TLCA.org
Go Back   IH8MUD.com > TLCAForum.com > Toyota Land Cruiser Association Forum > Group Clubhouses > INTL- JDM Owners Alliance
LinkBack (3) Thread Tools Display Modes
Old 10-01-06, 06:29 PM   3 links from elsewhere to this Post. Click to view. #1 (permalink)
Rookie
HzJ74 VS 73
I am seriously considering purchasing one of the above and would like to get opinions on which is better.
Engine?......3.4T or 4.2?
suspension differences?
is the auto tranny in the 74 the 'bulletproof' one or might it cause me grief?
is the 73 a 24V system of 12? the 24V system scares me for some reason.
thanks for any help i might get!
Pete
justpete is offline   Reply With Quote
Old 10-01-06, 07:56 PM   #2 (permalink)
lowenbrau's Avatar
TLCA# 5513
I don't know why this got moved here but I'll give you my thoughts.
The auto is the same in either and will outlast a couple of clutches and the fifth gear of the five speed. You should choose based on preference and not durability.
The 13bt is likely marginally more durable than the 1hz and then only because of the in line pump. The turbo is a liability though. The six makes similar power without one.
The HZJ 73 has bigger birfields and a smaller ring gear. Pro and con. It also has coils in the front which make it work better.
12 or 24 volts is generally market dependent and both have their benefits. Nothing to be afraid of.
IS summery, drive them both. see which one you like more. You can't go wrong.
Rocky Mountain Land Cruiser Association TLCA # 5513
'91HDJ81, '87BJ74, '86BJ70, '78FJ45, '53M100, '90M101cdn and a Dodge
I support our Troopies
lowenbrau is offline   Reply With Quote
Old 10-02-06, 01:39 AM   #3 (permalink)
Stand and deliver
roscoFJ73's Avatar
HZJ73 is leaf sprung and the HZJ74 is the coil sprung. The HZJ71 is the coil sprung 70 version
Unlike the earlier models ,a jump up in numbers denotes a suspension change from leaf to coil rather than the turbo option
Turbo models are now known by the engine prefix of HDJ**
I would get the 1HZ because it has wider,smoother power band.
Mr Rentokill
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Holden Commodore V6
Honda XR650L
Old 10-02-06, 09:06 AM   #4 (permalink)
Supporting Vendor
Greg_B's Avatar
TLCA# 7091
Me neither. Should be in the 7* series section if anything.
Other then that, agree with most of what has been said.
I figure an HZJ73 with BJ74 cable locking axles, and a 1HD-T would be a sweet ride.
Back to your question...
HZJ73's seem to be much easier to find then the BJ74's right now, so that may be a consideration.
As Bruce said: "In summery, drive them both. see which one you like more. You can't go wrong."
hth's
gb
Old 10-02-06, 09:15 AM   #5 (permalink)
..I don't know why this moved here, should be a 70 series thread, but..
1985-1990 trucks have the 4 wheel leaf sprung, 9.5" ring gears front and rear and most often are seen with the "3B" engine known as the BJ73 or the turbo 13B-T = BJ74.
1990-1999 have leaf sprung, only the 1HZ 6 cylinder = HZJ73, and have 8" front ring gear plus ONLY slightly larger birfields.
1999+ have coil sprung front ends, 8" front ring gear, MUCH larger birfields (ala 80 series) and are denoted the HZJ74's. No 1990+ factory turbos are know (to 2004 production) of the 102" wheel base 73/74 classes.
the auto is ok, have heard of some problems but nothing "death-nail". I prefer the simplicity of the cast iron H55 5 speed transmission in north america because of parts supply (discontinued in 1999). In another land I think I would like the H150/1 series larger transmission. The R150/1 smaller 5 speed I don't have a solid opinion on.
JDM trucks are often 24v (I run one here in Arizona) and live with the system. 12v trucks I believe became a JDM standard circa 1994 or so but sometimes had 24V start. In my mind, all 12 or all 24, don't mix.
