08-04-09, 11:54 AM
#991 (permalink)
they make square drive line cause its CHEEEP!
1983 Toyota Trailblazer rear powertrax sliders weber electric fan Dog House A/C brake upgrade dd booster/1' mc v rotors calipers more to come
Last year we said, 'Things can't go on like this', and they didn't, they got worse.
Will Rogers
08-04-09, 03:28 PM
#992 (permalink)
Ratio and Speed Calculator
Originally Posted by kjnarmyfj
and also does any one know what would the low range be on the yota with dual t case set up ? i seen vids and its LOW ! and SLOW! but i was wondering around what it is is it lower than 4 ;1 they guy told me i have 15 gears to choose from , with on the trails , input please ?
I just created a simple little DOS program that calculates gear ratio and tells you your speed at 1k-5k rpm. If anyone wants it, send me a pm and I will email it to you.
'85 4Runner Daily Driver, 32" Mud Brutes, 4.88's, Locked F/R, 5" (or so) lift, swaybar disco, OBA, 1" MC, K&N, Accel Coil, Always loud, Always dirty.
08-05-09, 08:54 AM
#993 (permalink)
"socks"
I made one a while back in excel if you want to check it out. I was bored at work and wanted to mess around with gearing and doublers.
Gear calculator.xls - Windows Live
I linked to it on marlin, pirate and here. it aint much but it was the best I could manage in an afternoon. Wish I knew how to program one that would not require excel like in Java or flash or somethign along those lines.
1984 Toyota 4runner SR5
2004 Ford F150
2002 Suzuki DL1000
08-05-09, 06:23 PM
#994 (permalink)
My old one is pretty much the same except uglier because I only intended to use it myself. Basically the same info without the colors and explanation. I then took it and made it into a small program for ease of use and to make available for people without Excel. I did it for practice more than anything.
I used to be heading into the direction of being the world's greatest IT guy but I strayed into the electronics field for few years and now I am in oil well cementing. I want to use some of my IT knowledge on my days off to stay fresh because I hope to get back into it someday. Right now I am playing with C++, then maybe .NET or something like that. It keeps me from feeling like I am wasting my off days.
I see you have a Honda Shadow now. I'm still up for riding sometime if you want. A co-worker just bought an '07 VTX1300 and we'll probably be riding through your area sometime as we plan on hitting some of the scenic rural areas of southern LA.
08-06-09, 05:38 AM
#995 (permalink)
"socks"
Sure, just got to figure out when I will be off and my gf will be working  she does not mind little short rides but she does not like going too far.
2004 Ford F150
2002 Suzuki DL1000
08-06-09, 03:02 PM
#996 (permalink)
I planned on doing something last weekend but my buddy ended up going to Fourchon and I ended up with an ulcer in my right eye.
08-07-09, 01:25 PM
#997 (permalink)
is there a vent on the gas tank? I'm sure there is but I have no clue where it would be.
08-07-09, 02:02 PM
#998 (permalink)
HUH?
Will Rogers
08-07-09, 04:21 PM
#999 (permalink)
"socks"
Originally Posted by lostinafog
HUH?
I think he is asking where a ventline (if there is one) would be located to releave the vaccume caused by fuel being sucked out of his tank by the fuel pump.
On a truck without all the emisions **** controls wouldnt it just be a vented gas cap?
2004 Ford F150
2002 Suzuki DL1000
08-08-09, 04:21 AM
#1000 (permalink)
that's correct Josh that was what I was asking. Thanks
08-08-09, 05:33 AM
#1001 (permalink)
[QUOTE=my81fj;4671912]is there a vent on the gas tank? I'm sure there is but I have no clue where it would be.[/QUOTE
if said tank has only a single fuel line & no other fittings then it must have a vented cap
if it has two fuel lines AKA supply & return then in can use a vented cap but most prob has some kind of vac vent system.
to help in locating vent need the following .
