Go Back   IH8MUD.com > classifieds.ih8mud.com > Vendors Market > Merchandise Storefront
LinkBack (4) Thread Tools Display Modes
Old 01-14-09, 11:20 AM   #151 (permalink)
aclos3's Avatar
I bought it from a guy named "rut216," hopefully it works, I'd hate to have an engine code and not know whether I messed something up or just got a bad sensor. I believe I have some CRC carb/throttle body cleaner. Do you know if that will work for cleaning the sensor or is it too harsh?
Thanks.
-Andrew
1997 LX450, blue fan hub, Landtank MAF'd.
aclos3 is offline   Reply With Quote
Old 01-14-09, 12:51 PM   #152 (permalink)
The quick brown fox .....
Beowulf's Avatar
You can clean the sensor with brake cleaner if it is not too bad (and they usually are not that bad.)
-B-
97 FZJ80 - Locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, Warn M12000, OBA, Yaesu 7800, Outback drawers + other stuff. Transformation complete.
Old 01-16-09, 07:58 AM   #153 (permalink)
jamisobe's Avatar
I have been running around with this new MAF set up for about 2 weeks now and it feels great. I wish I had a way to measure the difference. But it is obvious from these 2 comparisons that the intake was opened up significantly:
You can see the narrowing diameter closer to the counter top.
Here is the outside shot of the narrowing diameter that is needed for this older style MAF sensor to get an accurate reading. The fronts are facing each other.
Thank you Rick for using your brain to figure this out and then sourcing it into production. If anyone is considering this modification you can add me to the long list of very happy customers who say do it.
95 FZJ80 headers, custom collector 2x2.25" into 3" Y-pipe, 3" Flowmaster/mandrel exhaust, LT MAF, 4" OME lift (with CC bushings, x br lines, adj panhards, heavier dropped sways), ARB lockers, 35" Toyo M/Ts, dual dry cell batteries, 2300 watt inverter, speedo corrected, & Kaymar w/carrier
jamisobe is offline   Reply With Quote
Old 01-16-09, 10:27 AM   #154 (permalink)
ThinkTank Waterboy
landtank's Avatar
Glad you like the improvement and thanks for the pictures.
I've always used CRC MAF cleaner and a small model paint brush to lightly sweep away any grime on the actual sensor. That's one of the benefits of this new sensor, it's out where it can easily be serviced instead of inside that "bullet" looking housing of the original.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 01-19-09, 04:18 PM   #155 (permalink)
Hate that mud...
TrickyT's Avatar
TLCA# 14435
Just a heads up for those of you in California (and maybe other states) when it comes to smog inspections. When you remove the vacuum hose to the fuel pressure regulator and plug off the connections, your vehicle is no longer compliant because it's been modified from the way it came from the factory - regardless of whether or not the mod has affected emissions. I failed visual inspection today because of this. However the guy I went to was quite nice when I explained what it was all about. He let me go next door to an auto parts store and grab 6" of 4mm tubing. I re-installed the vacuum control to the FPR, passed inspection, drove down the street for lunch, and then removed the hose and put back the plugs on the end of the vacuum lines. I'm just going to keep the hose in the center console from now on and reinstall it prior to an inspection.
I'm told it's possible to go to a special California Bureau of Automotive Repair "Referee Station" and have them exempt the FPR modification and then install a tamper-proof label saying that this mod is OK, if I can convince the the inspector that the modification will not adversely affect emissions. I may look into this in the future, but for now I'm busy with other projects.
Tom Ferrin
N6TEF - 2m and 70cm
1989 FJ-62 - 210K, 3" OME lift, recent engine overhaul, my daily driver
1997 FZJ-80 - 93K, lifted, bumpers, sliders, lockers, OBA, new HG, and Moab-trails tested
TrickyT is offline   Reply With Quote
Old 01-19-09, 04:44 PM   #156 (permalink)
Beowulf's Avatar
I would grab a 6mm hose (or whatever fits) and put it over the plugs which would make it look like the FPR was connected to vacuum.
-B-
Old 01-19-09, 05:46 PM   #157 (permalink)
Are these still available for purchase? If some are available, I want to buy one.
taccruiser97 is online now   Reply With Quote
Old 01-19-09, 06:02 PM   #158 (permalink)
Hate that mud...
TrickyT's Avatar
TLCA# 14435
-B-
I like it! Consider this done.
Thanks, B.
Tom Ferrin
N6TEF - 2m and 70cm
Old 01-19-09, 09:30 PM   #159 (permalink)
ThinkTank Waterboy
landtank's Avatar
a small bb in the original hose works well also.
