04-12-09, 08:25 AM
#91 (permalink)
Looking good Martin.
05-07-09, 09:06 PM
#92 (permalink)
no updates at the moment Ramon, I just finished school for the summer so i am starting to get back to work on the cruiser. Right now, im working on the rear axle getting it centered under the cruiser and the correct pinion axle set. Im going to point the rear pinion at the t-case and run a CV on the T-case. Then i will move up to the front of the cruiser and work on the front driveshaft(which will most likely be a 2 piece) and working on the PS and hydroboost. after that ill most likely move to the body....I hope to get some things done tomorrow and saturday b/c im headed back to raleigh to work for half the summer.....ohwell!
Martin Hovis
1974 FJ40, Freeborn Red, 4BT, NV4500, Dana300, SOA, 35s, Locked...In Progress
1977 FJ40, Smurf Blue, 2.5 lift, 33s.
"Correct me if I'm wrong Sandy, but if I kill all the golfers, they're gonna lock me up and throw away the key"
05-08-09, 07:08 AM
#93 (permalink)
Olde North State Cruisers
Where are you going to be working? Can you elaborate on the front ds?
 R
"Ramon" Weller
'78 FJ40 - Dune Beige - SOA (FJ55 rears, flipped fronts), SM465, MT Tube Fenders, MT Family Cage, 35x10.5 BFG MT, Aussie Rear, ARB Front, Saginaw, 8274-50, homebrew bumpers
Olde North State Cruisers - "And if I die in Raleigh, At least I will die free"
05-08-09, 09:07 AM
#94 (permalink)
WOW...what a great job...this thread has been fun to follow...you have given me some ideas...look forward to seeing the final product!! cheers
67 FJ40 F engine...mostly stock
"Over?..did you say over?..nothing is over until we decide it is..."
05-09-09, 02:55 PM
#95 (permalink)
Ill be working for the BAE department at State. I will be doing alot of traveling across NC looking over stream and wetland designs, and monitoring of these areas.
I got the rear axle completely welded up and the spring perches set. I set the pinion ~1* below the yoke of the transfercase b/c i will be running a CV from the t-case.
I also rolled the cruiser out of the shop to clean the shop of all its grinding dust that is everywhere!!! So i decided to make another video of it running so you could hear it better...enjoy
I think you can hear the turbo....haha (its open exhaust and no filter, plus the charged air is not directed to the intake manifold so the turbo is wide open, youll see)
Video outside the shop!!
Martin Hovis
05-09-09, 03:22 PM
#96 (permalink)
ONSC-Event Co-Ordinator
38.5 inches work for you? I noticed you put your rear anti-inversion shackle bolts on the same way you put mine on!
Brian, Heather, and Lily
1974 FJ40 JD Green, list too long but it's drivable
1995 FZJ80 Black, knuckle rebuild done, lift next
1974 FJ40 White,Back Axle removal,tub restoration
ONSC, UC, MATLCA
05-09-09, 05:22 PM
#97 (permalink)
Its either my way or no way!! haha
Yep, 38.5" inches worked out just right, thank you for that!
Martin Hovis
05-09-09, 08:05 PM
#98 (permalink)
Hope you are putting a trac bar on the rear end. Otherwise, el snappo senior pinion. Dang dude....that truck sits very high....or your dad is very short.  Seriously, bad ass.
78FJ40 13B-T, 5speed, split, full floater 70 series, cable lockers,4 disk, a/c, 60 pwr steering, all toyota except the a/c.
www.importpurist.com
Oh, and a bitchin FJ45 that may or may not be for sale.
"Much like a cat or hot buttered toast, the correct side will always try to land down. If the bezel is on upside down, then the force of it trying to right itself may cause you to roll your cruiser unexpectedly."
05-09-09, 09:53 PM
#99 (permalink)
haha, my dad is only 5' 3" so that is likely.
And yes a trac bar is in the works, no worries.
Martin Hovis
07-07-09, 09:58 PM
#100 (permalink)
Home for a month I think. Just got started back on this thing.
Got my saginaw box mounted after making a plate for it. BTW, cutting the hole out for the steering shaft to go through, not that easy! You def need a large holesaw or plasma or torch.
Here is where i relocated the factory frame boxing piece to the passenger side. Thought it was a neat idea.
Martin Hovis
07-08-09, 05:27 AM
#101 (permalink)
also adds strength obvisously, so in a month are we going to see this thing back around Raleigh?
Greg
95 FZJ80, "D" light works...oh and a few other things
92 P/U, 1KZ-TE/R151F 5 Speed M/T Diesel, 2" OME, 255/85/16, DD. July ROTM
79 FJ55, 2F w/1.5F Head and 3FE manifolds, H55F/Split Case, Factory PS, Rusty but I'm working on it...
07-08-09, 06:45 AM
#102 (permalink)
URE run in September...
ONSC, UC, MATLCA
07-08-09, 07:35 AM
#103 (permalink)
For that matter Harlan in October, I think that was his goal.
