Go Back   IH8MUD.com > classifieds.ih8mud.com > Vendors Market > Merchandise Storefront
Old 08-15-09, 10:44 AM   #1 (permalink)
orangefj45's Avatar
split case twin-stick kits!!!!!
i've been tinkering with this idea for quite some time now and have built a few prototypes. now i finally have a design that i'm happy with so i thought i'd start selling them.
the kits come in two versions:
1) standard kit for single t-case setups. this kit is designed to be used with long and short h42, h41 and h55f transmissions or conversions where a single split transfer case is being used. the cost for this kit is $209.98
2) the "doubler" kit. this one is desinged for guys using the 203 grb units, toyboxes or any other application where more than one transfer case gear reduction unit or doubler is being used. the cost for this kit is $229.98
both kits are in stock and ready to ship; shipping is $12 flat rate anywhere in the usa. i can ship international orders as well but shipping is obviously more expensive.
these kits are loosely based on the AA twin-stick kits for the earlier one-piece fj40/45/55 transfer cases. i have modified a few of the components as well as adding a few of my own. all parts are available seperatley. the kits include everything you need to convert your existing shifter setup to a twin-stick system. also included are the shifter boots and black plastic shifter knobs. billet aluminum shift knobs are available as well for a little more. some simple fab work and sheet metal modification is required for the shifters themselves.
i will write up a thread on here in the 60 forum the next time i install a set of these in a vehicle. it'll be step-by-step with lots of pics to hepl guide you thru the installation process.
here are a few pics of the standard kit installed on an h55f. the first pic shows the oem shifter setup, the next two show my twin-stick kit installed on an h55f trans and split case. both transmission/t-case combos in these pics were built by me for customers. the one in the top pic was installed by me in a customers' fj40. the one in the two bottom pics was shipped to IPOR where it's being installed into and fj40 as well.
georg @ valley hybrids
TLCA and PMC member
looking for Advance Adapters or marlin crawler parts? send me a pm!
bill dorry style ps brackets for sale:
http://forum.ih8mud.com/merchandise-...ml#post4481037
orangefj45 is offline   Reply With Quote
Old 08-15-09, 10:49 AM   #2 (permalink)
orangefj45's Avatar
here are a few pics of the 'doubler" twin-stick kit installed on cruiserdrews h41/toybox/split case combo. drew built the geartrain himself and then brought it to the shop where i built the twin-sticks for it. this combo will be going into drews fj60 project soon.
TLCA and PMC member
Old 08-15-09, 10:52 AM   #3 (permalink)
orangefj45's Avatar
fwiw, i will be building another split case with an AA adapter for a customer next week. he's requested a set of twin-sticks to go with the setup. i will be building this setup late next week and will post some pics when it's done as well.
TLCA and PMC member
Old 08-16-09, 10:28 AM   #4 (permalink)
Gobble Gobble Wut?
Spook50's Avatar
Sweet jebus that looks outstanding. Can't wait to see one available for A440F autos so I can do that on my 62.
That looks like a fantastic setup.
'88 FJ62 W/ 253K miles, desmogged, stock SUA W/ full length Add-A-Leafs, Tuffy console, LED interior lighting, Mallory ignition, Ford Contour electric fan, four wheel discs, Aussie sliding windows
Don't cry like a bitch when you feel the pain...
Spook50 is offline   Reply With Quote
Old 08-16-09, 10:30 AM   #5 (permalink)
No way Eh !!!
MANUCHAO's Avatar
I have an AA adapter and my current set up is not the best...
I like to see the AA adapter set up...
Im ignorant at this set up.. does this mean I could go to 4L with out having to go through 4H and N ?
Thanks !!
MaNu !!!
'85--FJ60-L59
E-mail: viviendo.de.mar.a.cordillera@gmail.com
Alaska bound * June 2009 !!!!
MANUCHAO is offline   Reply With Quote
Old 08-16-09, 10:51 AM   #6 (permalink)
Dynosoar's Avatar
TLCA# 17857
The far shifter is for 2wd - 4wd and the closer one is the range selector Hi - N- Low. I want to do this for my 700r4 I think it will fit I just need to do some measuring.
