08-21-07, 08:01 AM
#91 (permalink)
Addict
Extended Brake Line Question
Found this on the 60 forum for brake lines - NAPA - part #38881.
When I put these on, what else has to be done? I may be winging some of this solo and want to know what to expect or what else I may have to do. What is the install like?
Thanks.
1999 UZJ, stock and that's okay.
08-21-07, 08:12 AM
#92 (permalink)
IH8MUD "I Live Here"
Thanks.
Install is easy, but since your putting on a test lift you may run into a few hiccups here and there but nothing that can't be worked out. On the brake lines is that a part# someone used on their 4inch lift? The only thing you'll need to do after you change them is to bleed all 4-wheels to get all the air out. Once you get the front U-Bolts off I would take them over to Lafayette Spring and have some new ones cut. I read that the rear came with the kit. If it were me I'd order greaseable shackles to go with that new snazzy lift. Let me know when you plan to do it and I'll try to drop in and help when I can
Larry Landry Bayou State Land Cruiser Assoc Visit us at BSLCA.com ; Facebook
67 lacking some metal work and paint 74 trail beast to be 78 FJ40 trail rig 95 FJ80 DD/family wheeler 02 Sequioa family hauler
08-21-07, 08:34 AM
#93 (permalink)
Addict
Man-A-Fre sells a set of these: http://www.man-a-fre.com/parts_acces...BrakeLines.htm
How do you bleed the lines? Pretty easy?
What exactly are greaseable shackles and where do I get them?
Thanks podnuh.
I may set my laptup up in the garage when I do the install.
08-21-07, 09:15 AM
#94 (permalink)
Yep, those should work it says for various lifts I'd make sure you ask them just to clarify that they'll work with a 4inch lift. On the shackles I'd go with something like this http://www.man-a-fre.com/pa/greasableshackles.htm. Bleeding the brakes call me I'll help you there are alot of ways you can do it but I have a nice coffee glass you can use that'll does the trick easy. Here is a brief article http://www.4x4wire.com/toyota/mainte...leedingbrakes/ the only thing I disagree with is his order of doing it I start with the RR, LR, RF, and then LF you always start with the wheel furthest from the master cylinder.
08-21-07, 09:18 AM
#95 (permalink)
Addict
Cool, thanks.
08-21-07, 10:27 AM
#96 (permalink)
IH8Mud4Life
I say w/ all M's flexing that he'll be doing... he's gonna need the anti-reverse shackle
me
1982 FJ45 Troop Carrier "Matilda" - - 1996 LX450 "80 in drag" Good friends, a few cruisers, alot of laughs and a bunch of wives making this face --> "If I'm off (which is rare)... I'm in!"
08-21-07, 10:42 AM
#97 (permalink)
Addict
I just need reinforced springs on the driver side and enough all around to crawl over all the speed bumps in town.
08-21-07, 10:53 AM
#98 (permalink)
M your mud clan link don't work, FYI.
08-21-07, 11:56 AM
#99 (permalink)
Addict
Thanks, fixed it.
08-22-07, 10:25 AM
#100 (permalink)
Hey Marty i was thinking I have the old U bolts from my lift. If they are the same size that are on your ride, you can take one to Lafayette spring and have yours made so that you will have them on hand when you do the lift. Just a thought.
08-22-07, 10:27 AM
#101 (permalink)
Addict
Thanks Corey. I may do that.
08-24-07, 09:45 AM
#102 (permalink)
Any one know where i can get a drag link, tie rod and relay rod made here in town?
08-28-07, 07:44 AM
#103 (permalink)
spent the last hour assesing the pig. what i have discovered, please forgive me since it has been since 2002 since i've owned a clutch operated cruiser, does the slave cylinder' s plunger where it hits the throw out fork have a cap of some type? if so that is what i am missing.
next question i need some advice to what chemicals anyone is using with success for treating rust.
Old Dirty Dan
tlca# 4165
bslca
1987 4runner......
08-28-07, 08:39 AM
#104 (permalink)
Yes, at the end of the slave cylinder rod there is a rounded nut that contacts the clutch fork. There is usually a second nut behind it to lock it in place. Metal Wash is what I use but can't seem to find it here. Eastwood sell it online  http://www.eastwoodco.com/jump.jsp?i...ORY&itemID=372 the site is down. I was able to find it at Advanced Auto in TN when I was doing my Dad's build. I'm sure you can find something comparable at Shannon's or one of the oil field supply houses. I'll look when I get a chance I need some as well to prep the frame on the 67 for painting.  Whats nice about the metal wash is after you clean the surface of the raised rust it cleans and glazes the metal and serves as a primer.
