TLCA.org
Go Back   IH8MUD.com > TLCAForum.com > Toyota Land Cruiser Association Forum > North American Clubhouses - Central Region > LA- Bayou State Land Cruisers
Old 07-02-07, 03:06 PM   #1 (permalink)
IH8MUD "I Live Here"
Volunteer's Avatar
TLCA# 16325
Tech Questions Here
Just like the title says if you have a tech question you don't want to ask in the general forum feel free to post it here. We have some knowledgable folks here that can answer your questions or that may have run into the same issues. If we don't know the answer we can point you there.
Larry Landry
Bayou State Land Cruiser Assoc
Visit us at BSLCA.com ; Facebook
67 lacking some metal work and paint
74 trail beast to be
78 FJ40 trail rig
95 FJ80 DD/family wheeler
02 Sequioa family hauler
Volunteer is offline   Reply With Quote
Old 07-02-07, 03:20 PM   #2 (permalink)
Volunteer's Avatar
TLCA# 16325
Something I learned while on vacation building 74 frame and driveline/70 body for my Dad. To fit an early model 1F oil pan (Off a 70 model) on a later model 1F in a 74 model with the newer oil pump you have to bend the fin in the oil pan closest to the drain plug to get it to fit. If you don't the pan will not seat flat.
Gasket advice: I was on a tight timeline and ordered the Fel Pro gasket from Advanced auto parts which is a 4 piece cork. The sides fit perfectly but trying to get the end pieces it while putting up the pan is a heck of a challege even with using a tube of silicone to try and stick them in. Short story was $15 thrown away. I called Toyota today and ordered the factory gasket which is a 1 piece and the way to go. About $19 with our discount. Just FYI next time you need a gasket or crack your oil pan on a rock
Larry Landry
78 FJ40 trail rig
Old 07-02-07, 08:42 PM   #3 (permalink)
Addict
cajun65's Avatar
TLCA# 16685
Okay, I was about to post this on the 60s forum (still will).
Is the pickup on my rig supposed to be turtle slow? I don't want a drag racer and I know it doesn't compare to the get up that my pickup truck has, but is something off? What really makes me wonder is that when I hit about 52 miles per hour, all of a sudden, I can jump from there to 70 with no problem at all. It's actually surprising how quick it gets after 52 mph. But getting to 52 seems to take forever.
Just wondering. Let's here it.
1999 UZJ, stock and that's okay.
cajun65 is offline   Reply With Quote
Old 07-02-07, 11:04 PM   #4 (permalink)
Volunteer's Avatar
TLCA# 16325
From what I've read Marty your truck is normal. Even in perfect mechanical condition you wouldn't see much more improvements. An automatic FJ62 and even the 80's don't have that much get up and go but thats not what they were made for and they are some heavy beasts.
Larry Landry
78 FJ40 trail rig
Old 07-03-07, 08:09 AM   #5 (permalink)
Addict
cajun65's Avatar
TLCA# 16685
I figured you'd say that, I just wanted to make sure. Thanks.
Old 07-03-07, 07:01 PM   #6 (permalink)
tabascoloco's Avatar
TLCA# 12940
The shift points on AUTO tranny are controlled by computer. On my 80 series, there's a POWER button you can press. This simply burns more gas, because it changes the RPM/SPEED at which it shifts from first to second,third,etc. Anyway, that said, I run a Flowmaster exhaust, with Magnaflow catalytic, and like to leave the PWR button on. I find that its plenty fast for me. The air cleaner in the FJ62 is pretty sizable, but the FJ60 stock air cleaner is ridiculously small and restrictive. I agree with Larry that for you year/model, that's about right.
'85 BJ70
TLCA #12940
tabascoloco is offline   Reply With Quote
Old 07-03-07, 08:45 PM   #7 (permalink)
Addict
cajun65's Avatar
TLCA# 16685
I think I need to look at my exhaust system on my rig. That and the air flowing in.
Old 07-04-07, 05:53 AM   #8 (permalink)
TLCA# 12940
On the 3FE, it's pretty darn good...the air cleaner is nice and not like the late 70's early 80's 2F design...also, the headers and larger exhaust help a little, but I don't expect huge gains. I think about 2.5" to 3" max is great on these sized engines.
'85 BJ70
TLCA #12940
Old 07-08-07, 08:39 AM   #9 (permalink)
Addict
cajun65's Avatar
TLCA# 16685
Next question: Does the speedometer connect in any way to the tranny? Mine went out this week. I wonder if there is a correlation to the recent work done and it going out.
MC
Old 07-08-07, 08:58 AM   #10 (permalink)
my81fj's Avatar
TLCA# 17809
ok guys got to drive the crusier today. bad news is i have a very bad vibration above 30 mph. need some help with what to look at to fix this problem.
my81fj is offline   Reply With Quote
Old 07-08-07, 10:34 AM   #11 (permalink)
TLCA# 12940
MC
Marty, it is attached. Crawl under there at you'll see it...cable just screws on. Unscrew it, and pull out. Inspect. There are like 2 washers with a gasket in the middle of them and on the end of the cable itself it a prop-like piece that spins. Might have come loose, or broke...check it out and report.
