TLCA HOME : BOARD & BYLAWS : EVENTS: MERCHANDISE : BUSINESSES : PHOTO GALLERY : CLASSIFIEDS
HISTORY : TOYOTA TRAILS : MEMBERSHIP : CLUBS : MISSING VEHICLES : LAND USE : CHAT : LINKS
Go Back   IH8MUD™ Forums > TLCAForum.com > Toyota Land Cruiser Association Forum > Clubhouse Corner > IL- Windy City Land Cruisers
Old 01-21-06, 09:32 PM   #1
You like dags?
Scott_sFZJ80's Avatar
TLCA# 13283
Scott_sFZJ80
Local Snorkel Install
I know that it’s been covered in other write ups but I had a few ideas that I would like to share. The Safari Snorkel is a nice product but I’m guessing that the company figures that the typical customer will take a few liberties on the install because the instructions were pretty bare. Also, they could have come up with a better place for the a-pillar bottom mounting hole.
1993 FZJ80 ROTW - October 23-29 2005
Snorkel install , Skid Plate install , Rear Bumper
Scott_sFZJ80 is offline   Reply With Quote
Old 01-21-06, 09:35 PM   #2
You like dags?
TLCA# 13283
Scott_sFZJ80
Step 1:
Remove air filter box (and associated duct work), front right turn signal, cruise control and drop antenna. Be sure to cover/block intake because there will be metal flakes flying around.
Old 01-21-06, 09:36 PM   #3
You like dags?
TLCA# 13283
Scott_sFZJ80
Step 2:
Carefully place provided template and tape to fender. Mark holes, remove template, check against snorkel (do a lot of checking and re-checking).
Old 01-21-06, 09:37 PM   #4
You like dags?
TLCA# 13283
Scott_sFZJ80
Step 3:
Center punch all marks made on the fender. Drill a small pilot hole for the “big hole”. Tape the area around the pilot hole and poke out the tape at the small hole. Hold your breath and drill the big three and a half inch hole in the side of your rig! De burr around the hole and paint the bare metal (if time allows let the paint on this hole dry over night).
Old 01-21-06, 09:39 PM   #5
You like dags?
TLCA# 13283
Scott_sFZJ80
Step 4:
Drill a small hole at all other marks on the fender. Use a step drill to increase each hole to the proper dimension. Side note: not a big deal but take note that the furthest hole forward for some reason is smaller than the rest. De burr around all the holes and paint the bare metal (you most likely won’t have to de burr much if you are using a step drill).
Old 01-21-06, 09:40 PM   #6
You like dags?
TLCA# 13283
Scott_sFZJ80
Step 5:
Screw in the studs to the snorkel (use a little thread lock to secure the stud to the snorkel). Connect the upper mounting bracket to the snorkel (no thread lock, you are going to have to remove it again). Place the snorkel onto the fender and mark the upper bracket on the A-Pillar. Remove snorkel and remove upper mounting bracket from snorkel. Place upper mounting bracket to A-Pillar and finish marking holes for drilling.
Old 01-21-06, 09:42 PM   #7
You like dags?
TLCA# 13283
Scott_sFZJ80
Step 6:
Center punch marks on A-Pillar. Drill small holes at each mark. Side note: be careful with the bottom (or lowest) hole, this hole needs to penetrate but stop just after due to an obstruction behind the exterior sheet metal. Step drill the holes only enough to get a small file in hole to square it off. The plastic body clips are square and are going to require some precise filing to fit properly.
Old 01-21-06, 09:43 PM   #8
You like dags?
TLCA# 13283
Scott_sFZJ80
Step 7:
Paint holes in A-Pillar and allow to dry. Paint sides of plastic body clips and place in A-Pillar holes while wet. This theory is to help seal the hole from moisture getting into the A-Pillar.
Old 01-21-06, 09:45 PM   #9
You like dags?