08-28-07, 02:36 PM
#105 (permalink)
upon further inspection there is something on the plunger i do not believe that it looks right, just not sure. i am willing to bet that more than likely that if i just bled it right that is the main problem.
also any one needing to purchase an in town high lift for the weekend the auto parts house in maurice has one and the right color red 78.00.
Old Dirty Dan
tlca# 4165
bslca
1987 4runner......
08-28-07, 03:02 PM
#106 (permalink)
Mike I picked up a 8000 lb pintle today at Utec on Bertrand for $36.00. I looked everywhere yesterday for the D ring mount that bolts to the factory hitch bolts but didn't find one. It'll work.
08-28-07, 03:20 PM
#107 (permalink)
Addict
What place is that?
08-28-07, 03:29 PM
#108 (permalink)
I think B&M and Cajun both sell them for the same price range or cheaper. I thought I remember $70, I bought the 54 ' from B&M for $86.
08-28-07, 03:49 PM
#109 (permalink)
i think it's called federated auto parts. only one in maurice. almost across the street from heberts. the jack is only a 48" probably won't do you any good after a 4" lift and 33's marty. i bought one yesterday in houston same price for a 60".
hey fyi talk to corey futch today he said to pass the word if anyone needs any thing from four wheel parts warehouse to pm him or give him a ring i believe he returns from corpus on fri.
mr marty hey spent some time under the truck today and i am pleased to anounce that the front axle has some 2 degree shims and the rear none. i really did not notice any vibrations, but these tires are worn fuckin' irregular and outa balance.
you need to see this thing it will get your juices flowin' and that lift will be on your truck faster than..........
Old Dirty Dan
tlca# 4165
bslca
1987 4runner......
08-28-07, 04:33 PM
#110 (permalink)
yes if anyone needs somthing from fourwheel parts I can pick it up for you. I will be back and forth for the next year.
08-28-07, 04:53 PM
#111 (permalink)
Addict
I can't wait to see it Dan.
08-28-07, 04:54 PM
#112 (permalink)
just say when. i will be runnin' around on the southside this evening....
Old Dirty Dan
tlca# 4165
bslca
1987 4runner......
08-28-07, 09:51 PM
#113 (permalink)
well i went over to 'nonk will's house and he was able to help me bleed the clutch hydraulic system. i am back in action with a solid pedal and good engagement/disengagement! however i was right about the plunger on the slave itself not having the right end cap, matter a fact will and i discovered it wasn't even threaded. must be some kinda advanced auto zono'reilly's part.
Old Dirty Dan
tlca# 4165
bslca
1987 4runner......
08-29-07, 06:58 AM
#114 (permalink)
Addict
Anyone ever fooled around with their e-brake before? Mine isn't working well. Need to do some research.
08-29-07, 02:41 PM
#115 (permalink)
damn master is going almost gone. scramble to make an order for parts. does any one happen to have a clutch master or rebuild kit?
Old Dirty Dan
tlca# 4165
bslca
1987 4runner......
08-29-07, 02:52 PM
#116 (permalink)
I have a spare brake and clutch master brand new in the box from Spectre, is it the same as a 40?
08-29-07, 02:54 PM
#117 (permalink)
You can go with one of these. See my thread on line locks http://forum.ih8mud.com/40-55-series-tech/174049-where-can-i-get-brake-line-locks.html I'll be putting one in before the crawl.
08-29-07, 02:55 PM
#118 (permalink)
well the rebuild kit is. i do not believe the clutch master cylinders are the same.
Old Dirty Dan
tlca# 4165
bslca
1987 4runner......
08-29-07, 02:56 PM
#119 (permalink)
it's the clutch master cylinder that is giving me trouble. it depends on what production date you bought it for your 40. if you have the 1/75-7/80 i doubt it. if your truck is 8/80-4/85 it may be very possible that is the only years 40's and 60's shared that clutch master. my truck is a 5/85 but most all the sites split the production dates differently some split at 4/85 some at 6/85 that is why i say it may work. my truck is the red headed step child fj60 so was my last one it had the same production date.
Old Dirty Dan
tlca# 4165
bslca
1987 4runner......
08-29-07, 03:18 PM
#120 (permalink)
it's the clutch master cylinder that is giving me trouble. it depends on what production date you bought it for your 40. if you have the 1/75-7/80 i doubt it. if you t**** is 8/80-4/85 it may be very possible that is the only years 40's and 60's shared that clutch master. my truck is a 5/85 but most all the sites split the production dates differently some split at 4/85 some at 6/85 that is why i say it may work. my truck is the red headed step child fj60 so was my last one it had the same production date.
Its the 1/75-7/80  Musson can order I've been getting my stuff in two - three days.