4" lift. How much shackle lift if any?
This one is very very different for everyone. SOme people lift 3 or 4" and have no vibrations or nothing. Others, simply lift 2.5" and shackles, and they get problems. I think that the Shackles really throw off the pinion angle, since it lifts unevenly on one side only. I think that if you get a angle finder and get your pinion angles front and rear the same (no matter what they are), you'll be fine. But, what I did on my rig was time-consuming and a PITA, but worked awesome. I calculated the proper Castor for my rig and shimmed it up right---This made my rig ride awesome, straight and true...no following lines in the road, etc.
Secondly, I measured the front pinion angle and ordered shims for the rear. In my case, it was 4degree and 6 degree.....different front and rear.
Final note: Assuming that you didn't take the rear driveshaft off and put on out of phase, there's another possible cause...but before I go there, just get try to get your front and rear pinion angles the SAME and that will probably do it.
Anyway, what happens is that the SLIGHTEST wear in the driveline ANYWHERE (U-joints---check them) Ujoints, tranny, transfer case, etc) translates into MAJOR vibes after a lift. Some folks try everything and then end up rebuilding their transfer case and/or tranny and it is resolved.
Also, search the forum for ideas and info. Use Advanced. But alot of the info is highly opinion. the bottom line is that you have to get your front and rear pinion angles equal...whatever that takes...different brands of springs are different, eveyone's rig different, so measure it and see. This means that they should be parallel to each other.
OH YEAH: Make sure that if you don't have shackle reversal (like Larry's and Armond's) then you need the THICK part of the shims pointed to the FRONT of your rig both front and rear axle...The Thicker side of the wedge needs to face the front of the truck on ALL SHIMS unless you have a shackle reversal....but again, the pinion angles will be WAY off if one of them is reversed.
Mike
'85 BJ70
TLCA #12940
Old 07-10-07, 05:24 PM   #12 (permalink)
"socks"
TLCA# 17362
I think I need to do some work on the cooling system on my truck. At idle and up to about 55 in runs a constant 190 degrees, hell even crawling around on the trail it runs cool. but get it on interstate about 70-75 and it comes up to 205 and when in the mud while I was running it hard I once saw it come up to 220. I stopped and let it idle to keep the coolant circulating through the head and it cooled down to 190 again in about 2 or three min but I dont know what could be causing it to act liek this.
It always ran a steady 190 regardless of what I did with my old clapped out engine. Thermostat sticking and not alowing full flow?
1984 Toyota 4runner SR5
2004 Ford F150
2002 Suzuki DL1000
BikerTrash is offline   Reply With Quote
Old 07-10-07, 08:19 PM   #13 (permalink)
TLCA# 12940
Opposite here....I even checked my gauge against the GM computer and its 180's even after driving all day in 100F. I think that my FJ60 fan clutch and larger radiator is why...plus Oil cooler helps I'm sure... remember what they were saying about your fan maybe blowing wrong? Hmmmm....
'85 BJ70
TLCA #12940
Old 07-10-07, 08:37 PM   #14 (permalink)
"socks"
TLCA# 17362
thats true... I fixed it so that it is drawing, but if the blades are in the wrong position then they would not be workign at their peak efficiency . I am about to take it off and put a clutch fan and shroud back on I really didn't feel any differance when I put the electric fan on anyway.
2004 Ford F150
2002 Suzuki DL1000
Old 07-10-07, 09:43 PM   #15 (permalink)
Volunteer's Avatar
TLCA# 16325
Also if your radiator coils are gummed up with mud or just insect crap over the years it won't let the air circulate through the radiator. The gumbo MUD you went through this weekend will do that I've seen it many times in those situations. You can run both the fan clutch and electric fan for extra cooling reloacte it to the front of the radiator if its not already there just reverse the fan so it pushes rather than pulls.
LL
Larry Landry
78 FJ40 trail rig
Old 07-11-07, 11:55 AM   #16 (permalink)
TLCA# 12940
A GOOD electric fan should be awesome. I thought about one for my rig...why? AC would blow a little colder for one.....secondly, WATER CROSSINGS!!!!!! I could put a switch to turn the fan off while crossing streams....but honestly, how often is that really??? Unless you a Colicious that is
'85 BJ70
TLCA #12940
Old 07-11-07, 12:08 PM   #17 (permalink)
Colicious's Avatar
LOL. i can see myself getting in trouble in water before anything else. but thats a good idea with the cutoff switch for water crossings. ive heard of people putting tarps in front of the car to protect the fan, but TBH, i would probably be to lazy to do that. a switch would be great, as long as you dont forget to turn it back on
Cole Haddock
BSCLA Member #17
76 Land Cruiser
99 Land Cruiser
Colicious is offline   Reply With Quote
Old 07-11-07, 09:24 PM   #18 (permalink)
IH8Mud4Life
PScottBx's Avatar
TLCA# 16251
... search the forum for ideas and info. Use Advanced. But alot of the info is highly opinion.