?#1 what kinda gas tank
?#2 is it on a vehicle or some kind of equipment
?#3 what is the appx age of #1 or #2
Will Rogers
08-09-09, 05:29 PM
#1002 (permalink)
[QUOTE=lostinafog;4673574]
Answer to all qustions. My 1981 toyota Landcruiser FJ 40
08-09-09, 06:38 PM
#1003 (permalink)
IH8MUD "I Live Here"
[QUOTE=my81fj;4677250]
Not sure the layout on the 81 Corey the 77 & 78 models have a vent system that flows through the charcoal canister. Also has a little plastic coil vent right above the gas tank filler on pass side. My 70 had a vented camp and no charcoal system. I'll look to see what else I can find.
Larry Landry Bayou State Land Cruiser Assoc Visit us at BSLCA.com ; Facebook
67 lacking some metal work and paint 74 trail beast to be 78 FJ40 trail rig 95 FJ80 DD/family wheeler 02 Sequioa family hauler
08-10-09, 10:20 PM
#1004 (permalink)
any one know wher i can get a hydro steering kit are a parts llist do do it ,?
 07 fjc ,custom toyota buggy
08-11-09, 05:07 AM
#1005 (permalink)
"socks"
full hydro or hydro assist?
2004 Ford F150
2002 Suzuki DL1000
08-11-09, 05:57 AM
#1006 (permalink)
Emailed vac diagram
Will Rogers
08-11-09, 09:00 PM
#1007 (permalink)
what would be better ? im looking to do it on the trail beast dont think that stick pump is made to turn 4os
08-23-09, 10:21 AM
#1008 (permalink)
Albert,
Here is a link to the website where I ordered my pressure switch. They have all kinds of off-road stuff but this link will take you to the air accessories page.
Check Valves, Blow Off Valve, Circuit Breakers, Pressure Switch, Portable Air Compressors, Air Compressor Accessories
The link to their homepage is:
4wd Parts, 4x4 Parts, 4x4 Off-road Accessories, Jeep Accessories, Jeep Wrangler Accessories, Jeep Stuff, Jeep Parts And Accessories, Jeep Truck Accessories
08-23-09, 08:31 PM
#1009 (permalink)
Thanks for the link it will help me build a smaller manifold than the one I am using now.
Nothing puts a smlie on my face like the green glow of 4x4 on the dash !
http://www.bslca.com/
08-23-09, 08:34 PM
#1010 (permalink)
No problem. Thanks for the parts today!
08-26-09, 09:36 PM
#1011 (permalink)
I have searched but have not had much success in locating a 5:28 ring and pinion re-gear for a 97 FZJ-80. Does anyone know who sells the best set out there? Thanks.
A flat tire, empty Toyota tool bag, and more mods to come BSLCA.COM
08-26-09, 10:25 PM
#1012 (permalink)
Go to 80 tech and to search, type regear, you'll get all kinda threads.
It would be a 5:29, don't go with the Sierra's I have.
Slee has Nitro but only go up to 4:88's
Slee - Drivetrain - Gears and Lockers
TPI sell the Precision
TPI4x4
08-27-09, 06:33 AM
#1013 (permalink)
Thanks Larry. Maybe that is why I couldn't find them.  5.28 doesn't compute.
08-27-09, 05:55 PM
#1014 (permalink)
Anybody know if you can make a 2nd gen tire carrier fit a 1st gen 4Runner?
08-27-09, 10:47 PM
#1015 (permalink)
Not sure on that one but as Albert puts it everything is Doable  you would want to weld in some reinforcement metal on the inside of the rear quarters so when you bolted it up it wouldn't peel back the metal on the trails. I thought about doing the same with a factory 80 carrier but I need the bumper carrier for the extra stuff.
08-28-09, 04:53 AM
#1016 (permalink)
Yeah, I was thinking it should work with some fab work. I almost expected someone to come back with a reason why it was impossible.
08-28-09, 05:07 AM
#1017 (permalink)
nothing is impossible with enough desire patients time materials skills and of course ----------a bit of mula
Will Rogers
08-28-09, 05:12 AM
#1018 (permalink)
of course, can't forget the mula
08-28-09, 05:22 AM
#1019 (permalink)
I forgot one friends in high places  ----does anybody have the new # for the White House cause when I try I get a message "no longer in service"
Will Rogers
08-28-09, 05:33 AM
#1020 (permalink)
I hear that. I'm in a low place where I am afraid to even check my oil!