Dynosoar
'82 V8J60 - TPI 350 with a 700R4 attached to a splitcase, Cable Locker FF rear end, 4" SUA (National Spring), Copper Metalic Has been south to Cabo San Lucas, BCS and North to Port Angels,WA.
Call Sign: KI6SMP
Dynosoar is online now   Reply With Quote
Old 08-16-09, 10:51 AM   #7 (permalink)
orangefj45's Avatar
the standard kit will work with the 62 case and auto trans. i have a complete a440f/split case combo sitting on a pallet at the shop and could do a mock-up if that helps.
TLCA and PMC member
Old 08-16-09, 10:53 AM   #8 (permalink)
orangefj45's Avatar
Thanks !!
thanks for the reply and question. i have one of the aa th700/split case adapters at the shop, with a freshly rebuilt split case on it. i guess i could do a mock-up of for thie setup as well if time permits.
the twin stick offers a few benefits, one of them being that you can run the vehicle in "2 low".
georg
TLCA and PMC member
Old 08-16-09, 10:54 AM   #9 (permalink)
orangefj45's Avatar
Dynosoar
should definetly work!
georg
TLCA and PMC member
Old 08-16-09, 09:43 PM   #10 (permalink)
Rum Runnin'
GLTHFJ60's Avatar
TLCA# 17825
Garage
Would it be possible to buy the kit for just the transmission mated to the transfer case, and then later upgrade it to work with a doubler setup? I'd like to have this now but when I get a doubler I'd like to still use the same kit, even if I have to modify it a little bit.
Johnny C
Waiting to be installed:
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
GLTHFJ60 is online now   Reply With Quote
Old 08-17-09, 07:39 AM   #11 (permalink)
orangefj45's Avatar
good question!
yes, the standard kit can be upgraded to the "doubler" kit with just a simple mod. and all the parts are available seperatley so putting together and "upgrade kit" or "conversion kit" will not be an issue at all.
hth
TLCA and PMC member
Old 08-17-09, 09:17 AM   #12 (permalink)
67azcruizr's Avatar
TLCA# 18163
pm sent
59FST FJ25
62FST FJ40
63HT FJ40
64HT FJ40
Sean
all rigs are currently "soft tops"!
67azcruizr is offline   Reply With Quote
Old 08-17-09, 09:58 AM   #13 (permalink)
Rum Runnin'
GLTHFJ60's Avatar
TLCA# 17825
Garage
Originally Posted by orangefj45 View Post
good question!
hth
Damn. I was hoping you'd say no so that would be the only excuse for me not to buy this kit! Now I've gotta find something else to sell so I can buy this.
Johnny C
Previous Rig:
1987 FJ60 - Big Red
ΦΚΤ - Fall 06
Old 08-19-09, 03:19 PM   #14 (permalink)
vtcruiser60's Avatar
TLCA# 15129
Is this the space where I sign up for the vendor giveaway???
vtcruiser60 is offline   Reply With Quote
Old 08-19-09, 08:08 PM   #15 (permalink)
mwalls54's Avatar
TLCA# 19130
with the shifters not bent how do they fit in a 60?
74 FJ40 Mustard Yellow 2.5" procomp springs, rancho 5000s, sr5 seats, 32x11.50 BFG A/Ts awaiting 2f, h55f with split case to be installed.
87 FJ60 White 3"ome heavy,4plus flipkit, 33x10.50 BFG A/Ts on Eagle 589s, mwalls54 f+r bumpers with rock sliders/steps and rear 1/4 protection, mean green, H55f, hella h4 and 4000s, LED cargo lights. warn 9500ti, a lot of non usa parts on the dash.
WV Mountaineer Cruisers TLCA Delegate
Tornado Alley Cruisers
mwalls54 is offline   Reply With Quote
Old 08-19-09, 09:31 PM   #16 (permalink)
orangefj45's Avatar
nice try kieran!
but if i actually sell enough of these to make a profit, then i might just do an x-mas give-away.
so far i have well over $1k invested in parts to make the prototypes and a few kits. plus about 25 hours of R&D...........