Mike
http://forum.ih8mud.com/40-55-series-tech/163564-finished-hfs-4-today-well-sorta.html
1982 FJ45 Troop Carrier "Matilda" - - 1996 LX450 "80 in drag"
Good friends, a few cruisers, alot of laughs and a bunch of wives making this face -->
"If I'm off (which is rare)... I'm in!"
PScottBx is offline   Reply With Quote
Old 07-11-07, 09:30 PM   #19 (permalink)
Volunteer's Avatar
TLCA# 16325
Originally Posted by PScottBx View Post
I sent him that too, I spoke to 85roktoy numerous times on the suspension. That rig look familair minus the white rims.
Larry Landry
78 FJ40 trail rig
Old 07-12-07, 06:26 AM   #20 (permalink)
my81fj's Avatar
TLCA# 17809
I made a few attempts at the driveshaft thing with no luck. I'm probably not doing it right. I should be back this weekend, I'm in MS right now. The help from someone that knows what they are doing would be great. Thanks guys
Old 07-12-07, 09:44 AM   #21 (permalink)
TLCA# 12940
Let's take a look at it this weekend...heck, I'm lifting my 80 big time tomorrow, so may have the same things on my mind...anyway, aside from the common mistake of shimming wrong, driveshaft out of phase, ANY LOOSEness ANYWHERE translates into vibes bigtime because of the increased angles. Worn U joints, worn splines on shaft...cause now its not all-the-way in, etc..even way too much grease in it could cause a little vibe...we'll help you find the culprit over the weekend...just hand in there. Had guys change everything, and later find out that the output shaft on their xfer case was worn...anything loose before, shows up under the increase pinion angles after you lift....even if not noticed before...alot of people goto CVjoints as a partial solution.
'85 BJ70
TLCA #12940
Old 07-12-07, 09:49 AM   #22 (permalink)
my81fj's Avatar
TLCA# 17809
Great. I can give you a hand when I make it back in town, should be sometime on friday and i will be around all weekend. I just have to kiss the kid and kick the wife(hahaha)
Old 07-14-07, 04:29 PM   #23 (permalink)
my81fj's Avatar
TLCA# 17809
Well after talking to Mike he gave me some ideas. I took the back driveshaft off and drove around no vibration from the front. I stuck the shaft back on with everthing lined up vibration came back. i decided to take the caster shims out of the rear and I still a vibration but it is very small and it as at 55 mph verses 40 mph. Almost there. thats how many it took to do all this
Old 07-14-07, 06:07 PM   #24 (permalink)
TLCA# 12940
Yeah, I think that's step #6 in most of by manuals....anyway, after I finished yard work and the rain stopped, I decided to go by an air ratchet, coil spring compressor, and some other misc. tools...hope to get my springs on tomorrow...we'll see....didn't get anything done today. Glad you made progess....almost there.
'85 BJ70
TLCA #12940
Old 07-14-07, 07:26 PM   #25 (permalink)
cruiserschwing's Avatar
TLCA# 7580
Good luck tomorrow Mike. I just wanted to make ONE post in this thread. I really have no value to add to this one other than encouragement!
Previously Owned: 1986 FJ60, 1979 FJ40, 1988 FJ62, 1992 FJ80, 2 - 1978 FJ40's; Currently Looking!!!
"Join the Bayou Boys"
cruiserschwing is offline   Reply With Quote
Old 07-14-07, 10:15 PM   #26 (permalink)
Volunteer's Avatar
TLCA# 16325
Thats good to hear. You may only need 2 degrees in the rear, how did the u-joints look?
Larry Landry
78 FJ40 trail rig
Old 07-15-07, 06:47 AM   #27 (permalink)
my81fj's Avatar
TLCA# 17809
they look old I do have about 1mm of movement. Everything I read on this site says to change them so I will change them out.
Old 07-15-07, 06:55 AM   #28 (permalink)
TLCA# 12940
If you have to order them, I have a set of Ujoints in my 40...brand new....I think all are the same up to something like 1990....with 2F 3F that is....you can always come get these if you need.
I am likely gonna be killing myself trying to put the springs on myself with minimal tools....I did go out and buy some more tools last night...hope to get it done today....
'85 BJ70
TLCA #12940
Old 07-15-07, 09:26 AM   #29 (permalink)
my81fj's Avatar
TLCA# 17809
I can come by this afternoon if you need. I just have this family thing for lunch, should be done by 2 or 3
Old 07-15-07, 09:29 AM   #30 (permalink)
my81fj's Avatar
TLCA# 17809
just call
CONTACT US AT MEMBERSHIP@TLCA.ORG