I'd choose HZ engine because of ease of upgrade to turbo HD-T (what I have). I prefer the 9.5" ring gear, but you can't get them in front with HZ engine unless you modify. 12/24 non issue, live with what you get. and I like manuals more than auto. If your in canada, your not getting a coil front import for 5 years so scratch that.
rick_d is offline   Reply With Quote
Old 10-03-06, 12:28 AM   #6 (permalink)
retired maths geek huh
denis's Avatar
LJ73 and KZJ73 come to mind
'71MS75 5cyl crown coupe '74MS75 6cyl crown coupe '74MS75 4cyl crown coupe '75BJ40 DD '79FJ55 rostig schwein '80BJ40 never ending resto '82BJ45 project troopie 50% '83LN46 no engine '84BJ45 project troopie 50% '88LN65 getting closer '90HDJ80 the bear '92LN85 turbo ute '96LN108 rustbucket
Originally Posted by LandCruiserPhil View Post
there are a lot more single women available then nice low mileage Land Cruisers.
denis is offline   Reply With Quote
Old 10-03-06, 08:19 AM   #7 (permalink)
crushers's Avatar
gb
oh give it up, there are plenty of threads in the 70 series section that should be here including the race photos thread. no tech there but it is still sitting there. i would be willing to trade you that thread for this one...
this info has been covered a few times now, a search should have been made.
the start to the above truck here: http://forum.ih8mud.com/70-series-te...uck-build.html
shit all flows down hill and pools around your feet. The object is to
keep shovelling it away. If the shit is gaining you better figure out
how to shovel faster :-) Dave Stedman 03/20/09
(for any of you going through a divorce, thanks Woody) http://forum.ih8mud.com/1650867-post1.html
Wayne in Ontario
www.luxuryimports.ca
Old 10-08-06, 07:04 AM   #8 (permalink)
lshobie's Avatar
Haven Driven both I like the HZJ73 much better with caveats. I like the cable lockers on teh bj74 better as well as the bigger front end. The engine is the best part on the HZJ73 - it is smooth and has lots of power -as well as power potential with the addition of the turbo.
All in all my vote is for the HZJ73.
Regards,
Louis
Check out my youtube videos at: www.youtube.com/lshobie
Join the True North Toyota Land Cruiser Club in Ottawa http://landcruisers.ca/
lshobie is offline   Reply With Quote
Old 10-10-06, 10:20 PM   #9 (permalink)
jcolvin's Avatar
TLCA# 15691
Regards,
Seconded. Having driven both, the engine in the HZ73 is smooth and powerful, and puts the BJ74 to shame. Its a lovely little engine it is.
Jonathan Colvin Galiano Island, BC
1990 HDJ81 w. OME, 35'', intercooler, safari snorkel, locked all-round, viair 450 onboard air, deer-killer bumpa + train horns, milemarker hydraulic
Mitsubishi delica for the wifee
jcolvin is offline   Reply With Quote
Old 10-12-06, 05:52 PM   #10 (permalink)
crushers's Avatar
after beating some of the post 1990 models now i can say i like the newer rigs better than the older ones but the large front diff is nice to have...
the HZ is quieter, more poerful and b etter on fuel than the older 13BT...
cheers
Wayne in Ontario
Old 11-26-06, 09:49 PM   #11 (permalink)
bruzer's Avatar
i pot a pzj70 and a hzj73 come next month i know all bout the hzj but not the 1pz any help out there?
bruzer is offline   Reply With Quote
Old 11-26-06, 11:10 PM   #12 (permalink)
crushers's Avatar
i am wheeling a PZJ70 right now and have been for about a year. i turbo'd it way back and never regrettied it. i have driven the HZ for a few years now and that is a nice engien as well, they are quite comparable. the turbo PZ is faster and stronger than the NA HZ but turbo the HZ and it kicks anything Toyota's ass...
you bought 2 trucks you know nothing about?!?
Wayne in Ontario
Old 11-27-06, 02:30 PM   #13 (permalink)
bruzer's Avatar
you can only read so much, then buy! i own a 1989 bj73 1984 bj60 1997 tacco
1991 hdj 81. i was also bidding on the fj75 but stop at 300000yen lol
Old 11-27-06, 02:44 PM   #14 (permalink)
lshobie's Avatar
You will find just about everything you need at either ENS or G and S in BC. You can get the engine manual at ENS - i'd get that if you dont already have it.