They are still available also.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 01-20-09, 03:16 PM   #160 (permalink)
Payment sent via Paypal. Thanks.
Old 01-21-09, 12:11 PM   #161 (permalink)
aclos3's Avatar
Received my MAF yesterday and it looks beautiful. Hopefully my ebay sensor arrives today so I can install this after work. In Washington I don't believe we have visual inspections like you guys do in California, but I will consider it when I smog in early 2010. I've thought about just reinstalling the old original setup if it was an issue, but I like your fake out method Beowulf!
-Andrew
Old 01-21-09, 07:44 PM   #162 (permalink)
What is the current price on the modified MAF sensor housing?
Kernal is offline   Reply With Quote
Old 01-21-09, 08:24 PM   #163 (permalink)
ThinkTank Waterboy
landtank's Avatar
205.00 + 15.00 S&H
All info on first page.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 01-22-09, 04:38 PM   #164 (permalink)
george_tlc's Avatar
TLCA# 8068
Bad luck on the visual inspection. I just smogged mine in Sunnyvale a few weeks ago. No issue and passed with flying colours. Luck of the draw I guess. I'll have to remember to 'stealth' mine for next time
cheers,
george.
where ever you go, there you are....
'97 S/C White CE, locked^3, sliders,arb,kaymar, m12000,dual batteries, LEDs, etc..... ki6ibx
http://www.george4wd.taskled.com
george_tlc is offline   Reply With Quote
Old 01-26-09, 10:35 AM   #165 (permalink)
aclos3's Avatar
I installed the sensor and MAF housing before work today and I'm thrilled with the results. Just like everyone else is saying, it feels like the truck lost 500lbs or gained 20 horsepower. You really feel it in throttle response off the line and it pulls much harder in the middle of the rpm range. My slight idle stumble is completely gone. The installation was very easy with the provided instructions. I followed them all to the letter and when I started the truck with the new sensor, it fired right up and idled smoothly... I was at least expecting to have to go through a computer learning period.
Great product! After all shipping costs, I spent a total of $270 between the MAF and ebay OEM used sensor.
-Andrew
Old 01-29-09, 07:01 PM   #166 (permalink)
Rick,
PM sent. Hope there is one more.
LC newbie
Proud daddy of 3 boys and
85 FJ60, stock, 31" tires, 2" lift, RUSTY but runs, and
LX450, locked, Slee front bumper, DD
"The beatings will continue until morale improves!"
- an old Parris Island slogan.
reconranger is offline   Reply With Quote
Old 02-02-09, 04:31 PM   #167 (permalink)
ThinkTank Waterboy
landtank's Avatar
I've actually have 15 units in house and am not sure If I'll reorder. Not trying to push you just being up front.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 02-04-09, 05:23 AM   #168 (permalink)
Lugboot's Avatar
TLCA# 17677
PM sent. I'd like one.
Lugboot is offline   Reply With Quote
Old 02-05-09, 03:10 PM   #169 (permalink)
1973Guppie's Avatar
FYI, just got a used sensor shipped to my door for $40, it is from a scion, P#22204-21010, they guaranteed it is good and paid with CC so hopefully all will be ok, I found the salvage yard on Car-Part.com--Used Auto Parts Market, a great resource I have used before......
NEED A CRUISER MECHANIC?:http://forum.ih8mud.com/ca-san-diego...rlsbad-ca.html
Front disc brakes: http://forum.ih8mud.com/showthread.p...+brake+dummies
1973 FJ40 - Finished! Vortec/NV4500/ARB's/SOA
1970 FJ55 - Restoration project, 1996 FZJ80 - DD
FJ55 Restoration Thread: http://forum.ih8mud.com/fj55-iron-pig-preservation-society/102079-guppies-fj55-build-thread.html
FJ40 ROTW: http://forum.ih8mud.com/showthread.p...uppie%27s+fj40
1973Guppie is offline   Reply With Quote
Old 02-07-09, 02:45 AM   #170 (permalink)
Paypal sent, I cant wait, CEL came on and it saying its the MAF.
96 LX450, ELockers, OME lift, Safari Snorkel, BFG KO 285/75/16's
85 Mighty Max 2.3 HO Turbo Diesel, JK Dana 44 front and rear, 5.13's, Elockers, Fox Coilovers, and too much more to list.
spencevans is offline   Reply With Quote
Old 02-08-09, 05:32 AM   #171 (permalink)
Mad Jack's Avatar
TLCA# 15629
paypal sent...Thanks!
