Awl_TEQ
Supporting Vendor
Edit Oct 28, 2020 - this it the old thread - see here for updated info -> Awl_TEQ Metal Parts etc.
I have started this thread to showcase a few things I have made for myself and others during the rebuild and modification of my 45.
Hopefully most of you have seen my reproduction LPB bed thread (link in my sig) and my winch rebuild and subsequent aluminum solenoid cover thread in this section. These products are representative of the type of things I can make. The proceeds of anything I sell go directly into my ongoing BJ45 resto-mod.
To start this thread off I have just finished a small run of 40 series 3B motor brackets. These are the brackets that rivet (or bolt or weld) to the frame rails and will locate your 3B conversion with the correct offset and height when welded or bolted in the correct spot . I made a set for myself a while ago and below you will see them in use. They are 3/16" thick and identical to the original in all respects.
These are offered at $90.00 a set plus shipping
In the center is a factory set I used to build from. The "top plate" is not welded on yet in this pic.
Left side
Left side