TLCA# 13283
Scott_sFZJ80
Step 8:
On the big hole take a length of small vacuum hose and cut a slit down the length of it. Place the hose around the big hole to help reduce the tolerance and assist in sealing from the outside.
Old 01-21-06, 09:46 PM   #10
You like dags?
TLCA# 13283
Scott_sFZJ80
Step 9:
Attach upper mounting bracket to A-Pillar. Attach snorkel to fender with supplied hardware. Reattach upper mounting bracket to snorkel.
Old 01-21-06, 09:48 PM   #11
You like dags?
TLCA# 13283
Scott_sFZJ80
Step 10:
Install supplied hose and clamps to snorkel and fit air filter box, reattach air filter box to mounting points (along with associated duct work). Reattach front right turn signal, cruise control and antenna. Mount and secure air ram assembly to snorkel.
Old 01-21-06, 09:49 PM   #12
You like dags?
TLCA# 13283
Scott_sFZJ80
Ending notes and credits:
Thanks to Cruiserdan, he was calling me back regarding a part order while I was in the shop during the snorkel install and recommended dropping the cruise control and antenna (and not the rubber grommet), it helped out a lot.
Most recommended tool… step drill. If you don’t have one I suggest investing in one, makes for very clean and easy holes.
Use touch up paint, supposedly it holds less moisture than primer making it a little more resistant to rusting.
Take your time and keep checking and re-checking at every step.
Use a 3 ½” drill bit, I toyed with idea of some other sizes because the snorkel inlet hole isn’t that big but with the vacuum hose it fits perfectly.
Directions call for the removal of side marker light (JDM marker lights), I have these and found no need to remove it.
Old 01-22-06, 09:59 AM   #13
shahrislamic radical
Gumby's Avatar
TLCA# 5658
Gumby is on a distinguished road
After removing the fender for rust repair under the flares, I wonder if it would be easier to drop the fender for this job.
Nice write up. Are you sick of the questions yet?
War Pig and Cerdito
"Don't you know, Stan, it's always between a Giant Douche and a Turd Sandwich."
Gumby is online now   Reply With Quote
Old 01-22-06, 01:40 PM   #14
You like dags?
TLCA# 13283
Scott_sFZJ80
Interesting, Cruiserdan said the same thing… well… not about the rust. He mentioned that he needs to replace his windshield and was toying with the idea of just removing the fender.
Thanks, I have only had it on a week and I can’t believe the looks that it receives. Since my rig is dark green I thought it wouldn’t get much attention. I love look that it has, I have always admired the contrast that you rig has with the black on white.
Old 01-22-06, 02:22 PM   #15
Infidel for hire
Biff's Avatar
TLCA# 14778
Biff is an unknown quantity at this point
Good wirte up.
If I had to do mine again I would have dropped the fender would have made it alot easier to reach that last inner screw. I ended up using nutserts for my a-piller, better quality that the plastic things Safari provides.
Victor
08 FJ TT edition
71 fj40 project rig
Biff is offline   Reply With Quote
Old 01-27-06, 04:34 AM   #16
alia176's Avatar
TLCA# 15941
alia176 is an unknown quantity at this point
I'm loosely thinking of coming up with my own snorkel but need to drop the fender. Is this a one banana job? Any gotchas?
Ali
TLCA # 15941
KE5LED
Currently working in Danville, PA until Aug.
alia176 is offline   Reply With Quote
Old 01-27-06, 06:55 AM   #17
Gumby's Avatar
TLCA# 5658
One Banana. two bolts on the flare then wiggle the flare around (post 95) until it pops out. The bolts across the top and a few across the bottom. Two, IIRC in the door jam. The inner fender well is sealed to the fender with some super secret goop.
It is easy to break off the lower fender bolts if they rusted.
I think it's worth it to check for rust under the flares.
War Pig and Cerdito
Toyota Land Cruiser Association YOU MAY CONTACT US AT MEMBERSHIP@TLCA.ORG | (800) 655-3810 | PO BOX 230, VERONA, KY 41092
