Jon
04-18-09, 03:45 PM
#11 (permalink)
Looks good man.
Think you will be good now.
04-19-09, 08:33 PM
#12 (permalink)
ONSC-Event Co-Ordinator
Don't look at mine.... Nobody wants to know the evil that is lurking underneath...
Brian, Heather, and Lily
1974 FJ40 JD Green, list too long but it's drivable
1995 FZJ80 Black, knuckle rebuild done, lift next
1974 FJ40 White,Back Axle removal,tub restoration
ONSC, UC, MATLCA
05-06-09, 05:03 PM
#13 (permalink)
Update
I wire wheeled, sanded, degreased with trisodium phosphate, treated with ospho and POR15'd the rear 1/3 of the frame. Looks much better now and the rust should be stopped for a while with the POR. Not sure if I want to top coat the POR or just leave it. I doubt the frame will see that much sunlight and the truck is garaged.
I started bolting up the new rear gussets this afternoon and they are a pain to fit. One side went in eventually with a little dremel work to get the holes to line up perfect. The other side is a bit more of a challenge. I've given up for today in hopes that it somehow line up perfect in the morning...but I doubt it. My measurements are equal from each frame end to the bolt holes and the gussets are the same measurements so I'm clueless to why it won't align...
Anyways here are a couple pics of the POR'd rear frame.
Jon
05-06-09, 05:52 PM
#14 (permalink)
Looks really good Jon. I'm with you in there are times that giving a stubborn situation some time and space makes things go together easier...
05-06-09, 08:31 PM
#15 (permalink)
Lookin' good Jon.
 R
"Ramon" Weller
'78 FJ40 - Dune Beige - SOA (FJ55 rears, flipped fronts), SM465, MT Tube Fenders, MT Family Cage, 35x10.5 BFG MT, Aussie Rear, ARB Front, Saginaw, 8274-50, homebrew bumpers
Olde North State Cruisers - "And if I die in Raleigh, At least I will die free"
05-07-09, 04:22 AM
#16 (permalink)
Jon looking good, so did you get the bender?
Greg
05-07-09, 05:57 AM
#17 (permalink)
Not yet - still thinking about how much I want to spend. It seems like they very from a little to a whole lot. Any suggestions?
Jon
05-07-09, 07:12 AM
#18 (permalink)
Go with a floor mounted unit, I will check and see what Christopher is using in his shop, I believe he said it was around $800 for the bender and the 1 3/4" die.
Greg
05-07-09, 05:10 PM
#19 (permalink)
Finally got the other gusset fitted and mounted. A little cutting and grinding was all it needed.
I can finally rest easy now that it's fixed the right way...
Jon
05-08-09, 08:41 AM
#20 (permalink)
NICE!!!!!
 R
"Ramon" Weller
05-08-09, 08:50 AM
#21 (permalink)
Yup, looks pretty sweet. Job well done...
05-08-09, 04:01 PM
#22 (permalink)
Darn that looks good to go now for along time.