Greg
07-08-09, 09:03 AM
#104 (permalink)
Martin, I really like where you placed that box, further recessed in the frame. Things to watch for: will the pittman arm contact the DS spring on compression and full lock to the left? Will the tie rod contact the PS frame rail on full compression. Issues I am dealing with, but the placement of your box really helps. Are you going to do a shackle reversal?
 R
"Ramon" Weller
07-08-09, 12:17 PM
#105 (permalink)
Ive debated heavily on the SR!!! And I still dont know yet. Thanks for the advice.Once i decide on the SR i will clean up the front springs and start flexing it out to see what issues i may have.
Greg, back in raleigh before 2010 for sure.....................I hope haha
Brian, september is pushing it
Greg i plan to finish for the Harlan trip..........and will need trailer spot
Martin Hovis
07-08-09, 01:50 PM
#106 (permalink)
How does that crimp bender work for you compared to the mandrel ones? I've heard of guys filling the tube with sand and temporarily capping the ends to bend without distortion.
07-08-09, 02:47 PM
#107 (permalink)
It doesnt work well. Ive had that thing since i built my tube doors 4 years ago. Its a pipe bender and the metal flattens and wrinkles really quick. I have heard of filling with sand too but never tried it. I dont expect to use that thing again, haha.
Martin Hovis
07-08-09, 03:32 PM
#108 (permalink)
Martin, let me know about that taurus fan. It'll save me a trip to the junkyard...
ONSC, UC, MATLCA
07-13-09, 12:47 PM
#109 (permalink)
Sure will Brian. Im working on that here soon so i will know for sure shortly.
Thanks to Jonathan Malphrus, Ive got some 55 springs in the near future........Appreciate!
I got my tranny hump patched up for the new tranny shifter hole and the all-so-different t-case shifter spot. My dana300 twin stick setup(jbfab.net) was a really sweet setup, real high quality and shifted great! Its all stainless and looks great. I had to grab some stainless wire and weld up a different design to work for my fj. If my fj didnt have a long nv4500hd and and a dana300 clocking ring then i could run the twinsticks like JB-Fab made them, but i had to modify.
I really wanted to run the shifters out of the stock TLC shifter hole but felt better about how i have them now. It look awhile to get the hump patched up to work and look right. Once i get the hump at 100% done, im gonna cut out a plate that will hold both the T-case and tranny shifter boots down and look pretty cool i hope. Stay tuned for that....
Martin Hovis
07-13-09, 12:57 PM
#110 (permalink)
Martin Hovis
07-22-09, 08:06 AM
#111 (permalink)
Got my steering worked out...
I used a bearing i had laying around and some others i gathered. Pretty happy with it..
Made this plate to bolt to the firewall and to also accept my bearing..
Martin Hovis
07-22-09, 08:07 AM
#112 (permalink)
Here is the shaft coming out the firewall, i actually had to straighten this shaft because it was badly bent from the wreck i had.
Plate installed:
Bearing installed:
Shaft:
Martin Hovis
07-22-09, 08:09 AM
#113 (permalink)
Martin Hovis
07-22-09, 08:10 AM
#114 (permalink)
Hydroboost system is complete....took some work but i got it...
This is the original pin that connects the brake booster and brake pedal.
With the hydroboost system, i needed a different pin to make it work since this system had a different arm.
This is the original LC pin in the hydroboost system arm. Hard to see in the picture but the pin is far to small and its too wide to actually reuse. so i had to turn a new pin that would work..
new pin:
Martin Hovis
07-22-09, 08:11 AM
#115 (permalink)
This new pin will not use the cotter pin design, rather it is threaded and i have a ny-loc nut for it(3/8th 16). the first shoulder past the threads is for the brake pedal, the second is for the hydroboost arm(not turned to the exact size to allow it to move side to side, keeps it from binding). then the large shoulder with the flat sides is for holding the arm on and for holding while i tighten the nut, and ofcoarse the last section is to hold the brake pedal spring. Works great! very happy..
Martin Hovis
07-22-09, 08:12 AM
#116 (permalink)
Booster:
How the original brackets were for this unit before i cut them off to make my own mount which mounts the booster closer to the firewall.
Mounted:
Martin Hovis
07-22-09, 08:12 AM
#117 (permalink)
Mounted:
Martin Hovis
07-22-09, 08:43 AM
#118 (permalink)
Looking good martin, keep up the good work.
Greg
07-22-09, 08:56 AM
#119 (permalink)
Using that nogin' for something besides a hat rack... me likes. Did you get the 55 bushings straightened out?
 R
"Ramon" Weller
07-22-09, 09:31 AM
#120 (permalink)
haha, yea mostly a hat rack,
Got the bushing worked out, the part number from sor.com #289-55-A (which is a 1 1/8 OD and a 9/16 ID). The springs are in my shop right now and look great, im gonna hang them once i get my bushings and then mount my trac bar, shock mounts and then the ebrake cables.
I ordered rear quarter panels and my gas tank and a few other cosmetic stuff. I basically got everything in on monday but the quarter panels(which is what i really want). Ive got a friend (Will Carter, Raced 52x in the 09' KOH) who has a line-x business thats fixin to open in burlington in a few weeks, and he is gonna spray the tub for me. So im trying to get the body work done before i go back to school.
Martin Hovis