TLCA and PMC member
Old 08-19-09, 09:33 PM   #17 (permalink)
orangefj45's Avatar
the shifters supplied in the kits are straight and need to be bent for each specific application.
TLCA and PMC member
Old 08-20-09, 06:37 AM   #18 (permalink)
copasspupil's Avatar
Did you get my pm?
Danno
Projects:
'66 mustang fastback - finished
'66 40 project - just getting started
'00 Toyota Avalon loaded with 40K miles - misses car
If you aren't living on the edge, you're taking too much room!
copasspupil is offline   Reply With Quote
Old 08-20-09, 07:27 AM   #19 (permalink)
orangefj45's Avatar
Originally Posted by copasspupil View Post
Did you get my pm?
sorry, i did not. might have gotten "lost" during the server issue. please send it again.
georg
TLCA and PMC member
Old 08-24-09, 03:45 AM   #20 (permalink)
Gobble Gobble Wut?
Spook50's Avatar
Oh cool. I thought the spacing was too far differentbetween the manuals and the A440F. Can't wait to get my Tcase rebuilt and order one of your kits. Now we just need someone to offer all the necessary parts as a vacuum to manual Tcase conversion kit
I assume the 62 application is one where the shifters will need to bebent, correct? Is it just a slight bend, or pretty drastic?
Old 08-24-09, 07:21 AM   #21 (permalink)
orangefj45's Avatar
somebody does sell all the parts; the dealer!
as for thr shifters, they need to be bent to suit each specific application; none of them will work with the straight shifters.
georg
TLCA and PMC member
Old 08-25-09, 01:32 AM   #22 (permalink)
IH8MUD VOYEUR
hicruise55's Avatar
TLCA# 17618
PM sent- Aaron
-'76 FJ55-ARB's/4x4labs/Longs/60ps/60axles/36's/SOA/H55/Custom Awesome Driver!
-Matching FJ55 Trailer-ARB RTT/ARB Fridge/Same 36's/ trailer-being setup for long range travel/Basecamp
-'89 FJ62-350/700R4/reversal/33's/18"Mojave's/blacked out
-'69 FJ40-Now on 40's/SOA/60 axles w-ARB's/60ps/ 60 springs/4x4Labs... installed soon
See my Land Cruisers Myspace @ http://www.myspace.com/hicruisefiftyfive
hicruise55 is online now   Reply With Quote
Old 08-25-09, 01:50 PM   #23 (permalink)
IH8MUD VOYEUR
hicruise55's Avatar
TLCA# 17618
PayPal sent! Thanks again Georg! Aaron
Old 08-25-09, 10:04 PM   #24 (permalink)
orangefj45's Avatar
thanks for the business and support guys, i do appreciate it!
TLCA and PMC member
Old 08-30-09, 09:38 PM   #25 (permalink)
orangefj45's Avatar
thanks for the orders guys. post some pics when you get them installed!!!!
TLCA and PMC member
Old 09-03-09, 05:58 AM   #26 (permalink)
TLC Norway's Avatar
nice, cant wait to do this on mine... 2low is nice!
OpenAir Garage, Norway, a HJ60 TDIC 81'
Updates to ih8MUD
My LandCruiser don't leak oil. It's just marking it's territory!!!
TLC Norway is offline   Reply With Quote
Old 09-03-09, 07:41 AM   #27 (permalink)
orangefj45's Avatar
here are a couple of pics of the linkage attachment point at the 2-4 shift rod.
i don't have written instructions for the kits yet but i will do my best to write up an install thread on here later next week.
TLCA and PMC member
Old 09-03-09, 07:54 AM   #28 (permalink)
orangefj45's Avatar
sorry about the blurry pics, i'll take more for the install thread.
georg
TLCA and PMC member
Old 09-03-09, 11:15 AM   #29 (permalink)
Got the kit and thanks for the help. Hope to install it tonight.
Danno
Projects:
Old 11-04-09, 07:33 AM   #30 (permalink)
orangefj45's Avatar
just sent out two more, thanks again guys!!!!!
TLCA and PMC member