You like JDM's! That's awsome.
I was going to go for the FJ75, but not too fancy on gassers at this point. And, I see fire trucks just about everyday - not really into them that much when you drive one all the time
Regards,
Louis
Old 11-27-06, 03:08 PM   #15 (permalink)
bruzer's Avatar
yes i got the manuals
g and s ? do you have a link?
i was going to do a engine swap on the fj75
Old 11-27-06, 03:18 PM   #16 (permalink)
Deny's Avatar
TLCA# 11568
Go up to the number 4 post on this thread, and in Greg's sig line is the link.
Cheers,
Deny
Diesels Rule
81 BJ42 and a few other cruisers
Check out my endless fix up progress at http://forum.ih8mud.com/ca-bc-peace-canyon-toyota-swamp-donkeys/152995-bj42-winter-fix-up.html
Deny is offline   Reply With Quote
Old 11-27-06, 03:21 PM   #17 (permalink)
crushers's Avatar
you were WAY short on the FJ75...
Wayne in Ontario
Old 11-27-06, 03:28 PM   #18 (permalink)
bruzer's Avatar
i know! thats the lol
i saw the winning bid
thanks for the link
Old 11-27-06, 03:48 PM   #19 (permalink)
crushers's Avatar
so, you going to introduce yourself to the forum?
Wayne in Ontario
Old 11-27-06, 03:48 PM   #20 (permalink)
lshobie's Avatar
http://www.gscruiserparts.com/
Louis
Old 11-27-06, 06:29 PM   #21 (permalink)
bruzer's Avatar
derik mcauley i live in prince Albert and i drive truck up in northern Saskatchewan been cruiser owner for 12 yrs and very computer illiterate
bruzer is the name for my bj60
Old 11-27-06, 06:32 PM   #22 (permalink)
crushers's Avatar
welcome Derik
Wayne in Ontario
Old 11-27-06, 06:37 PM   #23 (permalink)
lshobie's Avatar
Nice to have you Derik.
Louis
Old 11-27-06, 09:56 PM   #24 (permalink)
Supporting Vendor
Greg_B's Avatar
TLCA# 7091
Thanks for the link lshobie...
I forgot all about this thread.
it really should be in the 70's section...
gb
Old 11-28-06, 06:19 AM   #25 (permalink)
lshobie's Avatar
No problem Greg, your service is invaluable.
Regards,
Louis
Old 11-29-06, 03:29 PM   #26 (permalink)
Deny's Avatar
TLCA# 11568
Cheers,
Deny
gb
Hey,
I was first! Thanks for no thanks
Diesels Rule
Check out my endless fix up progress at http://forum.ih8mud.com/showthread.php?t=152995
Old 12-04-06, 12:21 AM   #27 (permalink)
Supporting Vendor
Greg_B's Avatar
TLCA# 7091
Hey,
Deny...you know better then that, you're trailer trash!
Ugggg...that's what I get for scanning the last few and leaving it at that...
Thanks Deny!
gb
Old 12-04-06, 08:50 AM   #28 (permalink)
Deny's Avatar
TLCA# 11568
Don't worry,
I know it's tough keeping track of all my own posts, there is just so many sections on mud now. And I am proud trailer trash
Cheers,
Deny
Diesels Rule
Old 01-28-09, 07:04 PM   #29 (permalink)
Radd Cruisers's Avatar
This really should be in the 7 series forum tho...............
Rob
Come and visit us in Duncan, Vancouver Island, BC
www.raddcruisers.ca
Monday - Friday 08:00 - 17:00
LinkBack to this Thread: http://forum.ih8mud.com/intl-jdm-owners-alliance/113065-hzj74-vs-73-a.html
Posted By For Type Date
hzj 73 turbo | VIRGILIO Ricerca | Web This thread Refback 04-11-09 03:23 AM
hzj74 | VIRGILIO Ricerca | Web This thread Refback 03-21-09 10:37 AM
'hzj74' related products for sale This thread Refback 02-25-08 04:01 PM
CONTACT US AT MEMBERSHIP@TLCA.ORG