John
79 HJ45 Troopy
95 FZJ80 3x locked,cdl switch, LT MAF...
04 4Runner
Mad Jack is offline   Reply With Quote
Old 02-09-09, 11:35 PM   #172 (permalink)
arndog123's Avatar
Paypal'ed ya. I'm using my parent's address because I don't want my wife to find out. Going to see if she notices a difference.
1997 CE Land Cruiser: Locked, ARB w/ M12000
1996 LX450: Locked, ARB w/ no winch yet
1990 XtraCab 4x4 pickup: ARB w/ M8000
1986 Standard cab 4x4 pickup: Locked, ARB w/ XD9000
1985 XtraCab 4x4 pickup: ARB w/ M8000
1995 Acura Integra (Daily Driver)
arndog123 is offline   Reply With Quote
Old 02-10-09, 05:36 AM   #173 (permalink)
Lugboot's Avatar
TLCA# 17677
Paypal sent....one MAF housing, please!
Thanks!
Old 02-14-09, 09:15 PM   #174 (permalink)
rlabair's Avatar
PayPal sent for one MAF housing. Thank you.
rlabair is offline   Reply With Quote
Old 02-14-09, 11:09 PM   #175 (permalink)
1973Guppie's Avatar
installed yesterday and am really happy with the results, amazing how the engine runs even smoother now, pulls smoother up hill and downshifts smoother, I really don't even notice the tranny shifting now, It seems to even give it a little more power off the line for sure, overall well worth the $$, and I am a hard critic, I was a bit skeptical when I bought it, overall if you are looking for a huge power boost, this is not it, but it sure does help the engine run much better and overall perform better.......
FJ55 Restoration Thread: http://forum.ih8mud.com/showthread.php?t=102079
Old 02-19-09, 09:56 AM   #176 (permalink)
Lugboot's Avatar
TLCA# 17677
Just got this marvel of aluminum milling. What a great piece of work! Thanks, Rick!
Old 02-19-09, 09:07 PM   #177 (permalink)
rlabair's Avatar
Can anyone post up the installation directions from Landtank? I received both my MAF and sensor today but did not get the directions in the package that Landtank sent me. I've sent him an email but no reply yet and want to get the install done tonight. Thanks!
Everything seems pretty easy but I have questions on the wire re-arrangement he speaks of in thread #1.
Old 02-19-09, 09:28 PM   #178 (permalink)
thugmusk's Avatar
TLCA# 3842
I put it here:
http://home.roadrunner.com/~richadam...stallguide.pdf
'87 FJ60 (10/09 - present)
'97 FZJ80 (03/08 - 08/09, crashed)
'83 FJ60 (11/99 - 12/00, sold)
'85 FJ60 (11/98 - 3/08, rusted, dismantled, parted)
'78 FJ40 (03/98 - present)
'76 FJ40 (10/94 - 11/97, stolen, not forgotten)
thugmusk is offline   Reply With Quote
Old 02-20-09, 06:32 AM   #179 (permalink)
rlabair's Avatar
Thank you, I must give props to Landtank as he did return my email last night about 10pm on the Little Rock clock. Thanks to everyone for your posts, really helps alot. Landtank, great part and improvement, thanks for your effort. Got it installed and it threw code P0110 Intake Air Temp Circuit. Runs great, very smooth, checked the wiring all looks good, any thoughts?
Old 02-20-09, 04:34 PM   #180 (permalink)
ThinkTank Waterboy
landtank's Avatar
if the wiring is correct then possibly the sensor. But if you did check the connections and happened to solve the problem you would need to reset the CEL to have it go out. So just because it's on doesn't mean it's still a problem.
Rick Bigelow
'96 215k
Groveland MA 01834
LinkBack to this Thread: http://forum.ih8mud.com/merchandise-storefront/166370-landtank-performance-maf-housing.html
Posted By For Type Date
Merchandise Storefront on IH8MUD.com Forum - The Truth is in the Rocks - Powered by vBulletin | BoardReader This thread Refback 07-12-08 09:10 PM
MAF Mod - Page 3 - Rising Sun Member Forums Post #0 Refback 06-09-08 08:45 PM
the definitive snorkel thread. - Page 2 - Rising Sun Member Forums This thread Refback 02-24-08 10:33 PM
1997 Toyota Land Cruiser-turbo'd, 3-linked,etc - Pirate4x4.Com Bulletin Board This thread Refback 02-05-08 04:04 PM
